john in KY
7
Everything posted by john in KY
1991 Loyale no heat/overheating problems
john in KY replied to thekauz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think a new radiator will solve the overheating problem. The one in the car is now 25 years old.- 5 replies
- A/C
- overheating
(and 1 more)
Tagged with:
Run the AC for a few minutes and you will see a puddle of water form under the car in front of the passenger seat well. Or just look under the car, right side, for a dangling hose under the firewall. Use compressed air to clear it. The heater core is inside a sealed box. If it springs a leak, coolant begins to collect inside the box.
I would first replace the fuel filters. I believe there are 2.
- 15 replies
Ea81 brat HELP OIL EVERY WHERE
john in KY replied to Norcalbratcap's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oil pressure sensor sprung a leak? -
Fuel tank under the hood? Wonder what the outcome would be when the car is involved in a front end collision? Engine smashes tank, tank ruptures, gasoline flows on hot exhaust...guessing not a real concern after all.
- 18 replies
- loyale
- fuel range
(and 2 more)
Tagged with:
Ea82 weber fuel lines: gas in my engine bay!
john in KY replied to Nick Nack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My guess is your mechanic installed the correct pump so forget about the fuel pressure being too high. The photo of those 2 lines sure look like fuel lines to me. Where/what to they connect to? -
If your car is indeed a Loyale, than it was originally fuel injected. If the stock fuel pump wasn't changed when the Weber was added, then the fuel pressure is too high. Carbs leak for various reasons but the most common is too high fuel pressure and/or the float is adjusted too high. carburatore don't use/have a fuel return line. -
86 xt overheating
john in KY replied to SomeoneWithCarTrouble's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Radiators don't last forever and yours is 30 years old. -
New heads or crate engine EA82?
john in KY replied to Nitsivart's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you do opt for new heads, I won't, make sure they are the generation 3 heads. -
Can I fit 91 Loyale A/C into an 89 GL?
I did the swap in an 85 wagon 10 or more years ago. My advice is to swap the entire dash as a unit. The under-the-hood work is pretty basic. -
86 GL-10 Turbo line leak?
john in KY replied to New2Subaru1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have own 2 turbos over the years. Both developed a crack but not in a location to cause a leak. Just lucky. -
That turbo is both coolant and oil cooled. Replacing the line isn't the end of the world but I won't overlook the possibility of a cracked turbo. Point is, don't assume the problem is a line. Verify/identify where the coolant leak is originating. -
The TPS is still not adjusted. Start at the middle of its range and then make very small adjustments one way and the other. Have to road test each adjustment. If the shits get harder and shift points increase, going the wrong way on the adjustment.
- 11 replies
- forester
- throttle position sensor
(and 1 more)
Tagged with:
Looking for a manual for 1989 -1991 Xt6 Engines
john in KY replied to xt6rick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check for the FSM on eBay. What engine parts are you looking for? -
Alternator Replacement PT#14585
john in KY replied to Brokenneckj's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You almost always can find a new belt slightly smaller than the one you now have.
