john in KY
7
Everything posted by john in KY
XT turbo injectors not firing? SOLVED!!
john in KY replied to joostvdw's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the injectors are batched fired. Don't offhand know if the front 2 cylinders are a pair but check the plug wires at the distributor. If the front 2 cylinders are directly across from each other then they are a pair. good chance there could be a short in the engine wiring harness. Somewhere in the wiring harness the individual wires from the paired injectors join and become one wire. Hopefully this happens in the engine harness. Identify the wires for the injectors and then unplug the engine harness and check for voltage on the car side of the harness. Offhand I think the CAS in the distributor has something to do with the injectors firing. Don't know if this year used a dropping resistor but that is something else to check. I'll look at the FSM tonight and get back with you. -
I remember seeing saw mill engines many years ago that were started on gasoline and then switched to kerosine when up to operating temperature. These engines then ran literally all day without any problems.
Strut questions, 92 Loyale wagon 4WD
john in KY replied to msteel's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The last set of Gabriel struts I bought for a Subaru ended up in the trash. When I went to tighten that top nut the stud just twisted off. The nut wasn't even close to being tight. Maybe I just got a bad strut but I figured if the quality of the material used was that poor, the hell with ever using that brand again. -
2WD rear struts are longer than the AWD struts. Gabriel made good stuff many years ago. Not true today. If you gave me a set of Gabriel struts, I would give them back. -
Back in the late 70s I lived in VA and had a 69 Austin American (English FWD) with clicking CV joints. Didn't at the time know anything about CV axles and just thought it was normal. Drove the car for several years around VA. Made numerous trips to Ohio. One trip to Chicago and another from VA to LA and back. When I finally scrapped the car it still had the original clicking axles.
I would. Check the ECU in the trunk for any stored trouble codes. Remove the air intake hose and see if the engine will fire with a small shot of starting fluid. Possibility one or both timing belts are on the verge of breaking and the timing as changed as a result. Does the fuel pump work? Blown fuse maybe? The XT6 is really not that complicated once you get involved with them. I have never seen an LSD in an XT6.
I think your problem is the seals in the turbo are failing.
02 circuit - can it be eliminated?
john in KY replied to thealleyboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Why not just remove the O2 bung from the original pipe, drill a hole in the new pipe and then weld the bung onto the new pipe. I've done this several times. -
Intake Manifold Question
john in KY replied to DasWaff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Probably the vacuum fitting for the vacuum modulator, which you don't have. -
Put the transmission in 3ed or 4th gears. Depress the brake pedal and release the clutch. Clutch is good if the engine stalls.
Fusible llink cross reference.
john in KY replied to PhizzleSubarizzle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Subaru fusible links are also color-coded. For example red = a certain diameter. And wire diameter size equates to a certain amperage. Offhand I don't recall the sizes but I think they can be found in the FSM. You could always just measure the wire diameter of the link you are replacing and just replace it with the same diiameter link. -
Premium Battery Cables????
john in KY replied to chef_tim's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Boat supply businesses will have everything. Check out http://www.genuinedealZ.com first. Other sites I have used are: http://www.wiringproducts.com, http://www.westmarine.com, http://www.wiringproducts.com (if you use these guys be prepared for a long wait. always got what i ordered but several weeks of waiting not uncommon ), and http://www.fastenerhut.com. If you want to upgrade the battery i would go with a dual terminal Optima battery as long as I am plugging companies/brands. I also used the style of battery cable terminal that has an additional threaded stud. I used the stud to mount the alternator charge wire and glow plug feed wire. -
Just made a set for a dual-battery system for my tractor. There are 2 basic types of solder. One works for this application and the other doesn't. Can't recall the 2 types at the moment. What I did was mount the copper lug in a vise and then used a propane torch to fill the lug with molten solder. Then just push the cable into the lug. Use only 3M shrink wrap tubing if you want to prevent future corrosion problems. The other brands I have used are not up to the 3M quality standard. A cable cutter really makes cutting the cable easy. Hacksaw really makes a mess. -
Loose hose clamp?
sudden rise in engine temp when in boost.
john in KY replied to Tosh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Don't worry about it. Every turbo/digital dash I have owned did the same thing. -
not gettinf spark or fuel
john in KY replied to sidewayz soobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Verify the distributor rotor turns when the engine is cranked. No rotatation means a broken timing belt. -
The reason the temp gauge goes up and down is there are air pockets moving through the system. When an air pocket hits the temp probe the needle drops. Then superheated coolant moves under the probe and the needle shots up. If this was my problem I would just bit the bullet and pull both cylinder heads to see exactly what is the problem. Very good chance the problem is a warped head or leaking gasket because the methhead didn't properly torque the head bolts. Didn't you earlier state the engine seemingly ran fine when you first bought the car? If true then this would point to a HG failure. If the air control valve and MAF are the same, PM me your address and I'll mail you an extra one I have.
New member-'93 transmission prob :(
john in KY replied to Marthanna's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What about that vacuum line from the manifold that runs to the modulator? -
TCU = transmission control unit. The CEL doesn't flash. Find the ECU, which should be very near the test connectors, and then find that little "window". this is where the flashes occur. Don't know about the black connector but on older models I always used the green connector with the key in the ON position.
