Subaru Jim Maple Ridge
Everything posted by Subaru Jim Maple Ridge
Hate to even bring up the possibilities, but it could be a small intake leak, or, more hated, a notch out on the timing belt. Just thinking more of what can happen when that work is done. Yes, a plug could have hit the floor and closed the gap up etc, but it usually a bit closer to the work done. Good luck, hope you find your gremlin. Jim
We are about to put a '92 2.2 into an early '80's I/O. Would like to talk if someone has already done this. Thanks Jim .
Problem solved. Turns out there is a switch located at the bottom of the shift lever, on the rod for the shift button. The car sat for a least a year. Lube sprayed directly down the lever loosened everything up, had to jiggle the shifter around park occasionally, but now key returns to lock position every time. Thanks for all the help. Jim
Problem solved. Thanks for the input. Turns out there is a switch at the base of the shift lever. By removing the shift handle, I was able to spray lube directly down the lever. Once the rod moves freely, all I had to do was jiggle the shifter in park occasionally, and now the key goes to the lock position every time. This car did sit for almost a year. Again, thanks for the help. Jim
Bought a 2.5 SOHC to replace a 2.5 DOHC in a '99 OBW. I do not know the year, or the donor vehicle. I do know that it has 61k kms marked on it and cost me $300. It has what appears to be an oil cooler between the block and the oil filter. The water goes from the port normally used for a block heater to the rump roast'y, then towards the water pump. The pump is damaged so I do not know if it returned to the thermo bonnet or to another return hose, or to the pump itself. My question is; Is this factory for some other or future model? Worth keeping? and if so what should I order a water pump for? I know, more than 1 question. Anyway, thanks in advance for your thoughts.
Will 2.2 fit in 99 Outback?
Subaru Jim Maple Ridge replied to Subaru Jim Maple Ridge's topic in Subaru Retrofitting
New belt in, still lots of noise. Pulled the end covers, nothing amiss. Time to pull it out a`nd do the autopsy. Do oil pumps blow up on those things? -
The intake cam is advanced by 1 notch on the left, and the exhaust cam is advanced by 1 notch on the right. It makes a screeching sound which could be air sucking past a closed intake valve, and also a rapid, intermittent, light clattering noise, probably from the valve train. I will put in a new belt but I'm pretty skeptical at this point. -
Just bought a '99 outback with a 2.5. Makes lots of noises when running. Timing marks are off on 2 cams, but only by one notch each. I have a couple of good running 2.2's, ( from a '90 and a '92), will they drop in or do I have to tear this thing down and repair it? Is the '99 2.5 any good to begin with, or should I be looking for a different year? Thx. Jim
The rad is a 2 core. I put in a new rad because this is my own car, and I had the engine out anyway to switch the auto to DR. The antifreeze is 100%, only so that when you get a leak and have to fill your rad from a nearby creek with a coffee mug, you are diluting the mix towards the optimum, not away from it. I once blew a heater hose in -10*, filled the rad by stuffing in snow, and still had enough of a mix for it not to freeze before I made the 200 miles home. This problem may be maddenning result of a bunch of little things, like maybe the winch on top of the bumper. But it did the same thing last year as an auto without the winch. Thanks for the input.
EA82T 1986 Dual Range questions?
Subaru Jim Maple Ridge replied to EA82DM8's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can shift on the fly if you want, just watch the revs. Hard shifting is usually caused by mismatched tires or uneven tire pressure. When it is stuck in 4WD, you can release the pressure on the gears by backing up with the front tires straight while holding pressure down on the transfer lever. You may want to check that the ratio on the rear diff matches the tranny. Someone might have converted your car from an auto and not changed out the 3.77 rear. Good Luck As for larger tires. yes, they stress everything. Wheel bearings, CVs, clutches and brakes. You just have to decide for yourself if they are worth it. -
The fan is wired direct, the thermostat pin has been replaced by a 3/16 inch hole and I have no AC. The idea about the air sounds interesting, but the other cars I took up the same mountains had the same body styles, with no noticeable increase in temperature. There is little or no boost at 2000 RPM and you barely have your foot on the gas. I just putt along because I am usually hunting. I'm not blasting up the mountain with rocks flying everywhere. Thanks for the quesses though. Maybe the turbo needs an intercooler at those low speeds.
