Sweden
Contact Methods
Website URL
http://
Location
Lund, Sweden
Occupation
University Researcher
Sweden's Achievements
Advanced Member (3/11)
10
Hello all. It has been a while since I last posted. This is mainly due to the fact that I traded in my 1996 Legacy Outback for a 2008 Justy here in Sweden. I am having two issues with my Justy that I hoped to get some feedback on. 1) Has anyone, especially those of you in Europe, seen Subaru the horizontal roof rails for this vehicle? I am planning on mounting a roof luggage box on the car for a small family vacation, but there is no photo of the rails (or mounts) on the website. Are they universal mounts or something done just for a Justy. 2) This car has the 1.0 - 3 cylinder engine in it. One would think that it would be rather fuel efficient... Instead, I have been averaging 6.4 liters per 100 km, which really stinks! The driving is mostly on county roads and freeways, which seems to be where the fuel consumption is the worst... There are now 10,000 km on the vehicle. Is this the best I am going to do with it. The sticker claimed 5.0 liters/100 km. Thanks! Sweden 2008 Justy S
I actually fixed my problem a while back. I took the door apart but everything seemed to work well. I ended up digging a bit further (beyond the door) only to find that the wiring harness to all the electronical items in the door was in really bad shape. It was the one below the fuse box. Apparently there was some Minnesota salt water leakage there for a few years that took its toll on the wires in the harness. I bypassed the wires around the harness and everytrhing is peachy with the locks again! Sweden
The slides got greased a few months back when I replaced the pads, so I know it is not only that that is causing the sticking. After 3 years in the salted streets of MN and the subsequent years here in southern Sweden, it is not surprising that the caliper is hanging. I'll give one of the suppliers a call after the New Year to see if the kit they have is the correct one. 99obw Were you here in southern Sweden because of the University or one of the companies located here? Yes, the hjortonsylt is great; but I have tired of pepparkakor (after eating about a 1000 of them in the past month...). Sweden
It is time to replace the other front brake caliper on my '96 OBW. It's sticking. Being in Sweden, parts for my Indiana manufactered Subie are neither easy to come by nor inexpensive... I am wondering if anyone out there knows of a place ( in the U.S.) that sells rebuild kits for the double-pistoned caliper on this vehicle? It would be simple and cheaper to by a rebuilt caliper, but the shipping of a caliper from the U.S. to Sweden would make it cost-prohibitive. I thought of just having a kits sent and then having it done here would be a better & less expensive option. Thanks! Sweden
I think it is time for new front brake rotors after 10+ years and 120K miles on my 1996 Legacy Outback (EJ22 engine, 15" rims). I notice now that when I brake there is a pulsing in both the brakes and in the steering wheel. I replaced the pads a month or so back in order to ge the vehicle to pass inspection here is Sweden. 1) I am wondering if this IS most-likely the rotors in need of replacement? 2) And, if the rotors were the same as rotors on other vehicles. I would like to replace them with Original Subaru rotors but the price for them is extremely (i.e. prohibitively) expensive here in Sweden. Is there a way to cross-reference to see what other vehicles might use the same front rotor, so I might locate them at a parts supply house? Thanks! Sweden
Thanks-a-million for the advice and diagram Cougar & BigMattyD. I spent the day with changing brake pads and other things to get the car ready for its annual inspection coming up, so it will need to wait a few more days for time to dig back into the door. I did notice though that the 'ghost' came back while test driving the car today--meaning that the locks locked by themselves while driving. Sweden
I finally got around to pulling the door apart and checking things out. I disassembled the 'Nissan' switch as instructed. As far as I could tell, both contacts were touching but things were a bit dirty. I cleased evetything with alcohol and reasembled. NO LUCK. No change... The is no lock movement on the other doors, not with the key or manually. Could it be that some other part (e.g actuator, lock timer, etc) went belly-up with prolonged switch problems? I haven't tested enough to see if I get the ghost in the system again (meaning lock movement by itself). Is there a way to test (easily) where the problem might be (I don't have a multi-meter, but an excuse tyo buy one is ok by me... Thanks beforehand! Sweden
My vehicle needed to sit about 5- to 10-minutes before it would start again. If you have an extra plug wire and plug, pop it on when it won't start and see if there is spark. I got nothing... If I remember correctly, I received no Crank Angle Sensor code for quite a while. Then suddenly, it appeared. You can search for my thread on this from last autumn. Good luck! Sweden
Thanks for the advice Cougar! I'll play a bit more to see if I can get some change. It may seem like I overly-diagnos things, but it is only because I live in Sweden and need to order parts from the U.S. (US-manufactured OBW). This involves int'l telephone calls, having my parents pick up the parts and ship them, etc. A pain! Not only are the OBWs different here, there was no 1996 OBW in Sweden. I have been searching for two months now for a trailer hitch that can be 'approved' by the authorities here. Everything is a battle! Sweden
You are right with the code (sorry, I didn't read the whole thread close enough). One thing that was up with mine was that it didn't reveal the Crank Angle Sensor code for a number of days & trials at the mechanic. We got the Cam Angle Sensor code though; the problem was that I had just replaced it a few days earlier. My car is possessed Sweden
