2
Everything posted by somick
Open a panel below the steering column. You will see your ECU with a tiny bulb in the center. Turn you key to ON (motor not running). Count how many blinks you have. Come back here and search for answers. Good luck, Sam
I once tried to leave the old crush washer in. It did not leak it POURED. I switched to a copper one and stll using it. Probably for 15 years by now. A month ago I bought a crush washer from a dealer for my new Forester and they charged me $1.20. What a rip off! I did not use it, because I bought another copper one. So far so good! No leaks. Sam
Rockauto has new EA81 Exhausts
somick replied to aaronxs400's topic in Old Gen.: 80's GL/DL/XT/Loyales...
rock auto has very inaccurate database. You will get more troubels than you gain anything. Sam -
Parts
somick replied to Tahoe Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Be carefull with rockauto!!! Their database is very inaccurate... Sam -
They have mostly newer generation Subarus. No Loyales there... Sam
92 loyale smoke from under transaxel
somick replied to analog.anarchy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Flush - NO, drain and refill - YES. -
Master Cylinder rebuild kit??
somick replied to Skunk#1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Beware!!! Rockauto's catalog is very inacurate!!! Sam -
My coolant is leaking through the heater core. But the whole expantion tank is of course too much coolant to not notice it dripping on your legs. Try to do a compression test. It should tell you the conditions of your head gasket. Good luck, Sam
http://www.ultimatesubaru.org/forum/showthread.php?t=48341 See if that link will help you. Good luck, Sam
Three times I received wrong stuff from them. Since I am in California: three strikes and you are out. No more rockauto for me! Sam
rockauto's catalog is very inacurate! Beware.... Sam
Travis' 88 Wagon FIX "Build"
somick replied to Travisthedrumer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I beleive it is M8x1.25, like garry said. While in the store get few different sizes Good luck, Sam -
Follow your exhaust manifold. It is right before the mufler. Good luck, Sam
1993 Loyale Timing Belt Isuses
somick replied to thegogoboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
See if the idler spins freely. (A sprocket mounted to the engine body.) That what broke mine. Sam -
See if that helps: http://www.ultimatesubaru.org/forum/showthread.php?t=100559
the high oil pressure fixed
somick replied to bheinen74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
From the original post: 60 and 30 is too high. You guys keep buying from them! It will end up you paying more: they sent me wrong parts THREE times! Charged me for shipping... Good luck, Sam -
Suppose to be: running 0 to 45 (depending on conditions) Once again: rockauto got another victim! Sorry, Sam -
I will stop by and see what they have for future, but as of now it is too late to return used hoses to the dealer. Thanks, Sam
I failed inspection in Pennsylvania because of ... bad wiper blades!
I learned the hard way the difference between heater hose and emission hose: they fail my smog test with the verdict - "MODIFIED PCV SYSTEM" Could not find any 5/8'' emission hose anywhere. Had to spend 50 dollars at the Subaru dealer for three foot long pieces. I hope this information will help somebody. Sam
SPFI'd brat poor idle and pinging.
somick replied to ihscout54's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If this is automatic, check transmission modulator. Sam -
Open access hole under your spare tire. Rotate your engine clockwise. You will see three lines on the flywheel. Like this: |||. Line up the middle line with the mark on the housing. Check your cam marks now. Sam
Regular channellock will do that. You will loose some ATF, but not much so be prepared to add some. The fluid in the lines will be burnt off in the engine. Do not worry about it. Vacuum is applied to your transmission for gear changes. I do not think you will be able to go far... Good luck, Sam
