john in KY
7
Everything posted by john in KY
Pressure is great but the pump is still most likely sucking air. Reseal it first before doing anything else.
Also suspect a leaking FPR.
94 Loyale quit running
john in KY replied to xjoffroad92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
CAS is located inside the distributor. Since you have spark I would ignore it. Engine has 2 timing belts. I would check the other one before going any further. -
Need parts for 1986 turbo xt
john in KY replied to neximile's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think that bumper style was used only on the 85 and 86 models so it is going to be difficult to find. Another option would be to just replace the entire bumper. Any 87 and newer XT or XT6 bunper shoud just bolt on. -
Loyale... 2 Alternator laters, still no charging
john in KY replied to bfdtech's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Is the instrument panel charge light working? Read somewhere if the bulb is blown the alternator will not charge. -
May be nothing more than a bent dust shield or a loose caliper.
Loyale Tail, Dash & Head Light Conundrum
john in KY replied to Milemaker13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Relays located directly behind the instrument cluster, all in a row. -
I'm having some major EA82T issues
john in KY replied to i_c_the_light's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ruptured FPR? -
88 GL-10 Turbo won't idle
john in KY replied to cobcob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Remove the vac line going to the PB and plug it with a bolt. My XT6 will idle all day with the air intake tube removed. Fairly sure it will idle even with the airflow meter unplugged. When the engine is idling, essentially no air goes pass the throttle plate in the throttle body because it is in the closed position. "Idling" air is the function of the IAS system. If the IAS allows too much airflow then the idle increases. Too little and the engine dies. Just a few thoughts. -
starting to get sick of all the problems
john in KY replied to EYE_WHY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Look for a white cannister looking thing over on the passenger side of the firewall. Good chance one of its vaccum lines has cracked. lose this component and none of the interior vacuum powered switch will work. Losing exhaust gaskets because the nuts are loosing. Have you tried brass exhaust nuts? The boot is being ripped either because something is catching it after it is installed or it is ripped during the installation. Really the only 2 possible reasons. -
Need ideas on overheating problem
john in KY replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's the radiator. -
That single cylinder miss only at low rpms is probably an intake manifold leak. Check that small vacuum line close to #1 cylinder. If cracked or disconnected it will cause what you describe.
I've been told a timing belt on the verge of breaking will cause the sound you described.
overheating 86 xt turbo - need help!
john in KY replied to Xturbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mike is right about the radiator. Even if the problem is learned to be something else, your radiator is junk. After 20 years at least 70% of those little cooling tubes are now clogged. Someday I am going to buy a 20-year old Subaru radiator, pull the tank and take a picture of the internal tubes. -
Ball joint drama - Fried ECU??
john in KY replied to Virrdog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If not the battery then suspect popped diodes in the alternator. Once they go current can backflow from the battery giving you a dead battery. -
I did this once but went the other way converting a FWD into an AWD. Swapping the tailhousing solves most of the problems. Only other problem is the internal wiring harnesses between the 2 are different. One has an external VSS and the other (the FWD) has it internally inside the housing or was it the other way around? Got to drop the pan to change the harnesses. Forgot to mention the rear mount is different so get the one on the FWD 4EAT.
Really sounds like the starter. Bet it gets pretty hot when you attempt to crank the engine. -
OT: Photo-posting test.
john in KY replied to john in KY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Car was originally pearl white. Didn't like it all that much because even though I prefer white over almost any other color, it was just too white for me. A door was damaged so I had MAACO repaint it in a flatter shade of white. Huge mistake. Paint has recently started to flake off in large sections. MAACO never primed the car even though I payed extra for it. Think it was also $50 extra to remove the decals. Right. About a year after the paint job I was waxing the car and discovered all the decals are still in place. MAACO just took my money and painted over them. Still have overspray on all the black trim pieces. Total bill was around $800. For $800 I ended up with a no more than $100 paint job. Recently been thinking about this royal screwing. Still have all the paperwork and written lifetime guarantee. Will have no problem proving the decals were never removed and the car was never primed. My problem is I will NEVER allow MAACO to touch a car of mine. Been kicking around the idea of just going straight to small claims court for a full refund plus the cost of removing this crappy paint job. No way it can ever be just repainted over this crap. edit: Notice that white streak between the bumper and front fender? What you see there is a streak of the original paint. MAACO's finest paint job in my case hasn't held up very well. -
89 GL XT 4wd... Its here... Fixed on page 3...
john in KY replied to 86BRATMAN's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice notion but I somehow really doubt that. -
My guess is you blew one or more diodes in the alternator. This can explain the dash lighting up but not the no-start problem. Does the fuel pump still work? Another guess is if it doesn't then the ECU has been damaged. Would first physically check all the fusible links for damage before going any further with this. And I have welded on stuff without touching the battery or ECU and got away without any problems.. -
89XT6/parking lot.jpg DSCN0075.jpg Just attempting to learn how to post photos. Well, that didn't work.
I have a FWD XT6 FWD 4EAT out in the shed I bought years ago for a spare. It still has the rear mount and bracket. Don't know if it is the same as that used on the AWD but I could take a picture if that would help.
Don't think he ever did. Hard to remember after 6-7 years. Do recall Greg broke the tailhousing on his 89 XT6. Someone gave him another tail section from a 1st generation Legacy and that is when it was learned the mounting pads were different. Original poster has a couple of options. Could find a tailhousing from an early 4EAT. (Someone on ebay last wek was selling parts from an early 4EAT.) Other option would be to cut the center section out of a newer crossmember and use it to replace a section of the Loyale crossmember. Just FYI I would think a 4EAT crossmember from an XT or XT6 would bolt into the Loyale.
