![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
john in KY
7
Everything posted by john in KY
Engine is out and front cover removed. Can't find the gold links and how to remove the cam sprockets have us stumped. I'll post a photo of the sprockets tomorrow. For anyone in the future undertaking pulling this engine, there is a small inspection plate bottom of the bell housing. Forgetting to remove it and you will have a world of problems. The cover has a small lip that will snag the convertor and pull it for the transmission.
Just about to remove the front cover and stopped and backed off. Thought about what i was doing and the problem and concluded removing the front cover would accomplish nothing. The oil leak is behind the back cover and opening up that can of worms I decided above my pay grade. Decision was made to just replace the engine. Started on that this afternoon and stopped when I thought about that security system in newer cars. Can the engine be swapped without having the security system/ignition/whatever reprogrammed? Would really hate to go through the expense/labor installing another engine only to have it not be able to start.
All I know is that set of special sockets is/was a Craftsman. I'll do a photo tomorrow. As for the Vicegrips, I guess I still have a strong grip. Last week I found the torque setting for the cover bolts and the sequence. Did I print them out? Nah, I'll come back and get them when needed. Well now I can't find either on the internet. Need help. I need sort of segregate the different bolt lengths. The more I think about this leak the more I think it is the back cover with the problem. Going to take a chance and just do the front and keep my fingers crossed.
The photo is the backside of the cover. More or less found the leak. Just to the right of the water pump is an idler. Fairly positive it has an O ring and that has failed. The leak is definitely leaking what we believe is the part of the casting [back half of the cover] that directs the oil back to the oil pan. Whatever, feeling confident an O ring has failed and went and ordered all the parts and will start taking down the timing cover tomorrow. Will post a few photos during the teardown. Sorry about the confusing photo.
"That looks (and sounds) a lot like a front crank seal leak. Maybe remove the crank bolt cover (10mm bolts) and the crank pulley bolt (22mm) and crank pulley and see if it's wet behind there?" I'm willing to do this after watching several videos but can't stop wondering how a failed seal can produce a leak on the back side of the covers.
"What a mess, with the crap on the front of the cover, I'd say it's coming from higher up. Front main seal, probably." The front cover is fairly clean. The photo is from under the car and shows the backside of the timing chain cover. Have yet to decide on a course of action. Does this engine have 2 crankshaft seals, an inner and outer?
08 Outback with the 3.0. Over the summer been noticing a slight oil stain on the carport. Two days ago noticed no longer a slight stain. This morning had to use the car for a 25 mile trip. Added a quart before leaving, checked at the destination and had leaked a quart. This afternoon replaced the oil cooler gasket and the oil pressure sensor and no change. Leak is a large drop ever other second at idle. Leak is dripping between the front of the oil pan and backside of the timing chain cover. Just eyeballed the front of the engine to see if maybe from the crank pulley but looks dry to me. I am at a lose where the source of the leak is.
New XT Turbo Coupe owner
john in KY replied to nigxl's topic in Meet n' Greet. Your USMB Welcome Center
Been 25 years since I had an 85 XT turbo. For some reason thinking the part of the pump where the fan bolts can be moved downward with a press. The turbo engine I believe required the shorter pump because of the thicker radiator. -
Camshafts use 2 seals. Front one obvious but the one that always leaks is that O ring on the back side. I know the newer engine has 2 seals backside of the cylinder heads. Not sure about this engine but if there, both are leaking. -
1988 XT6 automatic how to refresh axles?
john in KY replied to xXArchusXx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Find and remove the roll pin. When reinstalling, the roll pin only goes in one way. Very important: use the correct size punch to punch out the roll pin. Axles attached to the differential, not the transmission. -
1994 Subaru Loyale won't Start --
john in KY replied to vtscooby's topic in Meet n' Greet. Your USMB Welcome Center
I know from experience that the coil bracket must be well grounded. Very remote possibility that small whatever it is called that is riveted to the bracket has failed. -
XT6 1988 where is the flasher relay?
Just start disconnecting them one at the time. -
87 XT idle issues. Dies when in gear.
john in KY replied to SiriusBlack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The 87 will have the 3-speed. But if the car is the 87.5 model it will have the 4 EAT. An easy way the tell the difference is the intake manifold. The spider intake will make it the 87.5 model.- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
Just throwing this out there. Could be an airflow meter problem. After all these years that "flexible" air intake hose isn't. Check for cracks and insure ALL the smaller hoses are still attached. Many years ago my 85 XT turbo would just quit running. Eventually discovered a ground wire attached to the intake manifold, right side , was corroded. Whenever the ground was lost, the injectors stopped firing.- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
