Everything posted by john in KY
need a lil help
Open the driver's door and the data/manufactured date will be found. Are you sure it has 13" tires. Seems very odd.
Rear suspension rotted out
If you have air tools and don't run into problems, easily can drop the whole thing in 45 minutes or less. I think for some reason I may even have that "crossmember" around here somewhere.
EA82T Complete engine failure
Impressive.
XT6 Dead Electircal
For some reason thinking the negative cable for the battery terminates at one of the starter mounting bolts. If so, either now making a poor connection or you overlooked it when you pulled the starter.
99 Outback suddenly brakes and brakes overheat
john in KY replied to craigmcd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPads are always making light contact with the rotors. This contact generates heat that gets transferred to the brake fluid. Brake fluid absorbs the heat and expands as a result. The increased volume has to go somewhere and the somewhere is the master brake cylinder. If the heated/expanded fluid can not get back it will push the calipers pistons out. All this does is generated more heat/more expanded fluid until eventually the brakes will lock up. Been there, done that.
john in KY replied to craigmcd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA new brake master cylinder will fix this.
92 loyale wheel bearings, help me
Once the drum is removed, you will see what was causing it not to want to come off. There will be a "lip" on the outer circumference of the drum that the shoes hung up on. Back the shoes off to remove the drum.
no oil pressure at all
Before buying a new pump, pull yours and verify the pump to block gasket didn't get sucked in.
Tips:Removing an automatic transmission
john in KY replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBe very careful when reinstalling it the TC is FULLY seated. Get it wrong and the transmission will end up junk.
91 Subaru won't even start...
john in KY replied to knor91's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre the battery cables clean and tight? I think there is a fusible link in the fuse box under the hood. May want to check it.
86 GL-10 problems
Had an 85 XT turbo once. Similar problem. Problem in my case was a poor electrical connection. Look for a grounding wire on one of the intake manifold bolts, passenger side. Also have a good AFM for this model. Removed from an engine with 60k miles and stored for many years. $50 plus shipping if interested.
89 GL-10 turbo wagon questions
$4K is a lot of money but this is a lot of car. Had a 90 turbo wagon that had 0ver 300K miles on it when I sold it. They can run for a long time regardless of what some folks say. Car also has the 4EAT transmission, which is great, and almost certainly has the rear LSD. In my experience an old radiator will cause more engine problems than just about anything else. Also this engine will have the generation lll cylinder heads which means less likely to crack. If I was in the market for another wagon, I would seriously consider this cream puff.
Need 'lectric help fast!
john in KY replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be bulbs if the circuit suffered a massive voltage strike.
15" Peugeot turbo wheels
Stopped in a local wrecking yard today and gained access to an area previously denied and stumbled onto a turbo Peugeot. Wheels are probably an 8.5 on a scale of 1 to 10 and even still have the center caps. Wondering what someone would pay for them.
Serious Problem. 95 Legacy LS
john in KY replied to violet12877's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNext time it dies on you, check for spark. Still have a strong spark, suspect a weal fuel pump. 16 flashes means you have a transmission problem. Won't hurt to pull any stored trouble codes. Most auto part stores will do this for free.
lack of power. help a brotha out.
Ignition timing retarded/clogged exhaust/weak fuel pump/clogged fuel filter?
front differential 85 xt 4 cyl. turbo automatic
Turbo cv axles and NA axles are different.
Adding a Start Button - Where's the Starter Relay?
Won't it just be easier to hotwire the radio?
92 Loyale mystery overheat
Pinhole leak in one of the heater hoses?
Is it the power steering pump or alternator?
john in KY replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen my alternator bearing failed a few years back I first noticed that chirping sound. Noise got progressively worse over a two week span. When the bearing is on its last leg the alternator will be too hot to touch after just a short drive.
Major Engine Problems Rendering My Car Useless
john in KY replied to zues marine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.obd-codes.com/p0106
need HELP fast on EA82
Maybe when you installed the new seal, you managed to dislodge that spring on the backside of the seal. The new seal should have stopped the leak. Either the original seal was bad or the crank snout was worn but if worn, that should have been obvious. At one time you could buy repair kits for a worn crankshaft. Just a thin wall tube that slid over the damaged snout.
xt6 suspension under ea82
You'll need the control arms to use the sway bar. Have a pair of new XT6 rear FWD shocks if interested. Grab the MC also.
Leaking Coolant from Throttle Body Preheat Line
Also a line that runs to the turbo. My money on this one and it is a bear to replace.
1988 GL EA82T Rebuild HELP
Engine needs to be rotated a full 369 degrees, not 180, after installing the first belt. Need to also use the correct marks on the flywheel. But having said this, the engine would have fired on 2 cylinders even if the second belt was installed out of phase. I know this because I didn't install the second belt correctly the first time I did a timing belt job and the engine ran on just 2 cylinders. So it appears the distributor timing is way off.
