john in KY
7
Everything posted by john in KY
1989 GL Sedan - Dead AT or Diff?
john in KY replied to cocheeze's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No, totally different. A turbo EA82 transmission will work but you have to use its CV axles. -
Need more power at same boost
john in KY replied to vagen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dump the stock exhaust after the turbo except for the flange that bolts to the turbo. 2 !/4 inch exhaust all the way back from the turbo does make a difference and fits the original exhaust flange perfectly. Ran 12 pounds of boost for 5 years/almost 100k miles in my old turbo wagon with a few modifications and never had a lick of problem with the set up. -
mazda rotery engine transplant, is it possable?
john in KY replied to hotrod_sol's topic in Subaru Transplants
Some west coast company (Kenny or something like that) years ago actually manufactured an adapter for the rotary/subaru combination. I even saw one on ebay maybe 8 years ago for sale. That company I think is the same one that still manufactures kits to install Subaru engines in VWs. -
xt-6 front axle spline question
john in KY replied to robert_the_sane's topic in Old Gen.: 80's GL/DL/XT/Loyales...
XT turbo axles and XT6 axles share the same inner joint so don't buy on spline count alone. What I am saying is a manual FWD transmission from an XT turbo will swap into an XT6 without changing the axles. -
need advice about buying 84 gl turbo wagon
john in KY replied to afterbang's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Guy down the road has an 85 or 86 turbo Brat. Original owner, drives the crap out of it and will not sell it. I don't think he bought the only good turbo EA81 ever made. -
Use some long bolts with the heads removed. Screw two into the bellhousing and they will act as "guide/alignment pins".
Newer Subaru weather band radio in GL...
john in KY replied to kybishop's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did it in my wagon years ago. Problem is you can't fully install the radio because the newer radio will bump up against the heater stuff under the dash. New radios are a lot deeper than your OEM radio. Somewhere I found an "extension" trim piece that made the install work. Can't recall where I got the new trim piece/housing and doubt if it is even made anymore. Isn't this weather nice? Freezing my butt off. -
Impreza 4EAT into a 1990 Loyale Turbo?
john in KY replied to eulogious's topic in Subaru Retrofitting
Tailhousing is different. The rear mount is slightly diifferent but you can swap that. Also the Loyale 4eat should have a 3.70 ratio and the Legacy a 3.90 so that will have to be swapped. -
If a 5 foot length of exhaust pipe doesn't do the trick, 2 minutes with a good small chisel and 3 pound hammer will. I've split more then a few that way. Really don't need to completely cut the nut. When close to being completely through, use your impact and it will either loosen the nut or complete splitting it. Amazed your 3/4 impact couldn't loosen it but that got me to thinking there is a relationship between the maximum torque an impact will produce and air pressure. Thinking a 900 lb-ft gun will not produce anything close to 900 lb-ft if not powered by a very large compressor.
New to air ride suspension.. Need HELP!!
john in KY replied to My92SVX's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Getting close to solving this then. New compressor, no air in tank, no air through the strut solenoids means the compressed air is being lost before making it to the tank/strut solenoids. Just about has to be the solenoids are not opening/clogged or there is a massive leak somewhere between the compressor and tank or at the compressor. Soapy water may be your next step. -
Just because the compressor runs, this alone doesn't mean it is any good. If you run the compressor with one of the front strut solenoids open and if that strut does not fully inflate in less than 5 seconds, the compressor is worn out. You stated you have run the compressor for 10 minutes, removed the tank solenoid and found no compressed air. If the tank solenoid is functioning and if the compressor is actually putting out compressed air, where did it go? -
The tank has a pressure switch and a solenoid. The pressure switch activates the compressor when low tank pressure is detected. Sounds like one or both may need cleaned. You seem to know how to manually operate the compressor relay and how to manually open the strut solenoids. Open a strut solenoid and jump the compressor. that strut should immediately pump up if the strut relay is indeed open and the compressor is producing adequate pressure. The strut solenoids can be taken apart and cleaned. Basically nothing more then a magnet and disk inside of them. There is a system CU under the carpet under the driver's seat. It can go bad but not often. Rust seems to be the only thing to kill them. May want to take a look at it checking the grounding point. -
Did you also swap the distributors? Thinking there should be major differences between the 86 and 90 whatever. And a second installing the original intake.
