Everything posted by electryc_monk
diesel subaru?
electryc_monk replied to Jack in Norfolk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
drive down to Texas from Michigan empty(basicly) return with a cb900 disassembled and alot of my stuff in the "shell-inclosed" fullsized bed and towing the GL-10 turbo on a dolly. Diesel gas mileage was just over 20 on the drive down and on the drive back it was 18-22mpg model: 2001 250 superduty quadcab 4WD 5+1spd 7.3L (or was it the 7.1L) turbo intercooled diesel speeds below 70 MPH garnered over 22MPG AVG. not bad for the 12K lbs 'family sports car' (family inside joke nickname) on the hardpacked dirt roads in the upper part of the "mitten" where they live we took it out and i got 4-wheel scratch in 1st and second gears. (admittedly the 2nd gear was for maybe 1-3 feet before it lurched forward.) -
I'm sorry looks who assumed again today.... W.ild A.$$ G.uess my optimistic side wanted to jump higher then "normal" as it *hear the use of a W.A.G.* and did so buy just guessing on those number from what I remember people saying that the EA82 design "might be able to hit the 180HP window at the *crankshaft* AKA flywheel from my last comment. And so it thru in an extra *few* digits for fun and well, thats why so high of numbers. Thinking the idea of such lofty number was *assumed* by the realistic side of me at the following estimate numbers: crankshaft HP :182 wheel HP :148 nahhh make it 140 do to the 4WD friction variable hows that look now?
okay here is the (link below) job Calbz and I did at his Casa a couple months ago. http://groups.msn.com/USMB/shoebox.msnw http://groups.msn.com/USMB/electrycmonk.msnw here is the specific image with regard to the front brake lines. http://groups.msn.com/USMB/electrycmonk.msnw?action=ShowPhoto&PhotoID=956 AND as its the drivers side, look for the metal tab that protrudes forward of the strut (at its base) where it connects to the Hub assembly. This has a simple "C" clip that holds the brake line close to the strut for "Safety" reasons. Admittedly its not OEM safe with the liftkit, it is however Very safely tucked away from the strut and tire as i only needed to very conservatively bend it for the needed flexing room. I had to (a while back) install a *newer* air strut and so to do it without taking the caliper off the hub and disconnecting the brake line and then having to deal with the "joy that is bleeding the brakes" - I ussed some "good quality" Tin-snips and cut the side of the tab and then bent it down. This allowed the brake line to be slid out of the tab of metal. Then i bent the metal tab back up and this kept the chances of accidental scraping the brake line to near zero from that piece of metal i just cut. there, that clear enough? (worried i just babbled too far) ***NOW about the rear brakes.... it's easier to deal with. There is this -10mm? shallow bolt that holds the metal brake line to the main suspension crossbar (round tube) as you lower the rear section it will be obvious what bolts I am refering too. NOW before you lower it too far a few inches(2-4) we also realized that the fuel line has a nice hidden shallow bolt to deal with too. Between the tank and the fuel pump hidden (up under the passenger rear seat) is a small section of metal fuel line with rubber section to the tank and on the other side of the main round tube it will have a rubber hose going to the fuel pump. (dork me can't recolect if this was a note in the install manual or not) anyways. The fuel pump vibration plate bolts and this top bolt on the "inbetween metal pipe" need to be removed before you go anyfurther.... that way no fuel accidentally gets spilled from a oops with it. :>) hows that folks? TMI?
THIS! Is what I was meaning in that PM i just sent you. (sheepish grin) I misspelled what the brain was thinking about AND found one of the pages still intack in a google search. http://www.sdsefi.com/air11.html The one I specifically refered to in PM no longer shows up in the cashed google search though. at least there is one though.
Dude, this is the spec's of the unit your looking at : Oil Cooler • New HAYDEN. Oil cooler for hydraulic systems, engine or transmission coolers, etc. Copper tubes with aluminum fins. 3/4" diam. cooling tubes. SPECIFICATIONS • GPM 6 • PSI 300 • 350° F • Ports 1/2" NPT • Cooling fin area 12" x 3" x 4" • Overall size 16 1/4" x 4" x 5 3/4" • Shpg. 7 lbs. **I'm worried that with the GPM6 equals 6 Galloons Per Minute Which makes me wonder What this will do to the Oil PSI? Am I just being too cautius?
diesel subaru?
