john in KY
7
Everything posted by john in KY
Possible new owner
john in KY replied to smkauffman's topic in Meet n' Greet. Your USMB Welcome Center
'Rust is also a huge deterrent in your area - check the underneath like the rear suspension, brakes, and exhaust which could look like scrap metal ". Replacing rusted undercarriage parts is not fun. -
I don't know either. Edit: Checked another site and you are correct. My bad.
- 18 replies
- quick struts
- raising
(and 3 more)
Tagged with:
15 inch wheels will probably not clear the front brake calipers but easy to check.
- 18 replies
- quick struts
- raising
(and 3 more)
Tagged with:
86 XT DL fuel pump inoperative
john in KY replied to The Cycle Guy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did you completely drain the old fuel? I once dealt with 20-year old gasoline and it is nasty stuff. Just mentioning this because the pick-up in the tank could be clogged. -
Welcome back.
My 95 had very similar symptoms. Over on the passenger side mounted on the inner fender is something with 2 vacuum lines. One of the lines was disconnected. Plugged it back in and problem solved. This solved the stalling problem. Your other problem, engine racing, almost always an air leak. Check all those hoses the connect with the air intake tube.
05 impreza
john in KY replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I think it will depend on the year of the 2.5. -
Just returned from the wrecking yard. Yard had only one Subaru and someone before me had damaged that trim piece. Post in the parts wanted section and I am sure some of the west coast members will have that part. Subarus in KY are fairly rare and everyone and their brothers owns one in the PNW. John
Needle-nose grips would be my choice. I checked a spare transmission I have and only one bolt secures the tube. I didn't read all the posts that closely and assumed you needed that trim piece above the radio that I have. Now I see you need the trim piece below what I have that I don't have. Will take a trip to the local wrecking yard tomorrow and will pull that piece if one available. How does $10 sound? John
That socket is out there. About 20 years ago I bought a pin socket that was a perfect fit for my XT6. Problem is I can't remember from where or how I seleted that particular pin socket.
