john in KY
7
Everything posted by john in KY
I'll see what I can find. Where in NE Ohio? Originally from the Warren/Youngstown area.
Neither is true. The XT6 has a FSM nd the ECU will store/flash DTCs.
legacy knuckle in ea82 5 lug conversion
john in KY replied to MilesFox's topic in Subaru Retrofitting
Used the FWD axles only because the length is close to the XT6 axle. -
Miles, this combination worked for me when I converted my FWD XT6: 2002 hubs,springs and struts reused the XT6 top hats Legacy FWD axles Car maybe sits an inch higher in the front but has none of the problems you have described. The XT6 axles can be made to work with the newer style hubs. Just take the outer joint to a machine shop and have that seal surface machined down to accept the newer style grease seal. I had this done for something like $30 but for some reason didn't use the modified XT6 axles when I did the conversion. Wish I could remember why but can't. I don't think you will ever get the ride height right using the Legacy struts. -
head gaskets? or maybe not?
john in KY replied to subarubuddy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Automatic? May want to check the vacuum modulator on the transmission. -
Stupid question, please forvgive me...
john in KY replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Has to be screwed into the intake manifold somewhere. Look around on the backside of the manifold, maybe on the driver's side first. -
Puh-leese, Hep a bruthuh out !!!
john in KY replied to HiPlainsShifter's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I still think the problem is you have the spark plug wires at the cap in the wrong holes. Also thinking you are using that "1" stamped on the cap as the starting point. Because the cap can be installed 2 ways, there is a 50/50 chance the "1" can be on the wrong side. Pull the wires from the cap. Remove cap, turn it 180 degrees, and reinstall it with the "1" on the other side. Reinstall wires starting with the "1" now on the other side of the distributor and see if that solves the problem. -
heater core in - no start!
john in KY replied to Stevethefolkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bet you a box of doughnuts the problem eventually will be discovered to be part of some wiring harness not connected. have pulled a few dashes myself over the years and know from experience it is very easy to overlook one or two connectors. -
I've done it more then once. Working on something and then not getting back to it for days/weeks and forgetting/confusing where I stopped. -
It' a possibility but the first time I replaced timing belts, and not knowing at the time the engine needed to be rotated after installing the first belt, that engine fired right up on just two cylinders. Still believe the firing order is wrong. Thinking since you had replaced the cap and rotor so many times you got the wiring order at the cap 180 degrees off. -
Even though you have rechecked the firing order, my money is on the firing order is wrong. I mean all you did was change the cap and rotor. -
What if you installed that bevel washer upside down?
Engine from the netherworld
john in KY replied to mudman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Runs at rpms above idle but will not idle? You have an intake manifold vacuum leak somewhere. -
Tire Chains in the mud?
john in KY replied to wncsubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Once you lose forward momentum and one or both wheels continue to turn, you'll find yourself on the frame before you know it. At least that's what a truck I had years ago would do. When I stuck it, it was really stuck.
