Hogsubie
Everything posted by Hogsubie
Thanks guys. I probably should have provided more information. I only need them for the front for my 1994 Legacy L awd 5-speed. Jamal, Not sure if it's broken, but the bushings on the end links appear to be coming out. Plus I'm having some knocking sounds from the front end (not cv clicking). I'm not really interested in performance parts, I just want to keep it running smooth til the end of the year. I found some for $38 that I think I'm going to order, unless the ones you have will fit and are offering them at a better price??? Thanks for the responses guys,
gas gauge
Hogsubie replied to pamonster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That's kind of what I figured. Is there a way to carry gas safely though? I just didn't know if the it was supposed to light up with all the other indicator lights on startup. Thanks for the tips. I guess I'll have to live with the anxiety. BTW, what kind of mileage do you guys get with a 50/50 mix of city and highway driving. I've gotten about 320 to 340, but on fill up I was only able to put in like 13 or 14 gallons. At that point I was on E for atleast 30 miles, but the light hadn't come on. -
gas gauge
I hope this isn't hijacking the thread, because it is related to this issue. I have a 94 Legacy L and I know the gauge is off. Most advise waiting for the gas light to come on in order to fill up. Others have comented on their gas light not working. How do I know if my gas light works. I have not seen it light up when all the other lights come on during startup nor have I tested it by running my gas that low....is it supposed to? Is there a way to test the light? I usually will fill up when the gauge is on E and I've driven about 30-40 miles past. I get too nervous after that and just have to stop and fill up. I drive about 80 miles roundtrip to school and it all backroads with little to nothing but farm houses in between. I'm a little paranoid of running out of gas out there, not for fear of anything, just for the fact of walking to get help and being late for work or school. -
Well, you could do that...but that is environmentally irresponsible. It's actually is illegal in most places. I would suggest taking it to a shop, they hook up recovery equipment to suck it all out. Shouldn't cost very much just to have it dishcarged. I worked in the HVAC business for a while...atleast commercially there are very large fines for dishcarging freon in to the atmosphere (air).
Hey guys...I'm back. Well, actually I used to post mainly on the old gen forum, but when my ea81 crapped out on me, I kind of lost interest. However....next week I'm picking up a 94 Legacy L sedan. It needs wheels in a bad way...so I'm looking for info on what factory wheels fit and also the size of 15's or 16's to get in aftermarket. I'm not looking for anything too aggressive. I don't want larger than 16's. I'm considereing Rota's, but what are some relatively inexpensive brands you all are using? Where have you guys bought wheels before? Know anygood websites?
Superlite Wheels
Hogsubie replied to Barry Knickerbocker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
He's got a website so you might check there... http://www.packracingproducts.com/ -
mmmmmmmmmmmm...Garage envy! I guess I should complain, I do have a garage. It was a 2-car but I added an 8X12 room in the back corner off the door into the house. So now I have a one car with additional space up front. Of course it's cluttered up but I can still park one car in there.
Anyone ever see one of these? http://www.subaru.de/kundenservice/prospektarchiv/archiv-LSerie83.pdf
Anybody want one of these for their EA82? http://www.subaru.de/kundenservice/prospektarchiv/archiv-LSHubert88.pdf edit: I mean the seat rack.
I thought he was speaking Canadian!
Radio Replacement for 81 Subaru DL - HELP!
Hogsubie replied to Alexx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://usmb.net/gallery/albuo85/rehersal_155 Here's a good example of what I was trying to explain. Below the cutout for the radio is the "cubby" I was referring to. I enlarged the original radio opening to accomodate it. Moving it up allowed for a little more backspacing to allow a modern (deeper) stereo deck to fit flush. I also enlarged the lower opening and cut out the square with the power mirror toggle. I then fabricated a face plateto cover the now too wide opening. It looked a little ghetto, but the dash was pretty grungy to begin with. Using the faceplate allowed me to center the stereo as well. If I would have tried to install the radio in the factory location, I would not have been able to use the ashtray (gum wrappers-not ashes) because the modern deck is much wider than the old radio. -
The second link is the 81 DL dash but they cut off the portion I was talking about. The first link shows the portion but it doesn't look the same because the factory has already cut it out in order to accomodate the cassette.This picture shows the accessory square w/the hole that is to the right of the "cubby" but they did not remove the square like I did. I'm kind of surprised that is the factory solution. Looks kind of crappy to me. http://usmb.net/gallery/album72/1980_acc_c?full=1 -
The little cubby thing is the small slot to hold cassettes or other miscellaneous items. The radio I installed was an in-dash Pioneer CD player. -
I had an 81 DL and it had an old aftermarket shaft style radio. I replaced it with a single din cd/stereo. What I did was carfully cut out the portion with the holes for the shafts and I slid little cubby thing in the new hole. Where the little cubby came out, I cut all the way across, including the accessary square (I think the power mirror toggle went there-not sure though). Then I took some thin gauge aluminum and cut a whole sized for the stereo and then large enough to overlap where I made the second hole. I used sheet metal screws to attach it from the front. Now behind the console I used all the factory support brackets but I flattened them with a 3lb. sledge and then reshaped them as needed. Sorry I don't have pics or anything, I've since sold the car. If you want further clarification, just let me know. -
I kinda thought that too but the front end/headlights look too flat. That's why I think Fiat.
No, that's either a Fiat or some other euro-crap econo box.
