john in KY
7
Everything posted by john in KY
A Long Shot? A/C Compressor
john in KY replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think there was only 2 types. One type was original equipment, came from the factory, and the other was installed at the dealer. -
Well I sort of suggested it wasn't going to be pleasant. That small bolt had me saying words I didn't realize I even knew. I also need to replace that oil line. Ordered it when I did the coolant line but haven't gotten around to installing it. And I noticed that line under the intake manifold has a rusted area. Well do both this fall when it cools down.
Need some assistance with ea82t
john in KY replied to Kitcarguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thermostat housing confirms the engine is in the 85 to 87 range. -
This engine has the dual port heads. Engine offered from 85 to 1990. Exhaust gaskets the same for all years. Any model with the turbo option, no difference. Thinking I may even have a set in the garage. -
Looks like the AFM is the "flapper" style. Was only used in the 85/86/87 models. Also can tell if it is from one of these years is to look at the thermostat housing. Fairly sure the distributor changed in 1988. Cylinder heads the weak link. 3 versions used over the years. Early version tended to crack. -
Problem could be the hill-holder if so equipped.
No fire on cylinders 2 and 4
john in KY replied to Jmpjose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Verify the firing order: 1324. Do a compression test. Check valve clearance. -
I have no idea other than the noise appears to be coming from that area and once the engine is pulled, a visible inspection should show the source. TC failure is very rare and that greasing the rear main "solution" seems pretty far fetched to me. I would suspect a cracked felex plate way before a failing TC. Just recently pulled and reinstalled an engine in my 08 and not that bad a task and I have you by 15 more years.
Can't remove bolt in EA82 Crank Pulley
john in KY replied to 3crows's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Use a 3 to 4 foot cheater bar and may consider moving up to a 3/4 inch socket/breaker bar. -
Brat Starter Electrical issue. Help
john in KY replied to ajslacker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The distributor has nothing to do with the cranking of the engine. Heck, engine will crank with the distributor pulled. -
problem assembling 5MT ....
john in KY replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wonder if a really strong magnet could move that pin? -
Once had an 85 XT turbo FWD that had the 3.54 differential.
