argg.. brake caliper
jimscat replied to nickb21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlooks like a slide boot. make sure that those are greased well. mine froze up and caused some issues. sub does have a kit available.
Caliper/ Brake Issue? Please advise!
jimscat replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just went through this on my 93. it sounds to me that your slides are frozen. Subaru does make a rebuild kit (for my 93 anyway) comes with new o rings and caliper boots. I could not get the clips back in and the pads rattle. I should have bought new calipers but here in my area the best price I got was well over $200 bucks apeice.
Brake Pad Question
jimscat replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just did the brakes on mine and on my 93 the pads will go either way. the tabs on the front were on the outside and the rears were on the inside. I have done the brakes once before, so I cant say for sure that this was the way they were from the factory. Anyway it did not matter cuz the pads wore uneven and I had to free all 4 caliper slides.
A/C Issue
jimscat replied to Dr. Rock's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy 93 does the same thing. owners manual says it standard and helps dry the air out
90 Legacy Wagon- How can I test if AWD is working?
jimscat replied to subaruVWnut's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI to wondered if my awd worked after a got my 93. during the first winter I found out that it did work. I had to spin the fronts for maybe 15 secs and then I heard a clunk and would drive off. After figureing out that athe clunk was the rear locking up, I would just ease the gas and wait till I felt it, then drive off. After reading fj401968 post, I agree, just like any other thing that has gears that it will get a little sloppy (maybe my clink)
New Subarus and Problems!!!!
jimscat replied to Capri's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi generally do all my repairs but it would be nice to have a new car. with a proven reliable car yoy wouldnt have much for repairs but the needed maintenance fee that the warrenty requires will empty your wallet in a hurry.
rebuilding brakes
jimscat replied to jimscat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok guys, since I cant find the manual I bought, were is the metal ring and how do I get it off?
Brake Question
jimscat replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just had the same problem with my 93, I had to drive the bolt bushing out and clean up everything. There is a caliper rebuild kit available through Subaru for around $35 us (my area anyway) you may want to check out my post on rebuilding them
Anyone have a fix for leaking sunroof?
jimscat replied to Hondaman900's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdepending on the style, make sure any fasters that go through the glass ore tight.
rebuilding brakes
jimscat replied to jimscat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks guys for the info. sounds a little tricky, but yet quik and easy. I assume when removing the piston, blow air in were the brake line bolts to the caliper
brakes
jimscat replied to jimscat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI priced out a loaded caliper and it was 120 +/-. I paid 20 bucks for pads and 35 bucks for the rebuild kit. 55 bucks and all i really need are the three boots for the slides. ruffly 60 bucks saved and it wont take me long to get it done. it will be harder to get the car out of the road long enough to do it.
rebuilding brakes
on my 93 legacy wagon. i had to buy a rebuild kit to get the 3 boots that i need for the slides. the kit comes with a new boot for the piston. how do i get it out of the housing?
brakes
jimscat replied to jimscat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe left inner pad was worn out, no seperation. Yes I pulled, well actually had to beat the bushing out. it was that rusted up. pulled the old dry rotted boots off, put the high temp never seize to them and put them back together. I ordered a caliper rebuild kit today from suby. 35 bucks, but it was the only way i could get the 3 boots that each side needs. should be here in a few days. then i will have to pull the calipers out again.
brakes
Just I word to the ones that don't no much about them. I recently got a grinding noise in the front brakes and today when i got them off, the left inside pad was gone. the outer was only about half used up. The last time I did the brakes was the first time i had done any and did not make sure the slide the bolt goes through actually moved. MAKE sure it moves or you will have to do like I just did and replace them after 30000 miles. They make a boot kit wich the local part store listed but did not have in stock. I put them back together and will get the kit as soon as I can.
Refrigerant pressure too high
jimscat replied to mb86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom messing with mine, it sounds like you may either have some air or the preasure is to high. Hopefully Josh will chime in. He seems to be the guru on the subject. Do a search on ac and see if you can find anything Jim
jimscat
