2
Everything posted by somick
Replacing fuel pump 91 Loyale ea82, compatibility?
somick replied to BCO's topic in Old Gen.: 80's GL/DL/XT/Loyales...
https://www.amazon.com/gp/product/B07FZ5YKXT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Worked fine for a couple of years until I sold my car. Good luck, Sam -
I want to sell my 1992 Loyale 2wd
somick replied to somick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sorry, this is a 4 door sedan. -
Oh and I forgot to mention that the head gasket was done at 187000 miles. -
I wonder if anybody is interested in buying my one owner 1992 Loyale 2wd. 197000 miles. Still driveable, I drive it around the town. I live in the area between LA and San Diego but it will make it to wherever you need to take it. Heat works. . The car will come with some extra parts (brand new front shock (one), used oil pump, brake pads). Things not working: AC (probably low on R12 refrigerant) Shift interlock (sometimes works) Driver side shoulder belt (sometimes works) Some rust holes (passenger sided fender) Thanks for reading, Sam
On my 1992 Loyale my son used to honk the horn with his fist :). No surprise that after some time the horn started honking on its own. I removed the top from the steering wheel, bent down those tabs and it is fine since that. Worth to try. Good luck, Sam
Turn the steering wheel all the way from right to left (there is no need to start the engine). Easier done with the wheels in the air. If the fluid level drops add more fluid. That is how you bleed the power steering system. Whoever installed the new pump probably did not bleed the system correctly. Good luck, Sam
85 Subaru Brat 4wd No spark from Coil
somick replied to MrBrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check your timing belt. Good luck, Sam -
I love the attitude of @GENERAL DISORDER II - that is the way to be when you believe in what you are doing but my Camry, Accord and Loyale ALL easily reached 200, 000 miles with the cheapest oils I could buy, the factory specified viscosities and 5,000 miles oil change intervals. The only rule I have - I avoid Fram filters at any cost. My Forester is at 122,000. I may be lucky... Sam
At the ECM connector try to find a wire that sends voltage to the injector and connect a test light to it. If it lights it could be a broken wire like Dave mentioned. Good luck, Sam
Finding part numbers - 3AT & general
somick replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have bought them many years ago but never changed them. Since they were sitting in the same package I assume they all go to the driver side of my 3AT. I hope this helps. Sam -
I recommend you to post this question in the "1990 to present...." forum here on USMB. You will get more views and answers to your question. Good luck, Sam
How to remove EA82 SPFI TPS?
somick replied to Phil Hyde's topic in Old Gen.: 80's GL/DL/XT/Loyales...
As far as I remember you are correct. Either the throttle body needs to be removed or the AC compressor. But if you unplug the connector you can test in place. There is a testing procedure in the FSM Good luck, Sam -
I guess you get no codes? TPS may be acting up. Could be a poor contact at the TPS connector. How about the regular stuff: distributor, wires? Good luck, Sam
Are you going to save the freon if you have any?
