J A Blazer
About J A Blazer
- Birthday 12/19/1948
Location
Fairfax, Virginia
Occupation
Attorney
Vehicles
2000 OBW
J A Blazer's Achievements
Subaru Fanatic! (6/11)
13
Here is how I removed the starter in my 2000 4cyl OBW w/ AT after many unsuccessful false starts. Place car on ramps. Not necessary to remove either front wheel. Disconnect battery. Relocate hood support so as to permit additional access to rear portion of engine compartment. Remove air filter housing. Locate starter and remove power connections. Loosen top bolt, 14 mm I believe. Some people claim they can remove the lower starter bolt from above, but I could not. Take a long stick and from the top, place so as to touch the lower bolt - this will help you see where it is in the next step. On your back or on a creeper approach undercarriage from the front (not the side.) With bright illumination locate the stick that points to the lower starter bolt. With a 14mm socket on a wobbler and about 12" of extensions approach the lower starter bolt by going in from above the automatic transmission filter. Remove the lower bolt. Go back up above and remove the loosened top bolt. Lift out starter. If any aspect of this does not make sense let me know and I will try to clarify.
I had this problem with my 2000 OBW 2.5; front axles were replaced 5 years ago and were doing fine but as soon as I replaced the entire exhaust system the inner boot on the passenger side, which is directly above the cat, ruptured. I'm convinced it is because the replacement cat does not have a heat shield. Would love to see pictures of the heat shields that other posters have fabricated.