A person "convinced" against their will, is of the "same opinion" Still. Just a soft reminder reminder brought to you by 'saturday morning cartoons, and 'School House Rock!'. -
Trip Computer Control Box?
electryc_monk replied to Scrub2k's topic in Old Gen.: 80's GL/DL/XT/Loyales...
heheheh OR you might look at the place i have now... granted it was a temperary fix but, I was wondering about sticking it there as I too have removed the "ashtray" hmmmmmm maybe I'll put a simple plate down there and then drill a single hole for the starter-interupt too. http://www.geocities.com/electryc_monk/cd6-27.jpg or this view of the same http://www.geocities.com/electryc_monk/cd6-24.jpg -
diesel subaru?
your refering to the CNG or Propane kit? (smirks to self) "Wow a 1994 Brat, wonder how much dsign change has happened for this car?" http://www.altfuels.com/ http://www.afdc.nrel.gov/ http://www.alternatefuels.com/ and those came from this search: http://www.google.com/search?q=Alternate+fuel+vehicle&hl=en&lr=&ie=UTF-8&oe=UTF-8&start=50&sa=N -
diesel subaru?
BN and SF Railways have a LNG coverted diesel locomotive system in full use. Many companies world wide are designing bio-diesel or bi-fuel deisel engines systems. That being a diesel engine converted to run some persentage of diesel and the rest either Propane,CNG, LNG, LPG, or some other blend. there are Net communities that i have book marked somewhere that are very strong backing in the R&D of LEV and ELEV (Low Emissions Vehicles and Extremely LOw E. V.'s) sooo yeah its sooty and yes it is bad but, isn't there a difference between the blends and refining processes of diesels now and those of old? I believe that there is even a bit of higher level refinement done in Europe (due to the death of the Black forest et al) that made a manditory sulphur reduction to something less then half the US diesel sulphur emission levels of today.... so how (firstly) wrong am I and how wrong might though be? anyone else???? -
diesel subaru?
remembered hearing of a subie dude doing research in machining an EA81 for diesel reconstruction. did some google tunneling... rear "somewhere" - don't remember where - that there was something in South Africa being done. dug some more. Found a few Subaru sites in S.A. and actually got a couple legit replies from these Subaru businesses. One in particular replied with logical curiousity. I replied with a more indepth explination of what i was doing (kinda leaned alittle on the truth) as i was using my university ID and saying that I was considering it as a MAsters project in a physics program. This one place said it was an admirable idea and was very interested in the idea cosidering the specifics i had spit out for them. most of this stuf was from the stuff I had found on the net that others had "talked about back then". the below section are the only parts I vocalized as what "I" was looking into and leaning towards. RE: thicker sleeves and possibly studs into the sleeves themselves for support of the high CR and keeping a modest turbo from the RHB5 design or something similar. Conservative estimates of a 1.6 design was expressed aat which point the reply was ... keep in touch Because we may be trading notes if we find time to play with the idea down here. well sad to say i lost their email ID as that PC died last year and took the HD with it. and, that is all i can remember to this idea/thread/design/et al. -
exhaust ?? 2.5" pipe??
