john in KY
7
Everything posted by john in KY
I haven't bother to read all the posts but if the oil pan had an extra gallon the question is where did the extra gallon come from? If from a leaking gasket, then the radiator would have to be a gallon low and the engine would overheat. If you didn't have to top off the radiator, there is nothing wrong with the head gaskets.
You bend the tab attached to the float. Goggle "weber float adjustment".
If the Weber uses a float, sounds like the float s too low.
Easy outs can be problematic. If you have a reversible drill, buy some left-handed drill bits, and go that route. Use a center punch to mark the broken bolt before drilling.
This really sounds like caster or camber problem. Never could remember which is which but one seems to me needs to be adjusted. Also, whoever told you the coil springs need to turn knows less about alignment than I do.
xt gl10 dash going crazy after coil over swap
john in KY replied to tytuk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The control unit is located under the driver side door sill. Really need to pull the seat, roll back the carpet to gain access. Plus you have to remove that plastic sill plate. Anyways, just unplug it and problem solved. -
I Need A Heater Mechanic
john in KY replied to Subarumor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Don't know if this applies to the loyale but the XT/XT6 has a switch just to the right of the gas pedal that controls the "doors". It is located behind a small plastic cover. If there, pop the cover and while someone else works the heating buttons, see if that lever moves. Also do know your car has a vacuum canister under the hood on the passenger side on the firewall. It needs to be hooked up for the heater to work properly. -
New here from South Australia
john in KY replied to JP147's topic in Meet n' Greet. Your USMB Welcome Center
Road reminds me of what back roads in NE Ohio looked like during the spring thaw. -
only one 4wheel drive works
john in KY replied to kanobi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like a broken front cv axle or stripped front hub.- 19 replies
- 1
- 4 wheel drive
- 1984
(and 2 more)
Tagged with:
250,000 miles today!
john in KY replied to cascadeclimbn's topic in Meet n' Greet. Your USMB Welcome Center
Approaching 300K on my 95 Legacy. Engine/transaxle/driveshaft still all original. Seriously thinking about finding another driveshaft at the wrecking yard. rebuilding it, and have it ready when the original fails. -
I think you now have two problems. First problem is there is air in the coolant system or the engine is just low on antifreeze. Do a search for "burp". The belt is squealing because something it powers is not turning. The "something" could well be the water pump. I would not drive the car until the problem is identified and repaired. Replacing head gaskets can get very expensive. http://www.subaruforester.org/vbulletin/f88/burping-coolant-system-8683/ http://www.ultimatesubaru.org/forum/topic/93859-burping-question-on-overheating-legacy/
