john in KY
    7
Everything posted by john in KY
  1. The shifter linkage eventually connects to a "fan-shaped"whatever on the passenger side of the transmission. It has detents for every gear. Slim chance it maybe out of adjustment. But it sounds like you smoked the transmission driving it to work.
  2. Just recently read an article about "remanufactured" MC and slave cylinders on another forum. Seems most "rebuilt" cylinders today on the market aren't really rebuilt. Just new seals and that's it. Cylinders aren't even honed so good chance either one or both of the new parts you purchased have pitted bores.
  3. I think the asking price is way to high with the described paint job. The power steering is electric and most likely the motor just needs new brushes to fix it. An easy fix. The power steering fluid is special so only use Subaru fluid.
  4. The size should be cast into the backside of the wheel but what you have are the oddball 390s.
  5. Check the timing belt/belts for stripped teeth. Also verify the screw retaining the rotor hasn't fallen out.
  6. I just did mine in the driveway with the front wheels on ramps. The 7/8 wrench works for me and it is a tight fit. Very little room to work in and I attacked it from the bottom. Do yourself a huge favor and use antiseize on the new one.
  7. You can contact me at gflong@kih.net.
    John
  8. Also have new valve cover gaskets, distributor cap and rotor, fuel filter and a set of timing belts. Have a used distributor and coil also. Just putting this out there thinking you may need some of this.
    John
  9. $30 for the MC plus postage and the MC includes the booster. Don't think I still have an engine wiring harness but will look anyways. Send an email address and I can send photos of the MC.
    John
  10. My 95 fuel mileage recently took a major hit similar to yours. Turned out the problem was the vacuum line to the FPR came disconnected.
  11. Sure. Found the 2 hoses for the turbo and both radiator hoses. All new, never installed. $35 shipped. I'll post a photo if interested. You can PM me after you have racked more than 10 posts. John
  12. If you want to just replace the 4EAT with another, I know a person in Jacksonville, FL that has a good one. Post your email address and I'll forward it.
  13. I have the two "turbo" hoses around here somewhere. Had them for my 90 turbo wagon but never installed them.
  14. Don't think so. Thinking only the 1990 turbo wagon came with the 4EAT. Everything else got the 3 speed.
  15. http://subaruxt.com/forum/viewtopic.php?f=4&t=12635
  16. I did an internet search for "yardhippie" and got one hit. Location was TX and it is a Subaru forum.
  17. What about that old Dodge in the background? If it has the poly 318, I'd be interested i the exhaust manifolds and the exhaust header pipe if still any good.
  18. None that I am aware of. Problem more likely is a vacuum leak or that part the bolts to the top on the thermostat housing. It controls the idle speed.
  19. Just nitpicking but a factor to also consider is the width of the wheels. The same tire on a 6" wide wheel and then on a 5.5" wide wheel will probably have a difference in circumference.
  20. Had the same car a few years ago. Sold it with 250K on it and it was still running great.
