Abs and at CEL after battery change
somick replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXErase all codes. After that turn the the key to ON (do not start the car!). Wait fifteen seconds. Start the car. You still may experience some rough idle. Keep driving. If the idle does not get better do the "idle learn procedure". Hopefully it is that simple. Good luck, Sam
Replacing fuel pump 91 Loyale ea82, compatibility?
https://www.amazon.com/gp/product/B07FZ5YKXT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Worked fine for a couple of years until I sold my car. Good luck, Sam
Unable To Remove Key From Ignition
somick replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck out with the dealer. It might be covered by the TSB. My grandson's 2017 was. Good luck, Sam
I want to sell my 1992 Loyale 2wd
Sorry, this is a 4 door sedan.
Oh and I forgot to mention that the head gasket was done at 187000 miles.
somick started following I want to sell my 1992 Loyale 2wd
I wonder if anybody is interested in buying my one owner 1992 Loyale 2wd. 197000 miles. Still driveable, I drive it around the town. I live in the area between LA and San Diego but it will make it to wherever you need to take it. Heat works. . The car will come with some extra parts (brand new front shock (one), used oil pump, brake pads). Things not working: AC (probably low on R12 refrigerant) Shift interlock (sometimes works) Driver side shoulder belt (sometimes works) Some rust holes (passenger sided fender) Thanks for reading, Sam
My horn is possessed.
On my 1992 Loyale my son used to honk the horn with his fist :). No surprise that after some time the horn started honking on its own. I removed the top from the steering wheel, bent down those tabs and it is fine since that. Worth to try. Good luck, Sam
2009 Legacy AWD Won't Shift into Overdrive
somick replied to palfer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas the fluid ever replaced? Good luck, Sam
Subaru Legacy 2008 power steering transmission fluid
somick replied to Lonnie2008's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTurn the steering wheel all the way from right to left (there is no need to start the engine). Easier done with the wheels in the air. If the fluid level drops add more fluid. That is how you bleed the power steering system. Whoever installed the new pump probably did not bleed the system correctly. Good luck, Sam
85 Subaru Brat 4wd No spark from Coil
Check your timing belt. Good luck, Sam
Oil viscosity questions for H6 EZ30d phase 1. Anyone have direct experience with Liqui Moly oil?
somick replied to laegion's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI love the attitude of @GENERAL DISORDER II - that is the way to be when you believe in what you are doing but my Camry, Accord and Loyale ALL easily reached 200, 000 miles with the cheapest oils I could buy, the factory specified viscosities and 5,000 miles oil change intervals. The only rule I have - I avoid Fram filters at any cost. My Forester is at 122,000. I may be lucky... Sam
Needs ECM?
At the ECM connector try to find a wire that sends voltage to the injector and connect a test light to it. If it lights it could be a broken wire like Dave mentioned. Good luck, Sam
Finding part numbers - 3AT & general
I have bought them many years ago but never changed them. Since they were sitting in the same package I assume they all go to the driver side of my 3AT. I hope this helps. Sam
- question about transmissions
2012 Impreza P0340 Cold only
somick replied to FL$ubietech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you post your question in "1990 Subaru" subforum you will get more views/replies. Good luck, Sam
