Renée96
Location
Tahoe
Renée96's Achievements
Member (2/11)
10
I have AC questions. I've read many many threads on here about AC troubleshooting, and to make a long story short, I'm starting to suspect there is nothing wrong with my system at all.... but I'll give you the full story anyway and see if anyone has any input. So for the few years I've had my 96 OB wagon, whenever I've used the AC, the compressor always seems to be kicking on and off every 10-20 seconds or so. I always assumed that was just how the system was designed, and there wasn't enough damping of the controls, resulting in the noticeable cycling. Whenever the compressor was on, the air always blew sufficiently cool. Here's where my problems start: a friend noticed this the other day and said it's not supposed to do that, you must be low on refrigerant, get a can and the cheap gauge/hose from the local store and you'll be golden. I thought, wow, all this time I thought this was normal, but I guess not... so I got the can and cheap gauge and started adding some r134a to the system. And yes, I realize now that I shouldn't have proceeded in this manner, AC systems are complicated and best left to a pro, etc. It was around 70-75F yesterday, and the low side was initially at around 25 psi, with the compressor running, AC on high, etc. I didn't measure the air temp at the vents before I started. I bumped the low pressure reading up to about 30 psi, and I expected the air coming out to be a little colder, but it wasn't... but the compressor did stop cycling on and off, so I thought I was in good shape. I checked it again an hour later though, and this time it was still cycling on and off again. This time I took the temp at the vents, it was around 48-50F. Also, I checked that there were no bubbles in the sight glass when compressor's on, when it turns off, the bubbles show up but disappear right away. At this point I realized that I had somehow hit the re-circ button on the dash, so it was pulling inside air. Once I changed this to outside air, the cycling stopped, and the compressor runs continuously. If I switch it to inside air, it starts cycling. Either way, the air coming out of the vents is roughly 48-50F. Does it sound to everyone like my system is functioning properly? I'm guessing that the refrigerant *might* have been slightly low to begin with, and adding some might have slightly helped, since the AC doesn't cycle on and off if it's switched to outside air... but to be honest, it may have done that anyway, as I almost never use the AC without having the re-circulate button depressed. Thanks for reading my novel. Any input is appreciated.
I'm not Renee, but we used this thread to help pull her engine recently, to do the clutch and fix the "oil separator plate" which was leaking. I wanted to add some things that I found helpful: 1. You can remove the radiator, fans, and reservoir as one unit. 2. The thermostat housing does not need to be removed; just pull the hose off. 3. Don't worry about disconnecting the O2 sensor- just stack some blocks of wood under the exhaust or put a jackstand there. It'll stay right where you need it. 4. The spark plug wires can stay intact. Now some other thoughts: - the trick with the hood prop is cool. Very useful. - we replaced the rear main seal... even though it wasn't leaking. Once it came out, there wasn't even any oil on the inside of it. Is this seal redundant? Maybe that's why it never fails. - we replaced the plastic oil separator plate, which was leaking like a sieve. The one different loctited bolt the dealer gave us went where the arrow on the separator plate is. - lifting the engine a bit with the tranny attached, then putting a jackstand under the tranny before pulling the engine worked very well for getting the engine in and out. In fact, this was the easiest engine re-install I've ever done. Maybe we were very lucky, but it literally slipped back onto the tranny input shaft in something like 30 seconds, once we got the lower engine-to-tranny mounting studs in place. It was crazy how easy it was. - Subaru has done a very very good job of making these things easy to work on. Other than the exhaust manifolds, lower radiator hose, radiator fan plugs, and of course the two engine mount bolts, EVERY bolt could be undone from above the engine. And those that had to be worked on from underneath were still very accessible. For this reason alone, I'd rather pull the engine than pull the tranny. The lower starter nut was a little difficult, but just a little. I can't stress this enough... this car is much easier to work on than others. They actually seem to have considered wrench and hand placement when designing it. Also, the engine is so light (even with the oil left in) that we could shift it back and forth to get the engine mounts lined up without even having the engine hoist connected. Much easier than the Toyota diesel I recently did. Of course, it's a small engine, so no surprise there, but still, it was very easy to manage. The pilot bearing in the flywheel is great- much better than in the end of the crank like many other cars. So anyway, there you have it. Thanks for the helpful thread.
Sorry for the implied confusion, I said vibe damper rather than crank pulley because that's how the mechanic referred to it, and I had just gotten off the phone with him. And Nipper, I appreciate your internet diagnosis efforts greatly. My main intent was to get some unbiased advice on here so I wouldn't have to take it blindly into a shop to get screwed. Or, so I could see if I could fix it myself if it is something simple. In this case, I definitely could have fixed this myself if I was at home... but being in the next town over with no tools or place to work on it, I'm okay with paying the shop to do the work. Oh, to answer your question, the only work done on the engine recently was the timing belt job, which was a few months and a few thousand miles ago. Thanks again for the help, and I'll post again once the job is done and it's certain that it was the pulley that was the problem.
The shop says it's the vibration damper. They ordered a new one, and it should be here in a couple hours. I just read a whole lot about the vibration dampers, and it sounds like some people have driven with theirs wobbling for thousands of miles, while others have had theirs fall off- mutiple times! Mine was only making the noise for at most 30 miles, but probably more like a 1/4 mile... even with the stereo on, I probably would have heard it if it started making the noise while I was driving earlier in the day. Anyway, I really hope that's all this is.
