Everything posted by 95 super subbie
i have put a set of 86 subaru station wagon rims the 8 spoked white rims on my 91 loyale station wagon i re painted the rims white and there look great on the loyale with a set of 185/75/13 diggers this makes the loyale look a lot meaner alot more aggesive with these rims
my twin brother has a 91 leagcy that he bought wreck from the junk yard it was aready fixed beside the plastic inner fenders well for 600$ with only 65,000 orignal miles,you cant go wrong there its only 2wd later on in the year he went though a chain linked fence poped both turn signal out and busted one so he order a new 91 leagcy turn sigal, it was not right. we knew it had a new front end fender, hood, bumber, headlight, grill ect.... but it has the front end from a 92-94 legacy on a 91 legacy car the whole font end of 91-older will fit 92-94 legacy are interchangable but it has to be the whole front end,fenders,headlight,turnsignal,grill,hood front bumper
i got a 95 leagcy awd that the shifter is very loose! if i push it to the right its kind of springy but nothing to the left toward 1 and 2 its not springy and if its in gear i can move it all around like somthing is loose i replaced a clutch awhile ago i put the shifter and linkage back together is the somthing i did not get tight or is it normal? 95 subaru leagcy awd, the "super subbie" 91 subaru loyale awd the "super subbie station wagon"
i got a 91 loyale 4wd that i bought for 50$ not a road legal car when i first start it it holds about 45 pounds oil pressue then it drops down to 5 pounds of oil pressue while idling, but if i push the gas down and hold it it about 2500-3000 grand it goes above 45 pounds of oil pressue is there anything i should worry about 95 legacy awd 5 speed 91 loyales tation wagon four wheel drive
i got my 95 legacy from the junk yard it was reared ended, i fixed all of that. it had 96,000 when i got it less then 3,000 the clutch went just a couple hundred miles from 100,000 then it went bad, man was i pied off, just bought the car work on for about a month and the clutch goes, i think the idiot that had it should not buy another standard car ps is the clutch life less on a awd subaru then a front wheel drive proud owner of my 1995 super subbie legacy awd and the 1991 soob wagon four wheel drive yeah its a field car
who in tioga county pa or near
so how do like the subaru brat that is my name is earl, the red ehite and blue
they would proboly would be around the same year outback i stuck 20$ drivinh lights on my leagcy
its a 50$ car
i jumped the subaru loyale in my yard, there this big dip in the yard i was going about 27-31mph when i hit it, it was as fast as i could get it going the loyale to go and then i slamed my head of the roof which gave me a major headache i was not whereing a seatbelt at the time. i think next time i get the loyale to play i will wear a helmet has anybody ealse do this while offroading
i have a 4wd loyale wagon that is automatic and man this thing is fun to play in the snow with. the little 165 tires had good tread but it is just too small i got a set of the old white spoked rims off a gl and found 185/75/13 diggers to put on them now the sub wagon looks mean and how do i get a little picture up by my user name
91 loyale auto dont have any power, i picked it up of a retired farmer who used to drive it from one barn to the other one 1/4 up a dirt road it was sitting for a 1 year i put new plugs in it its just a field beater what esle could cause no power i drives aroud the yard but it dont like to go up hills
i have a 95 legacy that i put foglights(drivinglights) that i boughts from walmart for 21.00$ their about 4' around and they make it alot easier to see at night and make the car look better
junkyard junkyards junkyards
go with the cooper weather master st2we sell a lot at the gas station that i work at
what i did is used a wire brush hook up to a drill and clean it all up then put a new coat of black paint some friends find it hard to that it is not new. it makes the skid pan look alot better
i put it on my 95 legacy their is a bracket with 6 holes, 3 pair, the middle set lined up with the back holes on the skid pan you only have two drill to mount the front i used 4 new bolts and nuts it makes it easy i would recommend clean the skid pan with a wire brush on a drill and spay paint it it looks like it is band new
i have a 95 legacy is their any other subaru with a skid protector for the rear that i could make it work on my car
i have a 95 legacy sedan 5 speed that i always wanted to a put skid pan on it and did not want a new one, so i have a junk 91 loyale 4wd that had a skid pan on it. I just took the 4 bolts out then i took a wire brush wheel on a drill to clean all the oil and paint off it then repainted it. I only had to drill two holes for the front of the skid on the bootum of the rad support. their was already holes in the back that lined up with the holes in the back of the skid pan it really looks great it looks like it is new! note only the 4wd loyale has skid pans
