john in KY
7
Everything posted by john in KY
Just from memory I think there are 4 relays under the dash sort of above the steering column. Not easy to get to but there should be 4 in a row in a common holder. Also thinking they are round in shape.
Don't really understand what you are asking but I have an ER27 engine that was modified to be installed in an experimental aircraft. It has a GM distributor from a V6 that was modified to fit the ER27.
Another option and probably cheaper would be to replace the rear differential with a 3.90 ratio. I scrapped 2 just this summer so there must be tons of them out there. Once you have the car back, go to the Small Claims court and file a claim. You probably will end up spending a lot of money because of the "old guy's" mistake.
My guess is timing. Distributor timing off/firing order wrong/cams off.
I agree with the 1st responder. Since he has no basic tools, this suggests to me he has no experience working with wrenches/sockets/basic automotive tools. You could be amazed at how much damage a tool in an inexperience hand can cause. Car is probably near or at a timing belt change and brakes. When that belt breaks, probably a $2K repair. I also believe any tools you buy for him will never be used and cheap tools are a PITA to own.
93 loyale exploding coolent?
john in KY replied to tanner93loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Could be one of the heater hoses or that little line that snakes under the intake manifold but I would first check the heater hoses. -
error code 22: EA82T 1990 model + ECU questions
john in KY replied to wagonist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Send a PM to member nncoolg. He's local to you and knows a bunch about this engine. -
The power steering fluid leak probably just need to tighten the line fitting. Minute and really not something to be stressed out over right now. The steering rack could be the source of the problem but I wonder. Few months ago returning from a trip my 95 started pulling to the left. Also a a slight steering wheel shake the got more noticeable the closer I got to home. The wheel shake turned out to be a broken belt in the left front tire. Went and replaced the rack and that turned out to be a bitch of a job. Fittings are almost impossible to get a wrench on and one of the bolts the hold to rack to the frame snapped off. Nothing I tried to remove the snapped bolt worked so finally drilled it out and used a timesert. Installation was no picnic either. Had a terrible time reconnecting all the line fittings. Your rack does look bad and should be replaced but don't expect it to be a few hour job.
- 7 replies
- 1
- 1996
- legacy outback
- (and 8 more)
Just a thought but if the oil pump is coming apart, that would produce the leak and the low pressure.
Maybe the problem is a clogged exhaust. I would think even if the turbo was not working, the engine should still be able to rev past 4K.
I think this will work. Pull the vacuum line at the wastegate controller. This should cause the turbo to produce maximum boost, something like 20lbs. If no change at the gauge then I think the problem is either the controller or the turbo.
did a td04 swap...having a vacuum nightmare
john in KY replied to MuddyThunder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can provide a partial answer. Heater controls not working because of that white canister on the firewall just above the turbo. Either it is leaking or more likely, the vacuum hose is disconnected. -
EA82 Turbo Overheating
john in KY replied to Swollenberg's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Every turbo EA82 I have owned (3) have had the 2 core radiator. I don't believe that radiator can be bought new anymore. Seems odd to me that it runs cool in town but only overheats on the highway. -
EA82 MPFI 1987 engine cut out, won't start
john in KY replied to jkhackney's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hmm, 60,000 kilometers since I changed them. Belt should have lasted much longer. Most probable reason it failed so soon is the idle bearing is failing. If this was my car, and I once owned 2 turbo wagons, I would replace the oil pump gasket and the camshaft seals while it was apart. The camshaft seal that often causes the oil leak is not the one that is visible behind the cam sprocket. Need to remove the sprocket and then that housing retained by 3 bolts. there you will find an O-ring. Change it also.
