john in KY
7
Everything posted by john in KY
I don't believe it is a one-off bearing. Doesn't make sense economically. Find a "bearing house", a business that only sells bearings. There is such a business locally but that doesn't help you. Another option is maybe whatever the bearing is installed in can have the hole diameter increased to accommodate a slightly different/more available bearing.
My guess is bigger is better. Air tools require volume which a larger diameter hose should provide.
Starter solenoid wire left unplugged?
Shipping parts from craigslist - risky?
john in KY replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just my experience over the years: 2 chainsaws, one radio, set of 17.5 tires. Used Paypal every time and no problems. -
Solenoids for the front struts are located on the firewall. Rear strut solenoids are located on the struts. If the compressor is good, struts will inflate when the solenoids are opened. I would suspect a weak compressor. See if it will inflate a strut with the weight of the car removed. (Just jack the car up.) "so it seems like any pressure in the lines should fill up any strut which has an open solenoid (letting air in)." Makes sense to me. That other solenoid you tested may not be opening. You should hear a click when energized.
Probably a good idea to also get the crossmember.
The XT6 never offered a FWD manual. Only the XT had that option.
Could be not enough or too much air, little or no fuel pressure, no spark and that's about it.
- 27 replies
- electrical
- relay
(and 3 more)
Tagged with:
1987 GL10 Turbo 4WD Issues
john in KY replied to brundl3fly's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pretty sure this model didn't get the 4EAT until 1988. If so, that transmission is AWD, meaning no 2WD option. -
How can I check to see if my Starter is bad?
john in KY replied to Jman1991's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Probably is not the starter. Remove and clean the battery connections. Also clean that small wire at the starter. It activates the starter solenoid. -
Also when you changed the fuel lines, make sure you didn't cross them. Replacing the fuel pump isn't difficult if that turns out to be the problem but replace it with an OEM pump. Few years ago my pump failed and I bought a non OEM pump that was described as being a direct fit. It wasn't and ended up costing me $500 when it fell off 300 miles from home.
Noid light will not come on at any time at injector 1. Not sure about this but thinking the injectors receive 12 volts (not from the ECU) and the circuit is completed at the ECU, the ground. If I am correct, then the noid light should show a solid light even if the ECU is bad. Won't flash. Any chance the problem is a blown fuse? Sounds like the problem is the injectors are not receiving a 12V signal.
Checked cam timing it's dead on set tdc on compression stroke That doesn't sound right. From memory the camshaft timing marks line up when the piston is 1/2 way up the cylinder. Sounds like the valve timing is way off but in your post, no mention of tinkering with the timing belts. Odd.
Need quick help slightly urgent
john in KY replied to XHighOctanex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think it is yellow in color.