Emily: Does the pulley work loose, resulting in crank walk? Would I be able to tell if it's loose by yanking on it by hand? tcspeer: Nope, didn't specifically check any of the belts for tightness, unfortunately. I hope this all isn't a result of the timing belt change. The shop we took it to has TONS of experience on Subies (as do many shops around here of course) so I'd be really surprised if he didn't know about the greater torque required on the crank pulley. We'll see what the shop it's at right now says though...
Ummm... well... the oil should have been checked a little more regularly, but usually it doesn't get below the "low" mark between the normal 3k oil changes. But, on a couple occasions, the lifter noise seemed like it was getting louder than usual, and it turns out the oil wasn't even registering on the dipstick. I know, that's pretty bad, but it happened... Anyway, the first time was probably 10k miles ago, and the most recent time was a couple thousand miles ago. The whole time though, the engine always ran great and almost always gets about 26 mpg. After the recent timing belt change and tuneup, the mechanic reported the engine to be running great, other than the aforementioned oil leak of course. As for the overall noise of the engine, I thought it was pretty quiet other than the strange knock (maybe my camera is really really good?!). When inside the car, you can barely even tell it's running. Thanks again for your help, I really appreciate it.
Here's another video. I don't know if the wobble will show or not due to the video quality. I tried to get a few different angles of it... and at the end, I tried to see if it would record the sound louder as heard through the dipstick tube, but I don't think it worked. ANyway, let me know what you think, and thanks again for all the help! Click here to watch subie-wobble-pulley
Here's the video clip: Upload at Putfile Click here to watch subie-noise As for the oil loss, I'm pretty sure it's coming from the rear main seal. There doesn't seem to be any oil coming from the front of the engine at all. And, the leak has been there since we got the car, and we've put around 15k on it. If the pulley was loose, wouldn't I feel some play in it if I pulled/pushed on it?
The engine/car has about 150k miles on it. So I started it up this morning and pulled the plug wires one by one... and there was no difference in the sound (other than due to the rpm change). When I first started it, I almost thought the sound was gone, but then after a minute or so it got louder... which wouldn't indicate piston slap, right? Also, it looked like the main pulley off the crank was wobbling a bit, and coincided with the knocking sound. When the engine is revved, the pulley visibly smooths out and so does the sound. I stopped the engine, and pushed and pulled on the pulley, and it seemed very firm and didn't move at all. Is it possible for the whole crank to move axially while the engine is running? I took a short mpeg clip with my camera, does anyone know a good free place to post the video so yalls can hear what it sounds like? Thanks!
'96 OBW with 2.2 engine. Engine always runs well, but has slightly noisy lifters, which quiet down at every oil change. Also has a rear main seal leak, so the engine has been run low on oil a couple times... never overheated or got any oil warning lights though (not that that means much). Anyway, I went to start the car today after it had been sitting for a few hours, and immediately noticed a knocking noise that I haven't heard before. It *might* have been there earlier in the day, but the radio was on so I wouldn't have heard it. I've never heard anything like this before though, so at most, it's only made this sound for maybe 30 miles or so. It was somewhat cold out (maybe 30-35F) so I thought I'd drive it down the block and see if the noise got quieter. It definitely got quieter when under load, but was still there. Power felt fine though. I pulled over and let it idle for a couple minutes, and then it seemed to get louder, as the engine warmed up more. I though maybe it had gotten low on oil again, so I pulled the dipstick with it running just to see if there was any oil on it at all (and there was) and I could hear the noise very noticeably louder from through the dipstick tube. With the dipstick in, it is a deeper, solid-sounding thunk/knock, but listening through the dipstick tube it is a bit sharper sounding. I ended up leaving it where it is and got a ride home. I've read a bunch about rod knocks now, and it certainly seems more like that than, say, piston slap. And I know it's not the lifters. I'm going to try and pull the plug wires one by one tomorrow and see what happens, but does anyone have any ideas about this for now? Wouldn't a rod knock get progressively louder, and not just show up all of a sudden one day? Also, wouldn't a rod knock get louder with increasing engine rpm and load? Thanks in advance for any help!
Well, I got the car back tonight and the mechanic wasn't actually able to find anything flat out wrong with the engine. They did an exhaust analysis on it (I think that's what he said) and didn't any traces of telltale chemicals which would indicate a headgasket problem, so he felt very confident that that was not the problem. The only thing he could say was that the passenger side real cam plug seal was leaking, and that the oil separator plate was leaking- although I still don't see how he could know that without pulling the engine or trans. Anyway, after paying him for an hour of diagnostics time, from which couldn't find anything wrong other than oil leaks, I decided it should be okay to drive the 15 miles over the hill and take the car to my normal mechanic down the street from my house. My local mechanic will tell me exactly what the problem is, how serious it is, if I can do the repairs myself, risks of not repairing, etc. Due to money shortages, I can live with small oil leaks if that's all it is. The mechanic I got it back from could only think that there was condensation or water or something in the exhaust, which created the white "smoke" (vapor?) That might make sense, since I did have to plow through some fairly deep, wet snow to get out of the neighborhood yesterday, although I drove it about 30 highway miles before the whole smell/smoke thing started.
