2
Everything posted by somick
Check that round thing that is mounted next to the motor. Contacts inside might be dirty or warn out. Good luck, Sam
Make sure you compare readings at the alternator and at the battery posts. It also could be a bad diode. Check reading at the alternator for the AC current. Good luck, Sam
Did you also make sure your fly wheel was at this ||| mark? Miles Fox has a great thread somewhere here on timing belt installation. It helped me a lot. Good luck, Sam
- 12 replies
- valve timing
- compression
(and 1 more)
Tagged with:
should be 180 Good luck, Sam
- 12 replies
- valve timing
- compression
(and 1 more)
Tagged with:
Yes. Make sure you have a good ground. Good luck, Sam
I have put few drops of oil on the shaft. Did it two-three times and it started working again. I guess you know that this fan does not work all the times? It works when the engine gets too hot or when your AC is on. Good luck, Sam
I would, like Garry suggested, check for ground. You need to have an electrical diagram. Try to ground the body of the ECU while testing or check the diagram for ground pin number. Good luck, Sam
- 7 replies
- electrical
- engine
(and 2 more)
Tagged with:
How can I check to see if my Starter is bad?
somick replied to Jman1991's topic in Old Gen.: 80's GL/DL/XT/Loyales...
12 volts from the ignition key become 11 and then 10... That what happens with old cars. This is a common problem on this car generation. The solution is a new circuit for starter ignition line. Very simple and easy to do solution. We suppose to have a lot of threads about them on this forum. I installed one on my Loyale and never have problems with starting the car. Good luck, Sam -
EA81 Drum Brakes... Where do the Springs Go?
somick replied to Sapper 157's topic in Old Gen.: 80's GL/DL/XT/Loyales...
On my 1992 Loyale they go on top. Small spring is on top. But I may be mistaken. Good luck, Sam -
Any BRAT's for sale in the Bay Area?
somick replied to Plagueboy_'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
I want to get rid of my 92 Loyale. I live in the San Diego area. Let me know if you are interested. Sam -
Your problem is roach auto. They lure us with low prices and make us buy junk. Try to return it (I doubt it will work though!) They will make you pay for return shipping. But if you are stuck you can always take the alternator apart and verify the integrity of brushes. I am pretty sure they are worn out. Good luck, Sam
Yes, post it in the "Older Generation" As far as I know they have different distributors for different years. So make sure you are testing it with the correct one. There is a transistor mounted next to the coil. You may also need to get a known good one and test it. Good luck, Sam
+1. When my boot broke I was not able to find a replacement and bought a cheap Chinese ball joint for five dollars. Needles to say that the boot broke again in six months. The quality ones will last you but they are not cheap. My dealer charges more than fifty box for them. Good luck, Sam
PVC hose assembly available for 1992 Loyale
somick replied to markurq's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I believe the hoses are 5/8. I have failed the smog test once because I used regular hoses and I had to buy ones from the dealer. Not cheap! Good luck, Sam -
Here it is. Ping.doc
I will have to go through my tons of paperwork this weekend but I am pretty sure I know where it is. I will post it as soon as I find it. Sam
