john in KY
7
Everything posted by john in KY
It's your car and I am not a welder but I won't trust those welds.
Sounds like the previous owner had a fuel delivery problem and replaced the pump and that wasn't the problem. The pump I believe is recycling because of too low fuel pressure. If the pump is good, then the only thing I can think of is a bad fuel pressure regulator or a badly leaking fuel injector. But before replacing even more parts, make sure the hose between the engine and fuel filter is the right one. Someone may have crossed the fuel to engine hose and the fuel return hose.
Don't know why, it just is. If you have an old Subaru newer than 1987, unbolt the coil bracket and attempt to start the car.
The 85 turbo engine has a fairly unique distributor as noted above. From memory it should have a vacuum advance canister with 2 fittings. Also, don't know if this applies to the early turbo models, but the 87 and newer require that the coil bracket be grounded to the body. A photo of the distributor could help.
Just to the right of the gas pedal,behind a plastic cover, is a "white gear". It may be stripped or the lever connected to it is out of adjustment.
Freezing coolant(water) killed my car?!
john in KY replied to 82GLWag's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's true. If there was some way to cast a block/cylinder head without using a sand mould, freeze plugs won't even exist. -
This may help: http://allwheeldriveauto.com/why-is-the-power-steering-making-noise-on-my-subaru-outback/ Don't buy a power steering pump if yours is making noise for the first ten minutes of the day. Buy an O ring, Part # 3449AE020, from Subaru. Remove the bolt that attaches the fluid line from the reservoir at the pump, twist a little and it pulls right up. If the area is dirty first brush it off with an old tooth brush, to keep the dirt out. Carefully pull the line up, replace the O ring, and push the tube back in. Tighten the bolt. Start the engine, and turn the wheel side to side a few times to bleed any air out of the system. Happy motoring. http://www.subaruoutback.org/forums/66-problems-maintenance/43054-power-steering-noise-2002-outback.html 'there are still bubbles in the reservoir" suggests an air leak somewhere.
The repair costs so much because the entire dash has to be removed to get to the heater core. Not a fix but you could disconnect the 2 hoses at the firewall, engine side, and splice them together. You end up with no leak and also no heater. A SMALL amount of some quality radiator stop leak could plug the leak. By small I mean 1/2 of whatever is recommended. Too much is a bad thing.
- 4 replies
- Legacy
- Heater core
(and 3 more)
Tagged with:
Used 2.25 on my 90 turbo wagon. Went with that size because when I cut the flange at the turbo off, 2.25 size pipe was a perfect fit. Muffler used was a straight through turbo design. Noise was minimal, actually very quite.
Not starting in the morning, cold engine, suggests a problem with the CTS. Stalling at traffic lights suggest the IAS or AIS, never could recall which, needs cleaned. Shouldn't be difficult to determine what under the hood is making that sound. "next person said it was canister purge solenoid or circuit which is another 85.00 so could someone help " I doubt it. Save the $85 for something else like an air filter if the one in the car needs replaced.
87 XT air suspension swap
john in KY replied to makipsee's topic in Old Gen.: 80's GL/DL/XT/Loyales...
May want to adjust the air pressure in the current set up before going through the hassle of replacing it. -
Could just drop the entire front suspension if it is anything like the EA82 models and just leave the engine/transmission in place.
Does the car have a rust issue? If that "tube" the rear suspension is hung from is rusted in the middle, the rear suspension will sag.
