Everything posted by moosens
'85 BRAT, will install new clutch plate, what else?
Excellent follow ups after my previous post. All stuff my feeble mind dropped. And like Benny mentioned since you have it out , drop the oil pan and be careful with that sump stem. It’ll crack if you wrestle it too much. Can tap it downward as I recall. Use wood or plastic as your drift/punch if possible. Replace O-ring on top of stem part no. 8069 14020 Rear of crank has an O-ring too. P/N 41396 7000 Front main is 8067 38070 for the 1800. 38x59x9 is the size.
Paint Color suggestions for respray 81 Brat
Yeah , that sounds nice. And our man on the east coast did just that and also the go-kart to match. Doug in NH. Same feelings about the two tone and connotations. It’s sounds pretty cool though , the way you laid it out. I’d try it in a photo program first though.
Unquestionably replace the rear main seal. I can’t recall the pilot bearing but be sure that’s a fresh one. Fresh pressure plate and cleaned up flywheel.
Looking like the door is closing. Thanks
Friendly reminder. Easy to reach like Rockaway Beach. Seriously , others have made the drive. Give it some consideration while there may still be parts you’d want/need but would rather see in person before buying , or would rather not pay outrageous shipping for. Hope you are all well and hope the fear hasn’t prevented you from coming here. All healthy , no issues within my family for virus etc. Just a few seconds off exit 35 of I-95 in Milford CT. Whats left ?? Top of my head ramble list ...fenders stage one and two both sides quantities vary. Engines EA71 first and second editions one complete , one a longblock ATK rebuild in crate for dealers , boxes of small item New Old Stock genuine factory parts , some wagon rear bench seats, front valance Brat and 4WD wagon , 4WD transmissions gen one Brat and wagon , a five speed FWD transmission , front A bar I think one is gen one and maybe even stage one , and the other is either gen two or late gen one. Also starters, alternators, new side molding , some new bumpers , more. Still willing to make a sweet deal on a big lot. Hope to see you soon.
Back up light switch
Good question , how much different would they be in the 80’s or even 90’s ? I may actually have that in new old stock but to dig it out would be a chore. And I should have one on a tranny. I have at least a couple of the single range on demand from 75-79 and gen one Brat. I should be back at storage this weekend. If you can’t find one let me know.
EA82 Sanity Check Question
And the coolant sitting in the exhaust is going to vaporize immediately. As above I’d just replace the intake gaskets and if FI that same mentioned O ring. At this cars age if you’ve never replaced the intake manifold gaskets it’s about time you did. Such a nice moment when you’ve done the intake , start it up , and no more problem. Worth the try. After a compression test. Hope your camper episode ends well. Cheers !
EA71 head studs
I just had my hands on a fist full of head bolts and lifter rods. Next time I’m at storage I’m pretty sure I set them in a spot I can easily see them. Let me know if you need any. These should be from an early EA71 1600 I will check length etc as I get back to them. I was in a rush and saw them as I was needing to be wrapping up. But they’re there if you need some.
BRAT/GL/Loyale replacement center wheel cover rings?
Cool , thanks. Notice the superseded part number. 15 years ago , seems like no freakin way that long , but so goes life.
Ok pardon my eyes. I zoomed in and they are both with inner and outer flanges.
I would have to say that the early version 7231 46000 is the type which can be placed on the wheel while wheel is mounted. And the other , 23146 GA030 has flanges on both inner and outer edges so it must be placed in the wheel before mounting.
Some basic centercap noise from the parts manuals. 1978 and previous get a bolt on cap. Some more heavy and sturdy than others. 1979 you get the smoothie as I call it with NO bolt but also NO seating ring. At storage I have the 1980 and 81 parts manuals but here I have an 82 and it shows two styles for each the steel and the flat spoke wheels. Also does NOT show a ring. My 1985 manual for the Loyale body has the ring. It’s p/n 23146 GA030. And that is for the flat spoked wheel. And then within a manual for the Brat and 2dr from 1985-88 that ring is part number 7231 46000 which is an older p/n The two are obviously different style when viewed. Hope that info helps someone.
If my brain can remember I’ll look in the parts manuals I have and figure that out. Assuming someone else doesn’t chime in with the answer. My first guess would be the later Loyale style may have changed. Did you own one of those too?
Coolant leak, but where?
moosens replied to mrfixiter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat’s the right side of the car. Never mind looking at it from any other angle. When describing issues and locations you should refer to it as you drive it. You don’t turn left if you turn towards the radiator bleeder screw. You say you want to do it right then get a radiator and new hoses. You won’t be able to service your existing radiator.
moosens replied to mrfixiter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes that radiator have the square head plug atop the unit on the right side ? Just this past week I saw a leak but it was so small I couldn’t locate it. Same area you mention and it’s a 2.2 I did the $3.79 bottle of radiator leak stop. It worked for now. I have a new radiator on standby but when I went to do the repair I couldn’t get it to leak or overheat. I never recommend the easy bottle “fix” but this was so minute maybe this was the right time to use it. When I fill those style I mentioned above I follow directions given to me by the folks who work on them all the time. Take the square head plug out and fill while running until there’s no more air in the system then of course put the plug back in. From there you should be able to consider your coolant system topped off.
Subaru Part Numbers for 2nd Gen Brat Tailgate
When you get them please post their size. I can see this being searched in archives down the road.
used parts from 1976-1978 Subaru 4WD wagons
Same
Oil Filter etc. reviews
moosens replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOpinion: support small business and not that creep. And John at Perkins told me those Wix they sell or used to sell are the same as made for SOA , that was a good 10-15 years ago. Not so sure about these new tiny blue filters. But I have those on my shelf from a case I bought. Using them up but for years now they just scare me somewhat.
Lol here’s what I dug out. https://m.facebook.com/photo.php?fbid=4072542319471479&id=100001472520427&set=p.4072542319471479&source=47&ref=m_notif¬if_t=feedback_reaction_generic Sorry about this. Looks like they want you to sign in or sign up.
It's a good day when...
moosens replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd with my buddy Joey Ramone. A memorable time. Patty Smith , yeah I get her and she lives not far from me, but I just don’t go that deep into the left. But thanks to them for standing up. Ok that was a different committee meeting.
- Subaru Part Numbers for 2nd Gen Brat Tailgate
It’s on face dook now. Take a quick look. Just don’t let yourself be sucked into the vacuum .... hahaha https://m.facebook.com/groups/1603473039901513?view=permalink&id=2838645453050926 - Subaru Part Numbers for 2nd Gen Brat Tailgate
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
