OB99W
Everything posted by OB99W
In my experience (so opinions of others may differ ): 1) Bearing noise in neutral with the clutch pedal not depressed could be either throwout or input shaft. 2) When depressing the clutch pedal: a) If the noise changes (but is still there to some degree), it's likely the throwout. If the noise completely goes away, likely input shaft. Do check the trans oil. 3) Driving (in gear) loads the bearings differently, and the noise may change, go away, or be masked.
Just to clarify this -- I didn't say the noise (which John didn't describe, making remote dagnosis more difficult) couldn't be caused by a bad throwout bearing. The throwout may well be the culprit, but typically when bad they're still noisy even when the clutch is disengaged, although the nature of the noise usually changes. I offered the alternative possibility of input shaft bearings because John said the noise "goes away" when the clutch is disengaged.
Agreed. My own '99 has one of the "pieces of crap" 4EAT transmissions. Fresh fluid and very careful checking of the ATF level help a bit, but it still isn't "right". The 4EAT can be decent, but apparently not the early phase-2 ones ('99-'00 MY). Of course, the above won't help Sewoolf, who already bought the '99 and is having brake, not trans, issues at the moment.
There was a recall on the '99 Legacy for the master cylinder secondary circuit failing in extreme cold weather, with the result being the pedal travel is increased and braking decreased. While that probably isn't directly related to the current problem, you might want to determine if the work was ever done on your car. See:http://endwrench.com/images/pdfs/SecondaryInfo.pdf http://www.automallusa.net/1999/subaru/legacy/recalls.html
These are from the August 2002 issue of End Wrench: http://endwrench.com/images/pdfs/IdentifyInfo.pdf http://endwrench.com/images/pdfs/ABS.pdf There's more ABS info in that issue, so check the site. ABS relay sticking: http://endwrench.com/images/pdfs/ABSInsiderEWFall05.pdf ABS system check: http://endwrench.com/images/pdfs/ABSSystemInfo.pdf
What was the source of the "good used" axle? If from a "yard", can you be sure that the source car wasn't in a front end accident? It's also important that all mating surfaces are clean; some grit or rust between parts can cause problems. I'd suggest checking rotor runout, but if you find some don't assume the rotor is the culprit until other causes are eliminated.
ABS Light
OB99W replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
What happens if you downshift and drive at a lower road speed that still has the engine RPM at 2800? I'm puzzled too :-\ ; please explain what you mean by "shut off motor and continue highway driving" in a bit more detail. -
Rear horn?
OB99W replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
So how would you have those bumpers "shot out an extra distance", and what would absorb/dissipate the energy of the impact on the bumpers? Perhaps airbags with rapid inflation and controlled deflation underneath the bumper skin would work ? (And yes, I'm aware of the possible use of hydraulics, etc.) One of the problems is lack of standards for bumper height; this approach could get around that: http://static.howstuffworks.com/gif/mars-rover-airbag.jpg -
Rear horn?
Nipper said "It really wont do anything for two 3000 lb cars meeting." Turbone said "This isnt the same as a airbag inside a car.[...]You get propeled backwards. The energy gets transfered thru the ball and into you. Dont think this one would work." I believe that the reality is somewhere between those two extremes. While I wasn't totally serious in my "suggestion" (note the tone of the preceeding posts by ericem and mtsmiths), don't be too dismissive of the concept. Properly designed, such a system could do something to reduce forces transferred to the vehicle occupants; I didn't suggest that it would eliminate all damage and injury, and of course the relative speed of the two vehicles would play a role in how effective it could be. In addition, SRS airbags have a very controlled but rapid deflation, and that's key for energy absorption/dissipation and minimized force transfer in any airbag system. Try a Google search on "Charles H. Duell" for perspective.
