![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
john in KY
7
Everything posted by john in KY
Ignition timing adjustment issues
john in KY replied to Starlite's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The timing marks, are you using the ones on the flywheel or the front pulley? I think the balancer has marks. Could be wrong about that. Anyways, if using the timing marks on the balancer, the balancer could have slipped on its hub. As far as I know, the TPS sort of controls the injector pulse lengths and the automatic transmission shift points. I don't think it has anything to do with ignition timing. -
The distributor could be installed one tooth off. I don't think the TPS is the source of your problem. I would suspect a loose timing belt or a worn distributor first. -
91 to 83 Transmission Compatibility
john in KY replied to Jes1991's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I seriously doubt the differential ratios will be the same. -
Did a little research and decided to just buy the complete kit. All save the original parts, replace the bearings someday and have them around to use in the future. I keep cars a long time. Still driving the 95 with around 300k miles on it. One question: Is the bolt that retains the tensioner reverse threaded? What nipper posted appears to loosen, turn CW.
Subarute (small truck made from a Subaru wagon)
john in KY replied to sawdust_tom's topic in Subaru Retrofitting
I can't imagine any Subaru towing 5K pounds. Could be wrong but that is a bunch of weight. -
Peugeot wheels for 88 GL
john in KY replied to YnotDIY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Plus 2 about the lug nuts. Wheels are useless without them as the lug nuts are unique. -
Just a wag here but my guess is the sensors from the blown engine are different from the replacement engine.
Fried fusible link
john in KY replied to Movinasfastasican's topic in Historic Subaru Forum: 50's thru 70's
A wrecking yard or at a dealer. If you go the wrecking yard route, just pull one the same size/color. Doesn't have to be from a BRAT. Any GL/Loyale up to 1994 will have the links. -
Not 100% sure but don't think that are interchangeable.
