john in KY
7
Everything posted by john in KY
'91 loyale automatic shifting problems
john in KY replied to mrairrikk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check to see if you reattached the vacuum line that runs from the intake down to the vacuum modulator. If the line is attached and there is oil inside it, the modulator needs replaced. About the only other thing is the governor is bad. may want to do a search for "apple core". -
Pulling Engine/Tranny together? (EA82)
john in KY replied to esteveW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've pulled at least 1/2 dozen engines/transmissions as a unit. Fact is have never pulled either separately. -
The LSD takes a special lube. I still have some somewhere. I'll post a PN if I can find it. K0904AA080 PN probably obsolete but Anthony's Subaru in BC was able to get it for me about 8 years ago.
I Need some help on my ea82t 86 Gl-10
john in KY replied to 86deathwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No. Don't use the stop-leak stuff. You'll regret it if you do. If you have a leaking HG, you would know it. Good chance this minor coolant lose is caused by a pinhole leak in one of the hoses. Check the hoses that run to the heater. Will only leak under pressure. -
Nobody seems to sell u-joints
john in KY replied to Dr. Fresh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.rockforddriveline.com/replacem.htm -
Remove the center console to expose a rack of relays below the radio. Don't know their functions but the wires are color-coded so should be easy to identify a cut wire. but first check all the fuses.
Also check to see if the rotor turns when cranking the engine.
Wanting Help----My New "89 Omega
john in KY replied to Azza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What size is the EA86? -
I guess if you turned the input shaft by hand and shifted through the gears, that could tell you how many gears the box has.
30-year old radiator may be a contributing factor.
Will also need to swap the differential as the turbo transmission will have a 3.70 ratio.
Dealing with right rear bearing 89 gl wagon
john in KY replied to abcus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Photo attached, hopefully. Photo of the stubby shaft with bearing. Left side shows that nut that needs removed and what a pin socket looks like. -
Short answer is no. To remove the stubby splined shaft, have to remove that nut on the backside of the knuckle. Right way requires something called a pin socket. Or if you are good with a hammer and punch, you can loosen it that way. -
engine oil in my air filter
john in KY replied to bicycle_ben's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Remove and clean all the PCV hoses and replace the PCV valve and you should be good to go. -
That box next to the battery contains the 4 fusible links. Test connector should be close to the brake MC. If I am reading what you posted correctly, you have fuel flow. Have you checked for spark? Fuse box should have one marked IGN. Good idea to check that one. Remove the distributor cap and verify the rotor turns while cranking the engine.
Did the original tires survive the trip?
Wheel and bolt pattern exchange
Ten-year old tires that have been flat will have flat spots you won't believe. Don't plan on them making that 120 mile trip. -
