moosens
    96
Everything posted by moosens
  1. And these are used parts. There’s a small package of front brake parts New.
  2. Great , having trouble with this 2mb deal. I’ll post pics a little later when I have time to deal with phone settings etc. Sorry about that. Hang in there.
  3. Make an offer. Look close there’s some parts most everyone needs sooner or later. Little bits , but having that box of misc. bits can make your day at the right moment. If you see similar items in different pictures those are additional and not repeat of the other pictures. Pics coming. 2mb at a time. Lol
  4. In case you’re not aware I’m cleaning out massive amounts of parts and stuff from New Old Stock to great used hard to find parts. These days I’m sadly on face buke , but if you haven’t done that yet I commend you. But seriously it was easier to post there so that’s why I’ve stuck with it for now. The main three sites I go on for Vintage Subaru activity are: Classic 4x140 Old School Subaru Group and of course the Ultimate Subaru Cult - lol - sorry for that. The latest edition of this board is much better. Just have to shrink my photos for this board. So I’ll be posting here as I can. But to save time please see if you can check out my goods over on FB (gag). Best part about this board for us is that I’ll use the messenger here. But NOT face buke’s And you can always email me at moosens@yahoo.com Enjoy summer !
  5. And as of today I still haven’t gotten to check the ECU connections. Thats up at the passenger side foot well , right ?
  6. Found my FSM. Found a multi meter too. Have to make time now. Can relays click and seem good but actually be bad ? I know I can verify with my meter , but I’ll probably not have time for this car next 2-3 days. Also want to see if I can dig out any relays I may have snagged from parts cars and just switch it and see. At the pump the connector seems to have a slight burn/discoloration at one pin. It’s the lower left as you look into the connector. I’m pretty sure it was the black or black/red power source. It’s not a real obvious burn. But the other pins aren’t dirty like this one.
  7. Thanks very much. i just noticed that the diagram I was viewing was for a 98 and not a 92. No module - as I should have already been convinced having torn through so many of these 90-94s already. The things I do when I get flustered. Should have looked twice or more at that diagram. i do have an FSM which I will surely dig out and get checking connections. I know the ECU can also get corrosion at the terminals so I’ll start there.
  8. Tom , I already changed out the pump on this sedan so I know where the pump is. It’s in the trunk but you can access it from the back seat like I’m doing now. I’ve done several fuel pumps on EJ22 wagons and sedans. I’ve also torn down a few including removal of interior. But I’ve never noticed what the online schematic showed. It says there’s some sort of module under the center console. This car had sat longterm with a previous owner. And when we got it from the last owner ( young guy not good with cars but his friend eventually helped some) he had tried various remedies for what really amounted to lots of rust in the gas tank. So back when we got this car (couple of years at least now) I immediately changed the fuel pump. Ran great until this happened and now I’ve swapped in a new pump. Man I need to find my tester. This is a problem a guy with his own garage or even comfy place to work would have already fixed. I’m in a condo and my car is in a high traffic area so I’m trying to fix this without looking like I’m working on my car.
  9. And just installed a new pump. It’s a Beck Arnley which I’ve always trusted. At this time I’m unable to locate and of my testers/meters. I’ll grab one later.
  10. Won’t start. Relay clicks as it should. No action at the pump. Just looked online and I see a diagram that shows a module ? under the Center Console. I’ve never known that to be. I’ll try to copy the diagram but I had trouble doing that before.
  11. Ya know , I should have gotten my Sawzall out and cut the head like you mentioned , but I drew the line and just scrapped the block with oil pan , oil pump , and crank pulley still in great shape. Life goes on.
  12. Yeah that was my thought but the timing area is dry. That crank bolt now is super hard to get out so I gave up. There sits a low mile oil pump behind it that would be great to have down the line. Maybe I’ll take one more shot before the scrap yard.
  13. It was a loose crank bolt apparently , which caused the key to flex badly. Breaking the old engine down and that crank bolt of nasty bad not wanting to come out. I want to salvage that oil pump as it was new not so long ago. Brute force and ignorance will soon prevail. But that didn’t cause the rather severe oil leak it had. Really not yet seeing where it was spewing from.
  14. Horror show , comedy , tragedy ( geez let’s hope not ) , suspense for now. Thriller later. yeah buddy !! Ill do my best to take a break and some pics. That new main timing cover - oh baby ! So sexy !!! Piece of crap old bolts holding it on. Looks like a swimsuit pinup gal in work boots.
  15. Thanks , my thoughts too as for shorter of the two. Going to storage to dig some out. I’ll try to report back but I’ll be cranking the next 36 hours. Tazmanian Devil on the loose! Engine swap time. Gathering all the goodies and counting on a long day tomorrow. Cheers!
  16. I saw that I have some still lingering in a misc. nuts n bolts box. Could use some healthy ones now on my EJ22. Threads are the same I can assume. Just length and barrel size I’m concerned about. thanks!
  17. Timing done , covers on , crank pulley on. Forgot to take the passenger side spark plugs out and clean them. Also want to add some Marvel oil or ? to help flush out the remains of any milkshake that got caught up. Otherwise ready to swap engines.
