moosens
    111
Everything posted by moosens
  1. Fuel filler ? Or fuel filter ? I’ll double check but I’m pretty sure both are fine. Car is parked in the sun , over pavement not dirt.
  2. Aged gasoline odor. Sits sometimes lately , say the last 3 months was used about 10 days worth of daily type driving and a few random short runs. My opening line refers to term of ownership. About a year and a half or so. It was driven daily until springtime this year.
  3. Count me in as interested. That guy's came out mighty nice, from here. Enjoy the process.
  4. Car has been ours for at least a year and a half plus. Original owner let it sit after typical light use. Then a young guy got his hands on it and you could tell he pulled it out of vegetation and also didn't know jack dook about the car. But his buddy helped him and this same guy acted as his agent and dealt with me , he told me how they were chasing fuel issues etc. When we got it home I went through the fuel pump and replaced it and generally checked the pickup and float etc. This because the car with half a tank or less would sometimes want to stall. But that was all many months ago. So what could be causing an old gas smell now? Canister ? To me it seems to be more stronger in smell from around the drivers side of the engine bay up closer to the windshield. Checked those lines feeding and returning and breathing and they all seem fine.
  5. Fuzzy memory but I'm thinking you just lower the pedal a little and that will allow the pin to travel out. I've been there , just no super clear memory of it. You'll get it. Hang in there.
  6. And those aftermarket types often come with an end that is too big etc. Check your routing as mentioned ! And also check that your pedal box isn't cracked on the drivers side of it where the pivot pin is for the clutch pedal. That's a problem the previous generation had.
  7. "i have an 83 GL Hatchback EA81 that needs a new carburator, it currently has a holly, but its beat up pretty badly, what would be a WEBBER replacement for this EA71 wagon and would the same exact one work for the EA81? not sure about the bolt patterns and sizes between these two engines.." Other folks know more than I do on this matter but I'm thinking the ea71 and 81 Weber replacements are likely the same. 32/36 with a manual choke - I believe.
  8. "the thing is ill mess with everything on a car except when it comes to anything further past the head gaskets (inside engine block) and the carburator itself, but perhaps the carburator should be something i should overcome my fear of..." Yeah , I was the exact same way and I think you'll find many of us are still or were at one point. The carb rebuild kits are not so hard to get thru. If you do it have a small "sink" to dip the carb body in and soak it in appropriate fluid. Have air to blast too. Canned air can work. There's lots of info posted just have to dig a little. Finding new jets would be great but with cautious cleaning they'll likely be fine. The kits usually don't include jets but do have the accelerator pump and an air mix valve. There's a good sized population of knuckleheads like us over on the dreaded face book. You'll get lots of help there too. Private groups - just join up and enjoy. Face dook groups - Classic Subaru Network and Old School Subaru Group , can't go wrong there for starters.
  9. Once upon a time there was Mill Supply. Try researching them and keep an eye open on eBay etc. Not very long ago one guy was selling his old Mill Supply rocker panels etc because he never got to his project and you know the rest.
  10. Pin holes have caused the leak(s). Take the cowl off , take the dashboard out , lift the carpet , and use a flashlight or whatever pointing it down into the cowl area and look from the inside. Dash comes out easy , don't be scared - you're trying to save your ride. Pine needles and leaves etc build up down under the cowl and sit there until they cause the rot. Many many owners have ignored this and that's why many many old Subarus are gone. Also , PRP made our group here two batches of windshield gaskets. They have some in stock and I even have one or two left. Spend the money and get that gasket and again , don't be scared because I've done it so you can too. Get that sucker sealed up firstly. Then you're off hunting wire connectivity. As for the carb , most people jump over to a Weber , but in many cases you don't need to. Sounds like your carb is not set up right - sorry , I know a shop "did it" 10 months ago. To me that's my basic approach. Seal the body , check your wiring very thoroughly , and then go thru the carb one step at a time. Choke adjusted , idle , mix , and of course your timing too. It's a 79 so no points ignition that's a plus. Good luck. I have some factory service manuals if you're interested.
  11. Didn't the farmers daughter want it ? No real performance upgrades. You can do some things but it'll still be an old Subaru. Not too rare , but you may notice there aren't a lot of '78/9 anythings on the road. Need anything for it ? I have lots of parts. Check out crappy face book - there are a couple or so groups dedicated to old Subarus. "Classic Subaru Network" and Old School Subaru Group are two you'll want to check out. Here is great too for sure. Good luck with it.
  12. Sorry , but there isn't anyone I know of who re-manufactures rubber. But good news ! You can either get one from me or just go through the supplier who made them for our group here. PRP - look for an archived post. The subject comes up a few times a year. Part number should be WCR-288 but double check that. The last batch they had made was around 2009 or 2012 , much better than 40 year old stuff. Check with them first and if they are out let me know. Precision Replacement Parts
  13. You can always PM me here. Also email me at moosens at yahoo. I don't do face dook messaging. And I'm not big on "friending" , don't get offended - I just don't need the extra notifications , and we are all friends anyways. Cheers ! Paul
  14. Although I can't stand face dook I'm a member there as well as many of us here are. Joining a private group isn't so bad. And it's there that you'll find me unloading lots of 70's NOS and great used parts. Classic Subaru Group 4x140 Ultimate Subaru Old School Subaru Group Those three I'm involved with. Most of my sales are happening on the Classic Group 4x140 site
  15. Don't buy cheap crap. Gates belts kits were good , but I hear people saying they've gone to including lesser quality bearings , so do check. Bearings should be NTN or another well made brand. Take some time and read archived posts. It's the best policy to replace all seals and other items like the water pump. You can typically reseal the oil pump and you're good. Also the small elbow shaped hose coming off the water pump - bypass hose - spend the $8 and get that along with good hose clamps. Thermostat and gasket there too.
  16. Maybe I'm wrong but from here that wheel looks like 2nd Gen with the curved spokes. Just about the same. Good luck with your sale.
  17. Weekend dive into storage approaching. Not sure how much energy I'll have after working but yet another SHOUT OUT to any fellow northeast folks. If you haven't seen , I've been starting to list lots of parts and there's lots more to come out. New Old Stock , great used , manuals , etc. Joined dreaded face dook and am a member there in closed groups such as this Board's , the 4 x 140 group , and a couple others. Also threw some items on dreaded e bay. Helpers are certain to score well and have a great time. Shooting for a solid Saturday starting early - 6:30am With company and a reason to persist , I will hammer out a long day. But I don't want to be there come sundown. Sunday I'm hoping I'm back there early as well. But Sunday will not be a long day. If you can't make it by noon or so don't bother. Ok let's see who this shakes out. Lol NO expectations here. And if you're wondering , yes I do appreciate good IPA.
  18. Not really. Do the whole deal - belt , pulleys , water pump with new bypass hose (small elbow) , thermostat , and reseal your oil pump and do cam seals.
  19. Oh , sorry I didn't read too well. Cut floor out etc , So show what's left to do. East coast , going to be rust , but an 81 with dual range is a rarity here now. And could be lots of fun.
  20. How do people get ahold of you? Email ? I'm sure if folks had a picture or more that would help. If you have a low rust Gen I Brat in the east it'd be sold , so post pics or supply them somehow. The parts alone sound like a deal.