electryc_monk replied to Meeky Moose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the turbo out is esentially 2.5 from the O2 sensor back... when things "Calm down" and I can spend time with Ed out at his barn then the turbo adapter plate will have the O2 sensor nipple and EGT nipple welded to its neck... And so you already know, the 3-way cat is actually in the place of the original 2nd cat from its OEM days. The muffler is a 2.5 in and out as well.... some off brand of the turbosonic design its a striaght thru style but truthfully - we tested it in the muffler shop with stratpipe and then with the muffler installed. the only difference was at speed the muffler takes "the edge off the sounds" and allows a Very quiet ride. The Smog test was very productive too. I was quite happy with it. -
Unsprung cargo cover
electryc_monk replied to pianodirt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
two suggestions.... 1st: while holding the middle of the unit and sitting down spread the unsprung fabric across the table so the end of the fabric is away from you. b.) holding the middle roll it up about 4 or 5 full turns c.) then while still holding the middle turn the left side towards you as its being pushed towards the middle d.) repeat for the right side spring cap unit e.) while still holding the middle spin it either almost or all the way up at this point. f.) repeat step b. and c. then it should be fully sprung tight. *side note* IF that doesn't work out then do the idea backwards and the unit will actually hold itself coiled 2nd: similar idea just more complicated having the cover partially installed with one cap pushed into its normal space in the wall b.) while pushing towards the cars body on the backdeck cover unit AND holding onto the other endcap you start to spool up the covers spring system. c.)once the cover was installd you should notice a marked resistence higher when unscrolling the back deck of the wagon then you have the "Factory" level of more of friction here in denton . The health codes are not pretty but, welll yeah. braintoasted night night -
D/FW this weekend
electryc_monk replied to electryc_monk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well, i do have a service manual for the EA81'a automatic tranny but.... currently though this manual IS in someone elses possesion for HE/She is/Are scanning it and a few other manuals I own for the electronic database we are working on for all USMB members. soooooo. it might not be that early but i think it is. as its not for the 4EAT that for sure. and guys... Calabz and Okami.... i think i came up with an idea....... -
D/FW this weekend
we will have Okami's Cell phone with us tomorrow soooooooo... i hope to post it here or PM you with it tomorrow before we go... not sure where the piece of paper is at the moment other wise i'd PM you right now. -
D/FW this weekend
Calebz ... Okami's answering mashine isn't picking up and well they call it a night at 11 soooooo i guess something is up. Or they may have unplugged the phone for a night to themselves? (mischivious grin) honestly i haven't a clue but its cute to consider at least. -
Wounded Loyale... HELP!
electryc_monk replied to trooperjeep's topic in Old Gen.: 80's GL/DL/XT/Loyales...
look for the vacuum or electrical lines (?) which is it guys? I've not yet played with the push button 4WD. -
Some questions for the masters...
electryc_monk replied to ScoobieNoobie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
here is what I did to allow for a nice CD stereo setup. sorry but yahoo doesn't like it when i try to link a picture so goto my page here: http://www.geocities.com/electryc_monk/Headunit_mod.html but if your not to fond of the kit design welllll... (shoulders shrug) there is always the legacy trim kit and spending some time plastic cut-sanding the kit to fit.... but hey its only time right. -
D/FW this weekend
Okami and I at the least..... now to call you (Calebz).... T & T to be determinded (pun inforced and running for cover) -
D/FW this weekend
That is supposed to say Okami not I'm.... sheeeesh 591-9996 -
Russian or New England story.....
electryc_monk posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
I dare believe that those who took part in and fueled the seriously nice thread about 8-9 months ago migh be able to shed some light on my curiousity. "Reader's Digest" regurgitation follows: Someone started a thread on "what would be the interest in helping achieve this idea into reality" Getting the stamps and die's for starting or rather resurecting the early to late 80's subaru's via Russian automobile manufacturing. Then it jumped to Focusing on the Brat's and the military application with a off the factory line lift kit (i think?) the logic was its a line that has "mostly all the bug's" worked out of it and what mod's could be done to allow for the Mod's we all know of that have been done to the beloved pleadian's we drive.... then it tangeted(i think) to a gov't contract idea for just the brat s and then being able to find a place in the US for its resurection and cheap way to get New parts for us..... then it was chimbed in by a N.H. or Connecticutt(sp) soul who said if Russia doesn't work out what about our home team as the Ship yards up here have taken a big hit and well, if a gov't contract for a ORV (read like the chenoworth sand rail idea) were to be built on the BRat design... several uber mech-heads were commenting back -n- forth here.... Then the update near the end of the threasd was "I'm abouyt to go pitch the idea overseas" then the thread of the idea for a switch to V-bulliten happened and this thead dissapeared..... Well, anyone wanna update, or more for starters clarify anything i miss-construded or did not remeber correctly? -
errm, this saturday. Okami is going to the Dallas Junkyards, I ask if i could go and he said sure... I'm gonna get a rear disk set for the Brat. Hey Calebz, you wanna go on saturday? We might even get a chance to se TiminTexas (the newbie to the board as well) (i oops and missed touching base with him this weekend) anyone else lurking wanna do this? I can be found easily... you know what to do.
if you'll overlook the geeky computer phrase above its litterally a screwdriver only swap. The wire connector for the 6 disc unit is the EXACT same. you'll have FAR Less need for imagination then i did for this: http://www.geocities.com/electryc_monk/Headunit_mod.html nuff said? Cool. Goforth and play well with others. :wave:
