john in KY
7
Everything posted by john in KY
Steering wandering after suspension work
john in KY replied to stratman977's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have no idea if this could be the problem but whatever that plate is called that is between the top of the coil spring and top hat bearing is only installed one way. Thinking it has arrows or something etched in it to insure proper orientation. -
Fairly sure any subaru radio from the 1990s and even into the 2000s will be a plug and play. Double din radios swap into single din holes just by removing that tray under the single din radio. Probably also want to look at the speakers because I bet they all need replaced. As for the heater problem, lots of possible causes. I would run a hot wire to the fan motor just to see of the motor is the problem. Edit: If you decide to swap radios, the trim piece needs pulled. Pull the ash tray and look up. Should be 2 small screws. Need a really short screwdriver to remove.
Sounds like part of the problem could be from a ruptured fuel pressure regulator or leaking injectors. Do a fuel pressure test to verify if pressure is within specs with engine running and after shut down. Pressure should remain steady after the engine is turned off. If the needle slowly drops over time then there is a leak somewhere. An easy way to check for a ruptured FPR is to just pull its vacuum line. If fuel squirts out, engine running, then the FPR has failed. Since you don't know the history of the car, previous owner could have replaced the stock injectors with much larger ones which would compound the problem.
- 7 replies
- timing belt change
- one autolite spark plug
(and 1 more)
Tagged with:
Tribeca Power Seat Dead
john in KY replied to davewetzel's topic in Meet n' Greet. Your USMB Welcome Center
Be careful with the YELLOW wires. Yellow = airbag.- 3 replies
- 1
- Power Seat
- Tribeca
(and 1 more)
Tagged with:
A collapsed radiator hose suggests to me a clogged radiator. Has happened to me several times over the years and it was in all cases the radiator. My theory is either the previous owner used a lot of radiator stop leak or being it is Hawaii, straight water was used for years.
- 20 replies
Greetings from The Boonies, WV
john in KY replied to samsonlonghair's topic in Meet n' Greet. Your USMB Welcome Center
Recommend you use an impact screwdriver when removing those 3 mirror screws. Often they are really in there and the heads are easy to strip out. Recently bought an 08 LL Bean. Took me 2 5-hour days to change the 6 spark plugs. Yours probably need changed. Paying someone to replace them will not be cheap. -
Here's another forum you may like: http://www.subaruoutback.org/ -
What model year and what are some of the problems? -
Should be no need to cut the holding bracket. Reason will be obvious once the clip is removed and the line pulled slightly in one direction.
- 11 replies
- forester
- rear suspension
(and 4 more)
Tagged with:
http://www.ultimatesubaru.org/forum/topic/108429-pictorial-wheel-bearing-guide-4wd-rear/
Required exhaust back pressure
john in KY replied to mandalore4411's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I once ran a 90 turbo wagon. The only part of the stock system, starting at the turbo, was the flange that bolts to the turbo. Everything else was replaced with 2 1/4 inch pipe. Muffler was a straight through design. Not even close to being too loud. -
Sloppy steering fix? Loyale
john in KY replied to Subarocket's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The steering rack is held in place by rubber bushings. Sounds like they may need replaced. The rack itself could be moving side to side.
