crazyman03
Administrator
    4
Everything posted by crazyman03
  1. So, I'm still working on this '05 WRX; I Pulled the turbo out and the turbine does spin and doesnt have any play in it. Though, the car does have ~150k and the turbo needs to be rebuilt, but thats a different project for a different day. Put the turbo in and it feels like there is a little boost now but, it bucks at you right around when the turbo would put out boost (around 3 - 4k on the tach). Any ideas? i was going to suggest a tune up. but im thinking it wont help much.. Ideas? -Justin
  2. Lay it flat, wrapped in blankets and maybe a tie-strap or two lightly holding it in place? I transported mine sitting vertical in the floorboards wrapped in blankets.. they are pretty durable - considering they sit on the front of your car ;-) edit: good luck getting it out... i hear thats the hard part. Im trying to get one for my back window and am thinking of just getting the entire liftgate. -Justin
  3. Ok, yea. by fine i mean it spins, no In/out play and no wiggle play. it does have a lot of oil on the intake side - probably the reason for the low oil problem and it does need to be rebuilt with as many miles as it has on it. The bonkers part is: no CEL. Yes, the light works on initial "key-on" test and Yes, I've plugged a reader in just for giggles and returned no codes :-/. We were thinking of putting it all back together and putting a boost gauge on it to see.. kinda wish we did that in the first place, though it really looked like it was shot. -Justin
  4. Well, Pulled the turbo off.... ... ... wait for it... ITS FINE!! WTHECK?!? Ideas?????? To add: it bucks at about 2-3500... -Justin
  5. oh, and since we're on the subject *tehehe* look what followed me home tonight... predator antenna :-D -Justin
  6. lol the only problem is: he just bought it 2 months ago for 10g's... yea, im not buying his loan for the car ;-) too bad though.. its a nice car.. but i dont want his problems lol! -Justin
  7. actually, what i should've added is no.. its not mine. its the one with the *likley* seized turbo. I gotta fix it.. but i dont want to give it back! lol! -Justin
  8. Well, look what followed me home, Now all I have to do is look at it. On that note, while I drove it home, I could've swore there was just a *tiny* bit of boost - Which was odd.. It shouldn'tve had any... -Justin
  9. And to add.. Tire wear, Air pressure, alignment.. but thats just being nit-picky.. -Justin
  10. i can't remember what type of relay they have in there but you can test it to be sure with just some wire (speaker wire works) and your battery. usually, the numbers match up and a lot of the time there are diagrams on the relay itself before you do anything, If you have a DMM, probe for connectivity between "30" and "87a" it should be good. apply +12 power to "85" and "86" (doesnt matter which polarity), and it should click. with power applied, now probe between "30" and "87a" again-there shouldn't be any connectivity. probe "30" and "87" - you should have connectivity. If all that works, then the relay is fine. this is for a standard "accessory" relay so double check what yours is before probing. This should give you an idea if there is a diagram on the relay you have, you can see how it works in order to test it. -Justin
  11. It really depends on how you throttle it. Downshifting and heavy engine working will directly effect it. Also, a good air filter, spark plugs, wires and even oil type/age make a huge difference. -Justin
  12. Down-Right-Sexy. I particularly like that the Ram in the last picture has smaller tires than the subaru lol! -Justin
  13. oh, my, WOW! what axles are those? did you do a toyota tcase and axles? looks like you kept the shocks in the stock locations? (as far as stock could co on that body) -Justin
  14. be sure to "throttle" your engine. I've seen 30MPG in my little Impy and about 38 out of my old GL wagon. I drove down to Trinidad on monday, and Cheyenne on tuesday.. ~26-30MPG round trip.. I throttle it at 70mph on cruse and kick it off on hills so it doesnt down-shift going up those hills - thats where you really kill your hwy miles. keeping the engine speed at around 2500 - 3k.. will help keep your mpg up.. any higher and you are putting more engine energy to keep the speed up there. 70mph is about what i cruse at.. sources: I hypermile! -Justin
  15. Well, Its just me in my car 95% of the time. the other 5% is the occasional person to give a ride. they can deal most of the time I'm either otr (over the road) or cruising around town at work and talking to myself only goes so far lol! -Justin
  16. I had to resurrect this one because.. Well, I had to. My Step-dad gave me his "trucking" CB before he retired from the road and eventually passed away. Its a Galaxy DX959. Tweaked and peaked with a little "box" to help me reach out and smack someone. I need a new antenna but I got ears! -Justin
  17. yea, but.. that there is no boost and the amount of oil, its likley blown. I wish i had a lot more time to tear it down. Its hit-or-miss with working on it.. -Justin
  18. To add, He's been topping off the oil and just put 4 qts or so in after we drove it. We took the inter-cooler off and there was a lot fresh oil in it as well as the outtake of the turbo. We didn't have a whole lot of time to tear down to get to the turbine and ended up putting it back together. With the fresh oil in the intake, and as much as there was, a seal/bearing in the turbo had to've blown right? -Justin
  19. From what I've read, its probably not related. http://forums.nasioc.com/forums/showthread.php?t=1469427 -Justin
  20. actually, thats the part that really *ticks* me off. an '05 WRX.. thats the car of my dreams! and he goes and wrecks the engine within 2 months of owning it. I would've worshiped that car and he seizes the turbo?!? I guess that's the difference between a guy that's worked for each and every car he's owned - and the guy that's had every car he's owned given to him. -Justin
  21. with a drill.. I'm sure you could come up with something. the only problem is you wont have a top trim piece where the cup holders are.. I've moved the stereo Up and flipped with the little cubby thats there but the cup holders would be interesting since the mount is a little wider.. -Justin
  22. I ran mine through the grommet behind the petals and ran it along the door jams. Just pull the trim out, and run it under the carpet. no zip-ties needed it just sits there. put the carpet back and the trim and voila! you cant see it and it only took me ~5 minutes per door to do it. before i bought mine, the previous owner had 2x 12's and 1500w. on zero gauge.. I ran it the same way. No pictures of her install though, but here's my little-bitty amp/sub -Justin
  23. Another thing is too, He's only had the car 2 months. (just plated it yesterday). I Advised them of needing a rebuild and to not be surprised when it comes around. More interested in a bigger better turbo - even though I told him he really doesnt need much more than what he has already. And if he couldnt pay attention to it as a stock turbo, what makes him think a bigger one is going to be easier. I think he just wants to listen to it whistle, and thats what it "takes". His mom is paying for the new turbo so whatever she says goes.. -Justin
  24. Problem with rebuilding it is the price tag. It's easier to look at the turbo and replace... I did tell them about what all could go on with the engine... Probably going to wait intill it all fails :-/ -Justin
  25. I have found a couple on ebay for a decent price new.. are all the EJ20 compatible work on multiple car model years? http://www.ebay.com/itm/GSP-BOLT-ON-TD05-16G-turbo-IMPREZA-WRX-STI-04-07-ej20-ej25-PERFORMANCE-GDA-GDB-/261073146552?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cc92c12b8&vxp=mtr http://www.ebay.com/itm/Subaru-WRX-STI-TD05-20g-Turbo-Charger-EJ20-EJ25-NEW-/170887310632?pt=Motors_Car_Truck_Parts_Accessories&hash=item27c9ad6d28&vxp=mtr -Justin
