john in KY
7
Everything posted by john in KY
EA82T, with code 12 not starting
john in KY replied to juankyx206's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Timing is correct and the plugs are firing means to me you have a fuel problem. Check for a blown fuse and check to see if the fuel pump under the RR wheel is working. -
front passenger wheel seized up 1985 gl hi-lo
john in KY replied to nepppen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Problem could be the master cylinder. -
$1200 plus labor is a lot of money to me. So the torque convertor doesn't go into lock-up mode when cruising. Big deal. You lose a little fuel economy and the engine will cruise at a slightly higher rpm but neither is the end of the world. And if it is a "dirt" problem, driving it for a while may cure the problem.
86 Air Flow Meter help? ea82t
john in KY replied to subarurx yo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
PM sent. -
The unthinkable 4eat conversion 87 GL-10
john in KY replied to AKghandi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also fairly sure the transmission tunnel in your 87 is too small for the 4EAT. -
Whats it worth (1990 Turbo 4WD wagon)
john in KY replied to jeryst's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Once owned the exact same car. Served me very well. Had 250K on it when I sold it and it was still running strong. The transmission will be the 4EAT which is a plus to me. -
A bit of a puzzle: 1988 Gl-Wagon problems
john in KY replied to Lvl50Hornist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Coil bracket also needs to be grounded but have you checked the timing belt? -
90 Loyale no spark, died on freeway
john in KY replied to Zekeuyasha's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The OP stated the engine has no spark. The passenger-side timing belt whether it is broken or not has nothing to do with a no-spark condition. From experience I can attest the engine will run on 2 cylinders when the passenger-side belt breaks.- 29 replies
- 1
- electrical
- timing
- (and 5 more)
Crank engine with the distributor cap off. If the rotor doesn't turn, broken timing belt.- 29 replies
- electrical
- timing
- (and 5 more)
Hydraulic. Reseal the oil pump along with a new block to pump gasket solves the problem the vast majority of the time. Edit: Advice was for a Loyale but your picture shows a Legacy. Two different animals. Also no Legacy came with a 3-speed automatic so is the photo the car in question or are you asking about a Loyale?
- 13 replies
- 94 Loyale
- Loyale 3AT
(and 5 more)
Tagged with:
Don't know the correct way to adjust it. Method I have used on my XT6s involved starting more or less in the middle of the range and then driving the car stopping to make small adjustments. Too far one way and you get the hard shifts. Too far the other way and car runs like crap and no upshifts. Keeping playing with it until you find the sweet spot.
I'd say yes. Takes more fuel to start a cold engine. Because the fans are running, the ECU "sees" a hot engine and therefor no need to add the extra fuel. The CTS along with the ECU performs the same function a choke did in the good old days.
- 13 replies
91 Loyale Weak Ignition and No Power
john in KY replied to finni's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Airflow meter. -
Won't a differential from an XT6 with the differential lock be the best of both worlds?
98 legacy outback wagon... sits too tall, need some ideas
john in KY replied to mightGETaSUBARU's topic in Suspension
I have some rear struts from a 1997 Legacy GT with something like 20K miles on them I'll sell cheap if interested. Plus a pair of new/never installed top mounts. -
Need some help with the ignition fellas....
john in KY replied to Demolition's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If it is anything like the XT, just remove the steering column cover and drill out the "headless" bolts. A lefthanded drill bit works great for this.
