john in KY
7
Everything posted by john in KY
6 lug hub and break issues, 87 gl wagon
john in KY replied to adot's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If by hubs you are referring to the wheels, my guess is everything else will be stock Subaru stuff. Edit: If the curent calipers also contain the E-brake, then everything other than the wheels are stock. -
Brake pad seized on Loyale
john in KY replied to Nowah9's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Does this model have the hill-holder feature? -
"You can try soaking it with AeroKroil or other rust penetrant but your success may vary. Sometimes using a chisel to open up the split assuming you got the entire pinch bolt out." That's the technique I used to remove the last ball joint I did. Took a couple of three days but that Kroil will eventually "eat" that rust. Had the knuckle off the car. Don't know what your time is worth but new knuckles on eBay for around $80.
A complete new engine will be very expensive. I think a rebuilt chart block goes for around $2500. Check out car-parts.com for a used engine. If this was my problem, used engine all the way. Rebuilding your engine will be very expensive. Crankshaft/ rods/bearings/labor...wow. Currently live in KY but originally from Ohio. Hooked up with the ex while attending school in VA.
From your description of the problem I won't throw money at the original engine. Subaru offers a factory rebuilt short block or source a low-mileage used engine. Replacing the engine itself is not rocket science and the kid down the street can probably do it for a few hundreds. My ex is from Pico Rivera. Good chance you probably dated her as I learn over time the girl really got around.
Be careful if you have to remove the air lines. Those plastic couplers are easy to snap. A short plastic straw spot longways makes an excellent tool. The XT6 used the same compressor and I think the 1st generation Legacy also used the same part.
I don't know but thinking 2 types of rotors. One type requires a set screw. May want to check the rotor. Just remembered the coil bracket must have a good ground contact.
From experience, removing the inner joint from the differential will test your patience.
hello from Latvia
john in KY replied to rex_saugerty's topic in Meet n' Greet. Your USMB Welcome Center
Welcome. -
First Time Subie Owner - 1986 XT Turbo
john in KY replied to Whitestorm's topic in Meet n' Greet. Your USMB Welcome Center
Don't know if it was an option but my 85 had one. -
Looks like either an 85 or 86. I just happen to have a blue steering column cover if interested. -
I'll take a shot at it. The switch in the overhead I would think is sort of 2 switches in one. In one position it allows current to flow in a direction that causes the motor to turn CW. In the other position the current through the switch flows in a different circuit allowing the motor to turn CCW. Because you believe you have current leaving the switch, you are testing only 1/2 of the switch. Just guessing here but there could be 2 wires on the motor side of the switch. One will be hot when the switch is one position and the other cold. Place the switch in the other position and the cold wire should now be hot. Could always pull the headliner and then test the motor or what I would do is just replace the switch. A member over on the Subaru Outback forum, can't think of his handle, helped me a few years ago when I had sunroof problems.
- 4 replies
- sunroof
- troubleshooting
(and 1 more)
Tagged with:
