J A Blazer
Everything posted by J A Blazer
Here is how I removed the starter in my 2000 4cyl OBW w/ AT after many unsuccessful false starts. Place car on ramps. Not necessary to remove either front wheel. Disconnect battery. Relocate hood support so as to permit additional access to rear portion of engine compartment. Remove air filter housing. Locate starter and remove power connections. Loosen top bolt, 14 mm I believe. Some people claim they can remove the lower starter bolt from above, but I could not. Take a long stick and from the top, place so as to touch the lower bolt - this will help you see where it is in the next step. On your back or on a creeper approach undercarriage from the front (not the side.) With bright illumination locate the stick that points to the lower starter bolt. With a 14mm socket on a wobbler and about 12" of extensions approach the lower starter bolt by going in from above the automatic transmission filter. Remove the lower bolt. Go back up above and remove the loosened top bolt. Lift out starter. If any aspect of this does not make sense let me know and I will try to clarify.
I had this problem with my 2000 OBW 2.5; front axles were replaced 5 years ago and were doing fine but as soon as I replaced the entire exhaust system the inner boot on the passenger side, which is directly above the cat, ruptured. I'm convinced it is because the replacement cat does not have a heat shield. Would love to see pictures of the heat shields that other posters have fabricated.
There are others on this forum far more knowledgeable than I, but understand in the 4 cylinder engine there are two sensors, one pre-cat (also called 'upstream') and the other post-cat (aka 'downstream.') Failure of the upstream one will affect performance; failure of the downstream one won't. But yes, the check engine light glaring in your face is a real pain, and regardless of whether your car passes emissions tests will jeopardize mandated safety/emissions checks and attempts to sell.
- 6 replies
- Subaru outback
- oxygen sensor
(and 1 more)
Tagged with:
2005 Struts
J A Blazer replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Perhaps the 2005-2009 generation of Outbacks are different, but on my 2000 Outback I was unable to compress the springs far enough to free up the top nut. And I was using a fairly high quality set of spring compressors from Sears. Had to take them to a mechanic with a more sophisticated device. -
I have posted on this issue before. I have a 2000 OBW that had the exact same problem. Dealer mechanic insisted it was the bulb but I knew otherwise. I replaced the stalk (new from RockAuto) and problem has not returned. Stalk is a user-installable item, but you need to lay on your back on the driver's seat with your head in the footwell.
