color-blind
Everything posted by color-blind
Here is a new website you all may like. http://development.axis-creative.com/dev/spx/sub/index.asp
There is a service bulletin on clutch judder #03-51-02F. Basically it is replacement of the clutch disc, cover, release bearing and a new flywheel. You have too many miles to claim warranty. While the clutch is out be sure to have the rear separator plate inspected. If it is the old plastic type have the new aluminum plate installed. Good luck
Egr problems are the most fun so here we go. Remvoe the egr valve and make sure that all the passages are clear. In addition make sure the metal tube is cleared out. The most common problem is the bpt valve and second clogged passages. If these repairs are not the fix you need to look at the map sensor. It monitors vacuum thus it can tell if the egr is working. If the egr is not working the map sensor tells the computer to set the egr code. There is a small filter inline on the map sensor hose it is common to fail be sure to replace it if you believe the map sensor is your problem. As to the knock sensor code; simply replace the knock sensor. Good luck.
Ok, sounds like you have two problems. First remove the exhaust y-pipe. Inspect the guides on #3 cylinder. If they have dropped down you will need to replace the cylinder heads. For the stalling I would suspect a failing air mass meter. Yet you need to go after the mis-fire codes first. Just to make sure the mis-fire is not causing other problems.
The blower resisitor has failed. When you go to speed 4 it by-passes the resistor. Yet the blower resistor failed for a reason. This is usually caused by a failing heater blower motor drawing too many amps. I would replace the resistor and the blower motor with oe parts. You could try just the resistor, yet don't be surprised if it fails again within a month or so. Good luck
Code P0304
color-blind replied to JBRIII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Ignore the converter code for now. First you need to determine the misfire code. I would suspect plug wires or a failing valve/guide. It is easiest and cheapest to simply replace #4 plug wire. If you have access to a leak-down tester you should check #4 cylinder. As far as the converter is concerned it is common for failure. Yet you have more pressing concerns with the mis-fire.
