2
Everything posted by somick
Make sure your oil sending unit wire is secured...
somick replied to TROGDOR!'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
and ....always have your camera handy!! I am glad you fixed it!!! -
You will need a special tool to turn the piston, but I've seen people doing it with needle nose pliers. A very important note: make sure a notch in the caliper is located the same way it was before you started turning it (not sure but I think it's in the bottom). Otherwise the pad would not seat right. Sam
Coolant leak around the throttle body on SPFI?
somick replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, the metal pipe that comes out of the heater core. It looks like it seats rignt on the top of the engine. The L-shaped rubber hose 5/16 in diameter connected to this metal line goes up into the throttle body. I have a post about it. Tried to replace it with the regular hose but it would not hold long (no more than 12 months). And yes I had small puddles in this area when it leaked. They evaporate real fast, so it's hard to diagnose if you don't do it right away. Sam -
Many problems... Help! 85 GL-10
somick replied to FUJI-HEAVY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a broken wire in my old Chevy that went from the car into the door. Considering the age of the car that might be it. I also heard about poor contact in the connectors inside the door itself. -
It is sad!
I've done mine three times!!! Passenger side was done twice (tried to save $$ and did not replace outer boot and it went bad in 3 weeks).
I hope that this is a right place to post a discount you receive when you make a purchas at www.rockauto.com . Anyway I wisht you guys use it and pass it around as many times as possible. I really appreciate being a part of USMB!!! Below you'll find instructions: - You give this discount code: 344010283343 to friends, neighbors, relatives, the guy at the corner garage--anyone you know who works on cars or trucks. - When someone (including yourself) places an order at www.rockauto.com and enters your discount code, he or she will receive an immediate 5% discount on that order. * If you are using our Java Catalog, enter your discount code in the "How did you hear about us" line of the shopping cart * If you are using our non-Java Catalog, enter your the discount code in the "Discount Code" field of the Shopping Cart and click "Calculate Discount" - The discount code expires on February 7, 2006; so don't wait! You may use this discount code as often as you wish until it expires, but only one discount code can be used per order. **Each month we see people who put the word "discount" in front of their code and do not get the discount. Please enter ONLY the discount code.**
www.rockauto.com usualy ship from the closest wearhouse. Here is a 5% discount: - You give this discount code: 344010283343 to friends, neighbors, relatives, the guy at the corner garage--anyone you know who works on cars or trucks. - When someone (including yourself) places an order at http://www.rockauto.com and enters your discount code, he or she will receive an immediate 5% discount on that order. * If you are using our Java Catalog, enter your discount code in the "How did you hear about us" line of the shopping cart * If you are using our non-Java Catalog, enter your the discount code in the "Discount Code" field of the Shopping Cart and click "Calculate Discount" - The discount code expires on February 7, 2006; so don't wait! You may use this discount code as often as you wish until it expires, but only one discount code can be used per order. **Each month we see people who put the word "discount" in front of their code and do not get the discount. Please enter ONLY the discount code.**
http://www.scoobymods.com/forums/showthread.php?p=15718#post15718 These instructions are a very good . It helped me a lot. I bookmarked it a while ago. I was not even aware about USMB at the time. Now images don't work, but I'm behind the firewall. Anyway, I've done timing belts couple of times. Feel free to ask me questions if you get any. I've found Miles Fox's link with good pictures: http://www.economysuperstar.com/milesfox/subaru/service/timingbelt.htm Sam
good source for valve cover grommets?
somick replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.partsamerica.com/ProductList.aspx?parttype=801&ptset=A&searchfor=Valve+Cover+Grommets http://www.rockauto.com/catalog/catalog.php?carcode=1270134&parttype=5492&partGroup=20&EPImodelID=6148&EPIengineID=3437 Both sets mention "9 per car" -
A very easy way to check timing belts: There are two small windows in the front timing belt covers. Just pop them with a screwdriver and stick your finger inside. DON'T crank the engine!!!
Issues. Update! Please help
somick replied to Allowishus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When I burnt my heater core I got the same symptoms: Lost coolant, Coolant smell, Foggy windows. Do you happen to get fog on your windows? Try to bypass the heater. If you stop loosing coolant that's the problem -
Thanks a lot! I'll try that.
1992 Loyale w/AT. An “L” shaped ¼ hose that goes from the throttle body to the metal heater line on the top of the engine (EA82). The original one lasted me about 8 years. I keep replacing it with the regular hose but it does not last long (about a year). I’ve been thinking of switching to a high pressure fuel line but still don’t know if it’s going to hold it longer (plus the cost: about $14 for a foot at Kragen). Dealer wants $13 for the new one. Doesn’t sound like a big deal, but I woukd rather support USMB!!! then the dealer. Any suggestions? The second question is how to support the site? It is really GREAT!!! (and I want that little DONOR icon at the bottom of my user name………. Even if it’s not tax deductable!!!!!!!! Thanks
Valve cover rocker gasket(LH/RH)......
somick replied to bella's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi Bella, I've just found your post. Check out this site: www.rockauto.com Pick the right vehicle type. When you get to the gaskets (keyword "Valve cover") there should be a button "More info" or something like this. Click on it and in the separate window you'll see the image of the gaskets. A week ago I bought a set for $11.00 + shipping. As far as I know they ship overseas too. I don't know if they accept Romanian currency. Good luck!!! -
loyale heater-defroster repair
somick replied to fst4rsc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That might be the common problem. I have the same problem with my 92. Do you wait long enough? In my case after 3-5 minutes it makes it mind and starts delivering air through the port it's been asked. -
Loyale peopleeeeeeeeeee
somick replied to NewDriverOlderRide's topic in Old Gen.: 80's GL/DL/XT/Loyales...
On my 92 Loyale the larger lever will lift the steering column all the way up. The small one is so called custom lever wil also lift the column up. But when you press it down it will stop at your "custom" level (the one has been preset). Regards, Sam -
Where's all my coolant going??
somick replied to Numbchux's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Open the glove box and stick your hand in the upper leftmost corner of it. Pretty easy to do. If you pull the clock out you may jerk the harness. It'll help to find the connector
Thank you! I'll give it a try.
I've never posted any threads before. I hope I'm in the right spot. I have a question about replacing a valve cover gaskets on EA82 for 1992 Loyale FWD. Can I do it without removing engine and timing belt? Question No. 2. (if I can do it without removing engine) Do I need to use RTV sealant on rubber gaskets? Question No. 3 (if I need to use RTV sealant) which one to use? And one more question. Do I need to use RTV sealant for the oil pan gasket? A little bit information about a car. I have 150 000 miles on it. When it was under warranty (what a nice time it was!) after the routine check up the dealer stated: “Oil leak…” Probably that was the same problem because I can see some gray stuff sticking out of the seams.
