moosens
Everything posted by moosens
  1. Wow,that's a nice score.Any others around? Something with a really hard glossy coat.I guess an epoxy paint thinned out some.I doubt using it straight would be easy.I think it'll be a lot easier to spread around thinned out.And you'll avoid creating a resistance around the drain holes...just my thought.The reason my Zeibart'd '78 is still around is because they did the drain holes right.Too many cars held water,well,you know that,who am I talking to here?
  2. Yeah,they're all worth more to us because we're whacked out on Subaru,man. Seriously,my touring wagon cost $200 needing timing belts and an axle.That car has taken us on family vacations,gone off roading several times including the infamous nose in the air photo.. ...then it's helped move people,including myself,and still runs excellent even though my sister inlaw drives it. So,I'd say any SPFI wagon with dual range 4WD is worth the $500 or so. Hey,how about that one on eBay right now??Shooooey,boy,tell you what,that'd be for me if I had the green.Sccccccchhhhhhhhwwwwwweeeeeeeet!!!!!! There's been quite a few folks over the years that have commented favorably about the touring wagons of '89 and '90....because they really are a nice car for a boxy Subaru of the late 80's.
  3. Really not that hard.Now go get that '75 wagon!!
  4. If you have $300 and the time and place to keep it you CAN'T go wrong. Enjoy life,you're going to die someday.Cheers!
  5. I need the rocker dress trim,driver's side mirror,bumper guards (front of course),also need the little seem covers on the rain gutter trim-or even the trim too if it's really really nice or any one piece even if the set is not complete.You know how to remove that without damaging it,right?Real carefully. I'd like to have as much 1400 engine/exhaust parts as as still good and worth keeping-provided you don't snag them up.I'm still not sure that my '73 will be a 1400,but I should at least attempt to go for a true resto before upgrading. Also could use the antenea if it's 100%. Talk to you soon.
  6. elad,hang tight,the '76 grill will get to you soon,I swear.
  7. Standard Operating Procedure all the way.You HAVE to punch it to get the pressure to fill that last lifter in the train.At least all my EA82's were that way.
  8. Well,actually it all works but it has that 6speed double kick feel in the lower gear exchange.The 2nd-to-3rd gearshift is smooth and it's only one shift,not the double kick like the 1-to-2 exchange does. Downshifting is now much beter and I think the big-late kickdown when approaching a full stop is just about gone.At least I didn't notice it the last times I drove it. No reason to feel bad.The car drives really great.Just got back from Naugatuck,hits 75+ on the highway.Feel good about that,girl!! No more smoking car!!!!Feel good about that too!! I'll give it my best shot!,thanks!! Bottom line:Car is a pleasure to drive.Being 24 years old (the car) I should be thankful it delivers every bit of efficiency that it does.And for the amount of cash spent from the eBay purchase to date is so little when you consider what other cars have cost me.
  9. Bump....my son is asking all the time.....at least I can drop the gas on the plastic and bring a lunch to this,so anytime you guys want to get together....just kicking it around again. Some Saturday,before mid November for sure. Kick in your best date.Let's hope we get a good little group,what happens,happens.I know I'll be there,brownbag and all.
  10. Diaphram rod,as my FSM shows it,stayed in,same for the O-ring. That's right Pat,it must be the remainder because I sure wasn't about to do it the 100% correct way at that time.I think I'm going to just do another Sea Foam douche and see how that does.Yes,it does look like the color of what came out with the flush. So far I'm not inclined to do the pan drop/filter swap/band adjust If the weather stays fair I might get to that but right now time is tough to gather in quantity. I might take it for a power flush,but again,time and money are restricting.As long as it goes I tend to not stop and make more work for myself. Thanks for the response. Added:I just got back from a quick ride and it runs great but does still have the "6 speed" feel in the lower gear exchange. Dipstick shows a healthy,semi-clear blue fluid.That crap is sitting on the bottom,somewhat.I know it'll circulate,but probably holding up the valves...right Pat?Almost makes me want to make the time or pay the man to drop that pan,clean the valves,heck I already have a fresh screen and gasket...:-\
  11. 1982 GLF coupe. Previously changed tranny fluid after using Sea Foam's tranny cleanser product just a few weeks ago,before the wrath of rain.Anyhow,I added B & M Trick Shift,just because it helped me once before.The stuff is light blue in color.Keep that in mind.Then this week I noticed I was down a little fluid so I added a quart of red tranny fluid.So now the color should be mostly bluish,probably slightly purple,right? Well,when I removed the modulator some brownish fluid came out of the tranny.Is this typical,because the diaphram when ruptured allows oil in? Or do you think I should flush it again because what I saw was what didn't make it out the first time?I know that usually when you pull the hose off the modulator you'll see some oil if it was bad.Is this just that same oil or do you think it's sediment that finally broke loose or was just missed by the first cleaner? Only about 1/2 cup of fluid came out. Good news is that the modulator did make a difference in shifting as it should.I'll have to check tomorrow to see if it's not going to smoke anymore.It shouldn't.
  12. Same opinion here with a slight edge to the simplicity of the EA71. Personal opinion is that there should be an EA71 with SPFI available right now.But that ain't happenin'.
  13. Nice idea!! Who'd going to crawl under the next Acura CL they see?Regardless,I'm sure something can be done.All it takes it time and money.
  14. Hmmmmmm.....anyone got $65/$75 bucks? I'd love to do that,but we'll have to see. If there's enough interest I'll find a way to make it happen..or give it my best shot.I know I can do a better job of navigating after my first experience where I was just too road doped to think,calculate,and communicate as quickly as needed. My son really want to hit PB for what we're used to,diner breakfast,trail riding,etc.We'll definitely head down for a daytime/Saturday run so if folks want to hook up speak up in this thread. Let's see if there's enough folks interested in the TSD too!!Twist my arm.
  15. Might be able to do this before the PA yard run since it's a one day-all day event with no chance of spending money I don't have at junkyards. I think within the next three weeks is possible.
  16. October is breezing by....same for my paycheck...still no definite date in sight for me.I'm hoping for a small miracle but most likely I won't be able to swing this trip for at least 3 weeks.
  17. I think you should have asked if anyone LOCAL wants to go....because we ALL "want" to go. Have fun,show pics.
  18. Indeed!! Drooled all over the keyboard. GO FOR IT!!!!
  19. Never heard of anyone pulling this off yet. Personal dream for me would be an EA71 with a D/R 5spd....and SPFI. Be sure to let us know if you stuff a D/R 5spd into that '77.You'll be my hero.
  20. Air injector fittings are different,but can be re-drilled and tapped if swapping to the later issue. I can scan the page from my FPM for the early version for you if you need it.
  21. Same here!!! I've got the Toyo's on my '89 and '96 and they are excellent in the rain.My friend manages a Town Fair Tire location. I take the same route when buying new-get the high end-don't skimp out especially if you carry people all the time like I do. Toyo Spectrum,I believe they are called. You can always get even better,but for the money these are great.I'm looking at getting them for my coupe when I actually have cash...Cash price with all the goodies thown in is around $73 per tire.That's full replacement for road hazard,free flat repair,free rotaion,etc...for the life of the tires.
  22. How much for a bag of the thought producer? Kind of cute.Needs a nose job.
  23. That's Todd,a.k.a. Subaru3,whose got the bid on it.He'll tell us all about it.
