J A Blazer
Everything posted by J A Blazer
2000 OBW, 155K. Suddenly the 4-way rocker control for the side mirrors has failed in one of the directions, for both mirrors. Anybody been there with this problem? Simple fix? Is that control separately replaceable, or must the entire assembly (including door window controls, etc.) be replaced? TIA.
Amen to what everyone else has said. I would add that, regarding # 3, it is not the valve cover gaskets per se that are bad; its the seal between the spark plug tubes and the underside of the valve cover that will leak over time, causing oil to coat the spark plug and the plug wire. But in order to replace them you have to replace the valve cover gaskets, the bolt hole grommets, and the tube seals. But that is an item of repair that can be deferred a long time, and as others have said, would be included in a head gasket job.
I finally was able to remove the starter from my 2000 OBW. Replaced the contacts, and am now ready to reinstall it, but thought it might be a good idea to test it first. Jumper cables to the battery, I assume, but what about that small wire contact next to the positive terminal on the solenoid? What do I do to/with it? TIA.
I was able to remove the top bolt with no trouble. From above although I could position the socket on the lower bolt I could not get enough 'swing' to get it loose. From below, on jackstands, I simply could not get my socket on the bolt. No doubt I could have gotten it done were it on a lift, but the DIY facility that I have used in the past unfortunately just went out of business.
While installing a new knock sensor I encountered slight resistance with the bolt, and rather than risk cross-threading it, I installed the knock sensor in a different location that took the same thread. It is slightly towards the rear and towards the drivers side, higher up on the block. Will this work?
