gemery10
Location
Lismore
gemery10's Achievements
Advanced Member (3/11)
10
if all that fails the actual guage can be faulty. I've seen it happen recently
In Australia in my little town we had a heap of subarus doing this, mine included. Bad fuel plus crappy gasket kits can clog little lines in the carby. Only solution was soak carby in cleaner and install paper gaskets. Mine stopped that and just started running crap so eventually I put a weber 32/36 dgv and I'm definately not going back. They are really simple to work on and the engines sounds much healthier.
running 13's with weber I get 28-34 highway. Running 14's seemed to eat more gas. But is everyone calculating for bigger tyres?
Timing Belt Covers - Yay or Nay?
gemery10 replied to mrroot's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Rocks, mud, water, grass. But where oh where is the sand,salt more sand? Anyone beach it without timing belts? -
sometimes it pays to check the float height as the hitachi are quite sensitive to it. I've had bad mileage off and on with hitachi and just recently swapped to weber. I'm definately not going back. greg
Ah. thought so, my throwout bearing is stuffed anyway but I have noticed more slop in the system without the spring. 2wd subarus aren't very common around here, any idea where it should be hooked up. thanks for your help, greg
I couldn't undo the cable on my hill holder so I cut it off at the clutch end. The manuel says the hill holder was part of the return spring setup. Can I run without it or do I rig up a small return spring? thanks greg
You guys rock! I hate those ##$$%%## covers. Hadn't heard of anyone doing this but was considering at least splitting the bit behind the pulley -
adaptor plate bolts prob (weber conversion)
gemery10 replied to gemery10's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm in Aus and redline weber doesn't exist. Had to go the new thread option better anyway as have nice big 8 mill bolts now. next job is get it above the aircon. ahhggrr. thanks guys -
thanks, I think your right this is the second time i've gone back -
you guys rock. thanks heaps. Bottom line I can run with one line till summer or I get a round to it
hey guys, Im in the process of putting in 32/36 dgv carb into ea 82. I only have one fuel line in that elbow. Is that normal? What happens to the return line already there for the hi carappy
my 86 leaked out cam cover gasket on both sides and had a stuck pcv valve. It seemed to use oil about the same but when I fixed those I don't use any
