2
Everything posted by somick
Thank you wagons so much! Sam
- 23 replies
Thanks for the encouragement. I will probably take on this job if I cannot get rid of the car Any recommendations on the decent HG brand? Sam
- 23 replies
Thank you Dave. I am still debating whether to do the HG job or just dump it. I will see how much the junk yard will give me for it. Thanks, Sam
- 23 replies
92 Loyale with 187K. 2WD. Is there a way to guess if this is just a blown Head Gasket or a cracked head? The car has been losing coolant for a couple of years. Now the temperature started rising. I introduced compressed air in all the cylinders at TDC. At the cylinder #2 the coolant started leaking from the radiator. I am a fairly conservative driver, drive around the town and do not rev the engine. What do you guys think? Regard, Sam
- 23 replies
87 gl wagon no power to fuel pump
somick replied to Jakethewhite's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you checked fuses? Good luck, Sam -
I know that trick but it has never worked for me. The copper gasket for the steering pump leaked badly no matter how many times I heated it. I replaced it with a gasket made from the gasket material and it still holds. I, most likely, do not heat it enough because I do not want it to melt, but being color blind I cannot really tell what is the right color. So back to the washers. What size are they and who carries them? Sam
- 8 replies
- brake
- banjo bolt
(and 1 more)
Tagged with:
That was my plan but this was only one bolt. So I decided against it. If the OEM ones lasted me 188K I do not think I will be installing the new ones in the near future if at all! Sam
- 8 replies
- brake
- banjo bolt
(and 1 more)
Tagged with:
Thanks Dave! That what I did, I even bled the lines. I just wanted to be sure. Sam
- 8 replies
- brake
- banjo bolt
(and 1 more)
Tagged with:
A genius Subaru design requires disconnecting a brake line in order to replace front struts. That what I did. A Haynes manual says that I need to replace a banjo bolt washers. Does anybody know what size they are and what is more important what material? Copper, steel, gold? Thanks, Sam
- 8 replies
- brake
- banjo bolt
(and 1 more)
Tagged with:
2010 Forester with 82K miles When I turn the steering wheel all the way to the right or to the left I hear a nasty squeal or squeaking. I checked the level of fluid when the engine cooled down and it was right on the line of "Cold Low" Could somebody look at yours? What level do you have? No previous work. No leaks. If I need to add fluid I guess the Dexron IV is good? Thanks, Sam
Correct Struts for 93 Loyale.
somick replied to JWD06OBXT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Few months ago I contacted Monroe and they gave me the correct number. Good luck, Sam -
fuel level warning light doesn't light
somick replied to lrgvanman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
On my 1992 there is thermistor that is located in the sending unit. The thermistor is most likely dead. We had few threads on them here on the forum but I do not remember if anybody has ever fixed them. Mine died many years ago. Sam -
84 DL 1.8 valve cover gaskets
somick replied to YnotDIY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Actually this thread is about a different topic but, yes, I have had quite a bad experience with them. They sent me a wrong part once, they sent me a wrong part the second time. The distributor, they sent me with my third order, was for a wrong car as well. I had to pay for return shipping just to get my money back. I realize that I might have talked to a bad representative but the fact is that it cost me 10 bucks. They probably did not realize that they lost more money by loosing me as a customer. Regards, Sam -
Roach auto's database is very inaccurate. Do not deal with them.
