2
Everything posted by somick
Leaking heater core? Do you have to add antifreeze all the time? Good luck, Sam
My bad. Yes this is the one. I installed a new bearing yesterday and I am back on the road. Just for reference the new bearing is 6202-2RS. I got two from Amazon for six dollars.
... and next step - check the idler bearing for the power steering pump (the smaller belt). That what failed on my 92 Loyale two days ago. Not bad for 189000 miles.
Just wondering what happened to these people?
somick replied to Subasaurus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So true! But can mods move this thread to the off topic discussions! -
Update. While checking everything out I also checked the belt that I installed about 5K miles ago. It looked fine but I decided that a little more tension will not hurt. That fixed everything. Apparently it slipped a little with the engine cold. Now everything is back to normal. My thanks go to @1 Lucky Texan for the idea of checking the hoses, etc.
- 5 replies
- 2
- power steering
- dexron
(and 2 more)
Tagged with:
Thanks Texan! Have you found the point where the air was entering the system?
- 5 replies
- power steering
- dexron
(and 2 more)
Tagged with:
2010 Forester with 90000 miles. About 3000 miles ago I changed the power steering fluid with the Dexron III. Everything was fine but recently it developed a problem: when the motor is cold the power steering starts binding. To avoid binding I put the transmission in neutral, raise the RPMs a little and the problem goes away. I do not experience any problems with the warm engine. YouTube search shows that I probably have sticking valves in the power steering rack and recommends Seafoam TransTune. Has anybody used it? Will it help? And the main question: did I cause it? I am looking for some help/suggestion, Sam
- 5 replies
- power steering
- dexron
(and 2 more)
Tagged with:
Need Rubber Hood Prop Thing
somick replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I hope you will find a replacement. I have the same problem. Good luck, Sam -
What Garry said! Do the gravity bleeding, one wheel at a time, and you will be fine. Just make sure you watch the fluid level in the Master Cylinder. Good luck, Sam
Can't remove bolt in EA82 Crank Pulley
somick replied to 3crows's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That is how I removed my Honda crank bolt: -
valve grinding/lapping paste grrr
somick replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I used this: https://www.amazon.com/gp/product/B000FW4MFC/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 One thousand miles down the road still no problems. Sam -
87 GL EA82 wagon - new to me running problem
somick replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The easy thing to check, like others mentioned, is a distributor cap and rotor. Good luck, Sam -
I went through the same thing: as far as I understand the smaller ones go to the Y pipe. For the exhaust pipe to the exhaust manifold I used Fel Pro 93227. Good luck, Sam
rear wheel brake sylinder and wheel bearing
somick replied to maarten's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would not trust roach auto! but I have always thought that you can rebuild the wheel cylinder. Plenty of rebuild kits on Amazon. It is interesting to know if it works. Good luck, Sam -
Funny! Eight bolts and the cam tower is out. The only problem is if you have a bad back but I still managed to do it fairly easy. Follow idosubaur's procedure and unscrew those bolts little-by-little until you can grab the rocker arms. After this no problem whatsoever. Good luck, Sam
After you take care of the mating surface pay closer attention to the metal pipe seal. Aftermarket seals suck! I coat them with silicone RTV and they hold. Good luck, Sam
As per owner's manual I used to replace belts every 30K miles. Now I am reusing the old ones . So far so good. Sam
