moosens
100
Everything posted by moosens
Subaru Part Numbers for 2nd Gen Brat Tailgate
moosens replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Best of luck on those screws. -
Miracle!!!! Ok I’ve found my way here , I think. -
It’s on face dook now. Take a quick look. Just don’t let yourself be sucked into the vacuum .... hahaha https://m.facebook.com/groups/1603473039901513?view=permalink&id=2838645453050926 -
And again , my apologies for being forgetful and slow as mud sometimes. Hoping to be at my storage today and I’ll check my miscellaneous nuts n bolts boxes for those. -
Wish this board had a photo reduction gizmo so I could easily post a pic. But enough crying here we go ... 0411 06160 is the p/n for the screw which a quantity of 8 are required and showing as being used in the tailgate hinge. Also requires 8 lock washers with them. Washer p/n 0340 06000. -
EA81 Won't Idle When Warm
moosens replied to GLwagon1984's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You need part numbers ? I tend to forget sometimes but I do have my factory parts manuals/catalogs at home currently. Let me know which ones you need , which year vehicle and model , the usual stuff. -
Kits are out there too. Be sure to read up on what I was indicating to you. I did not go into detail but assumed you would check and adjust the float. From your description I would say remove the carb and soak it, do it properly. And when you’re all done check and adjust the float. You’re likely going to remove the top cover more than once and the adjustment can be frustrating so go slow and follow the manual. Your carb kit will almost certainly have an instruction sheet which helps a lot. Good luck. -
86 gl10 front brake caliper
moosens replied to Creelux's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah I used to use duckbill pliers. Wasn’t easy but lead to success! -
It was idling well previously and nobody else adjusted the screw. Check the float bowl and clean the needle and float chamber well. The real way is to remove the carb and soak it , blow it out , etc. But if you just take the float chamber cover off and work from there you’ll likely be fine. Service manuals are out there online or hard copies. -
Goes on your socket extension https://shop.advanceautoparts.com/p/lisle-disc-brake-piston-tool-28600/25961363-p?product_channel=local&store=7676&adtype=pla&product_channel=local&store_code=7676&gclid=EAIaIQobChMI3f-y8-Xj7wIVypyzCh0bPAmCEAQYAiABEgKwmfD_BwE&gclsrc=aw.ds -
76? Subaru in junkyard
moosens replied to charles_thomas's topic in Historic Subaru Forum: 50's thru 70's
The PRP gasket no. WCR-288 is the one that fits 1972-79 cars Except Coupe. Also fits the Brat 1977-1981. For the Coupe there is a different part number. And the upper ears are a bit taller. That given , you can stretch and I think a small relief cut in each ear and make the standard gasket work for those cars. Not sure what you’ve come across. There are newer alternatives so maybe you’re seeing something someone came up with. -
Usual brain fog when I walked past my manuals. I’ll get that p/n for you next chance I get. Parts manuals don’t show up as much as Service manuals but they’re out there. -
Back about 1999/2000 I spent a good amount of time searching “elder” dealerships to inquire about any possible old stock for purchase and heard just too many heartbreaking stories about old stock being tossed. Literally missed large containers , before all these smaller containers were in the storage market and only huge containers existed or so it seemed , by as close as three weeks. Other dealers had purged months or years previous. That’s the life cycle. -
Parts catalogs getting that hard to find ? But just because we can dig out old factory parts catalogs doesn’t mean they still have the parts. Probably have those screws in my miscellaneous nut-n-bolt containers. I’ll post back later or tomorrow. -
You got a new windshield installed for around $250 ? Twice ? That’s amazing. I mean they are an easy install but still for the glass , gasket , and labor that’s a deal and then some. -
Install those dry. Smaller particle cork gasket is better but at this point you may just be happy with whatever comes. Soon I’ll be listing stuff for sale again including gasket sets. I also have just valve/rocker cover gaskets when I can dig them out. You’ll be fine for now. Payen is a good name from back in the day. Those kits still show up.
Yeah looking closer appears to be sedan not hardtop. -
second generation Brat Shock absorber
moosens replied to Marc556's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Be ahead of the game for the next production run. Somebody at the mfg. has to be aware of demand. This vehicle falls into a certain category. Classic not going away anytime soon.
