john in KY
7
Everything posted by john in KY
My new 1986 XT won't start, help?
john in KY replied to derburger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Blown Head Gasket - Water Damage??
john in KY replied to Major Lazy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://cgi.ebay.com/ebaymotors/1987-SUBARU-XT-TURBO-ENGINE-USED-1-8L-P170J_W0QQcmdZViewItemQQcategoryZ33615QQihZ010QQitemZ200301234565QQrdZ1QQsspagenameZWDVW -
Transaxle Bearing? Popping, clunking noise
john in KY replied to blinkibus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Damaged hub splines? Loose CV axle nut? Loose brake caliper? -
Leave the ball joint attached to the hub. Remove the nut at the bottom. Rent a "pickle fork" at Autozone and a big hammer. Insert pickle fork between the ball joint and control arm and wail (?) away with the hammer. Remove now loose ball joint from hub and replace with a new one. Really not difficult at all. edit: You did remember to reinstall that clinch bolt when you replaced the axles?
Check condition of fusible links near the battery. You will loose spark if the coil bracket is loose. May want to remove it, clean the contact points and make sure the mounting screws are tight. Thinking that jar from the speed bump loosen something.
88 GL-10 EA82T auto Transmission case & shaft
john in KY replied to M45's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That bent rod has a good amount of adjustibility. Just make sure the shifter is in sync with the transmission. By this I mean when eg the shifter indicates D, the transmission is in D and not say R. -
EA-82 Sinking brake pedal
john in KY replied to paulpicard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Make sure you bench bleed it before installing. -
CV Joint Broke (All fixed! Next Project)
john in KY replied to Keiji22's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I checked Rockauto and there the 607008 is listed for the manual transmission and 607009 fits the automatic so you are correct. -
Urgent: Drive shaft broke: 88 GL10 turbo AWD
If just the rear housing is cracked, which usually is the case, it can be fairly easily replaced. Much easier than replacing the transmission. -
Old Gen. Subaru Guard Dog
john in KY replied to Quidam's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Saw an 84 GL wagon there today. That soft yellow color. Bumpers, grill, doors looked very good. Also noticed the tan dash was without cracks. May post a photo later of the dash. Anyone locally interested go to row 4 or 5 and then walk back to the fence. It is the last car in one of those rows. Too far away for me to pull parts.
I have one I just recently pulled from an AWD XT6. PM if inereseted. John
I believe I'm in need of a new clutch....
john in KY replied to 92loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If it worked fine until the cable was replaced then cable not adjusted or the fork cracked. -
Just recently stripped an XT6 and pulled the tank. Real pita because the rear differential has to be dropped. Also there are a lot of lines associated with the tank which didn't concern me since I was only after the tank. But maybe you have a FWD which will make the process easier. Not the end of the world but give yourself at least 1/2 day.
