moosens
100
Everything posted by moosens
We need a cross section of the rubber to give us an idea of wether or not a current catalog item will work,or if we need to special order. PRP's catalog has nice cross section views of their stock. Datsuns,maybe!! The Subes and 'suns share a few items! Cross your fingers everybody. Whoa!!! I might have the cross sections right here in my FPM!! Later on I'll start a dedicated Sealing and Weatherstripping Parts Thread. For now,the info you asked for......Stage II '77-79 rear sedan windshield gasket p/n = 6650 02660 and according to the FPM does NOT interchange with Stage I cars from '72-77.That p/n is 6650 02240 GF Hardtop = 6650 02410 for Stage I and 6650 02700 for Stage II FE and DL Coupe = 6650 02280 for Stage I and 6650 02680 for Stage II
So,what about Windshield GLASS for our oldies?
moosens replied to moosens's topic in Historic Subaru Forum: 50's thru 70's
Thanks,but don't bother.They aren't about to send glass over for us now.We have a board member who works at SOA.He's also checking on some old stock,but so far has come up fairly empty. Looks we're going to need some produced unless some distributor or shop still has a batch. -
Yes,I agree with Todd. Strip everything out of that interior.You're probably going to find some stuff you don't like behind the dash too.All needs to be dealt with.And besides,you'll be that much more ahead of the game if it does become a parts car. I can't emphasize this enough,keep everything labeld and organized.Although this is a really simple car,as time goes by even the simplest of items can perplex your day. You at least have your head on your shoulders about it,I can see that.thumbs up Drop the gas tank,I guess you're doing that already.Get the bumpers off,splash pans,exhaust chunks (asuming it's like most sitting Subarus),etc. If the ceiling liner is good,don't touch it. Please get it as best as you can and take some more pictures.Not sure if WagonsOnly has looked in on this but he/we should have some floor sections from a '75 4WD wagon that might help. Mosty you need it stiff,solid,and trustworthy.Replacing with the pressed steel pieces it was originally assembled with is most likely not going to happen.But if you ask me if I care......no way! You'll have that body style rolling and if somebody needs to be picky about it call me and I'll kick their :cool: And,if need be,I thnik you've got an excellent shot at finding another.There were TONS of those as they were very popular with ladies,so they're still out there,albeit a handfull of them.
Brake pad replacement question
moosens replied to MachineAgeVictim's topic in Historic Subaru Forum: 50's thru 70's
Jeff,Haven't heard from you.I sent emails,or PM's I think too.Windshield gaskets are shipping.Email or PM me,please.I replied to the Paypal payment address from your initial payment.That much I'm sure of.Talk to you soon, Paul Oh,and try some WD-40 or stronger,inside the dust boot around the piston.Let it sit facing upward for a bit,then go try it.. Seriously nice rebuilts on eBay.Randy "Mofoco" has them.Right around $49 I think.THey'll show up cheaper once in awhile,but only after you already bought them. -
Hey Jim,good to see you around the old country here. OK,who's the person with the 360? I can't resist asking.:-p
86 carbed swap into a 88 SPFI??
moosens replied to JLDT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
OK,I've got you now. Yes,you can drop the carb'd engine's longblock into the SPFI car with one minor issue.When you disconnect the AIS piping from the exhaust port of the carb'd model you'll need to cover the holes with some metal shim stock,or whatever you have that'll cover those holes. Intake mainifold gaskets are the same for carb/SPFI.Be slow and careful with those intake manifold bolts.Keep in mind that most of us have snapped one of those bolts.Heli-coil to the rescue!!:-p ...or Time-sert. Good luck with it. -
sorry,I need to re-read that post...... -
Can the VW Bug gasket be used there?Todd (subaru3) would probably know. You can repair that floor.Won't be easy,but it doesn't have to be perfect either.We'll all try to help you out with pics,or scans of FSM's or FPM's.You can at least get the important points down,if there are any for that area you're working on.Were the seat mounting points still there?If the rot was just sheetmetal floor then you're not doing so bad.I looked at the pics very quickly before. We're all wanting reproduction parts,but I don't see that happening much at all.:-\
Can you find out how many are left? -
Coupe with FE Badging in Jessup, MD
moosens replied to Seahag1978's topic in Historic Subaru Forum: 50's thru 70's
Well,I just talked to some s.o.b. there. Good luck dealing with these holes.We'll see what happens tomorrow.Maybe this jerk was just the weekend loser yard God. Has anyone seen the underside of this car? It's a four hour drive plus more for my partner.We'd appreciate and compensate (if needed) for a quick inspection,if possible. If you can make it by the Jessup location at 8125 Washington Blvd. zipcode 21074 and call me from there please PM for a phone number. Thanks! Paul -
Standing aside from EJ conversion tactics,I can tell you that you have the three 10mm bolts on top and then from underside in the far wings you have I believe one 10mm bolt on each end. Take down the panels under the steering wheel first and disconnect the duct. Disconnect the radio antenea,speedo cable from underside of dash(just pull it forward out of the socket).You'll also have a vacuum line in the form of a thin plastic hose with rubber hose connecting to it.And you need to disconnect the slider cable for the heat-to-cool lever all the way down at the heater box.Just yank up on the clip there,you'll see.Then you just take the loop of end of the cable off the cock lever. Been a while for me,but I did it and got everything working again,so you can too. I did a heater core swap,that's how I got my experience.And I took many out while parting way too many cars.While you have the dash out I think you'd be foolish not to inspect the heater core for corrosion,and replace it now if need be.Also check the blower fan and the resistor pack.And make sure the heater core cock is not corroded too.No better time to clean the ducts out too. Good luck with it.
It was pretty funny hearing them in the background when I called.Whoever answered had to put the phone down and take a few steps to yell out back,etc. You can hear them saying "Yeah,it was on the internet!!!",and "Subaru people" several times. You would think that in this day and age we'd see EVERY yard set anything unusual aside for a few days and check the internet for clubs or activity to see if they can make more than scrap money from it.
OK,thanks. But let's see exactly where these existing ones are.I search eBay often enough.There's one on there now,way overpriced.Other than that one I can't recall many for '72-79's at all.I checked "Completed Items" and got nothing. Coupes from '72-up AND GF Hardtops from '75-up: SOA001910 blue tint (Supercede number) Wagon,Sedans,and BRAT from '72-up: 665001740 clear,and 665001980 blue tint Yes,we know the BRAT started in '77 :cool: Whoo hoo! I have a 56k mile GF windshield that should fit my '73 Coupe!! -
I found a 76 DL sedan today! Pics added
moosens replied to Subieguy's topic in Historic Subaru Forum: 50's thru 70's
Suba freakin licious!!!!!!!!!!! You go boy! Get yourself a Factory Service Manual yet? -
Yes,it is. -
Chiller Theater scary!!!!!! that blue in the shiny grill ornament.......like a twinkle of life from a zombie's eye.Mossy bumper,Creature from the Black Lagoon.:-p
Been some inquiries lately. Can we get an account of what we know of in stocks of dealers,shop owners,enthusiasts??????????? Gotta belive the numbers will fall short of demand. Personally,I see myself needing/wanting badly a second windshield for my '73 GL Coupe.And a newly produced piece for the '78 4WD Wagon would be nice.I'd accept a good used w/s for the '73 as long as it was taken from a '72-77 Stage I Coupe body recently or stored upright.I sure don't want to find a bad fit from flattening or stressing.Feel the same way about your car? Think we should look into new production of front windshield glass? I couldn't expect a Coupe production,but the wagon,sedan,hardtop group shares the same mold!! Oh,doesn't the BRAT use the same one too?My manuals are boxed up.Can't check that.
Hey,I've got a guy interested.Can we get some more details.I'll send a PM now. -
Hey uhh,certainly not wedging Matt out,but why don't we see if we're close to 25 cars first?We have untill the end of April,right?I know I'm most likely going to register at least two,maybe the wife's car too.That's 1/8th almost.Andrew,you've got plenty of cars and cash....could be six right there.For me,it might get my friend Chris to finally go to the show.He can drive my third car. Don't forget,it's a lousy $5 to add a third car.Consider it the tent fee. $15 first car,add $10 for second car,add $5 more for third car. Andrew and Paul- 6 Connie- 1 Matt-2 Dave hocrest-1 Ben-1 backwoodsyboy- 1 nkx Jon- 1 Nick goobaroo- 1 That's 14 fairly definite people and a handful of those who might make it.And it's only January. We could easily get the rest by April.
Well,is it on its way to Walden or what????????
