moosens
96
Everything posted by moosens
Make an offer. Look close there’s some parts most everyone needs sooner or later. Little bits , but having that box of misc. bits can make your day at the right moment. If you see similar items in different pictures those are additional and not repeat of the other pictures. Pics coming. 2mb at a time. Lol
In case you’re not aware I’m cleaning out massive amounts of parts and stuff from New Old Stock to great used hard to find parts. These days I’m sadly on face buke , but if you haven’t done that yet I commend you. But seriously it was easier to post there so that’s why I’ve stuck with it for now. The main three sites I go on for Vintage Subaru activity are: Classic 4x140 Old School Subaru Group and of course the Ultimate Subaru Cult - lol - sorry for that. The latest edition of this board is much better. Just have to shrink my photos for this board. So I’ll be posting here as I can. But to save time please see if you can check out my goods over on FB (gag). Best part about this board for us is that I’ll use the messenger here. But NOT face buke’s And you can always email me at moosens@yahoo.com Enjoy summer !
Found my FSM. Found a multi meter too. Have to make time now. Can relays click and seem good but actually be bad ? I know I can verify with my meter , but I’ll probably not have time for this car next 2-3 days. Also want to see if I can dig out any relays I may have snagged from parts cars and just switch it and see. At the pump the connector seems to have a slight burn/discoloration at one pin. It’s the lower left as you look into the connector. I’m pretty sure it was the black or black/red power source. It’s not a real obvious burn. But the other pins aren’t dirty like this one.
Thanks very much. i just noticed that the diagram I was viewing was for a 98 and not a 92. No module - as I should have already been convinced having torn through so many of these 90-94s already. The things I do when I get flustered. Should have looked twice or more at that diagram. i do have an FSM which I will surely dig out and get checking connections. I know the ECU can also get corrosion at the terminals so I’ll start there.
Tom , I already changed out the pump on this sedan so I know where the pump is. It’s in the trunk but you can access it from the back seat like I’m doing now. I’ve done several fuel pumps on EJ22 wagons and sedans. I’ve also torn down a few including removal of interior. But I’ve never noticed what the online schematic showed. It says there’s some sort of module under the center console. This car had sat longterm with a previous owner. And when we got it from the last owner ( young guy not good with cars but his friend eventually helped some) he had tried various remedies for what really amounted to lots of rust in the gas tank. So back when we got this car (couple of years at least now) I immediately changed the fuel pump. Ran great until this happened and now I’ve swapped in a new pump. Man I need to find my tester. This is a problem a guy with his own garage or even comfy place to work would have already fixed. I’m in a condo and my car is in a high traffic area so I’m trying to fix this without looking like I’m working on my car.
1978 Subaru 4WD wagon parts for sale
moosens replied to NLAParts's topic in Historic Subaru Forum: 50's thru 70's
Charlie , good luck. Same kind of situation here. -
It was a loose crank bolt apparently , which caused the key to flex badly. Breaking the old engine down and that crank bolt of nasty bad not wanting to come out. I want to salvage that oil pump as it was new not so long ago. Brute force and ignorance will soon prevail. But that didn’t cause the rather severe oil leak it had. Really not yet seeing where it was spewing from.
