Rhubey
Everything posted by Rhubey
When I first started my car it idled just over 1k. I tapped the gas then let off and then it went to 1k on the dot. Flipped on the ac, it went up to about 1100 then I heard the click as the compressor kicked on. Idle then dropped to just below 1k. Turned off ac and idle fell Way low. Like 750. Then I turned ac back on. RMP flew back up to just above 1k, then creeped back to just below 1k in about 10 seconds. Turned ac off again, it bogged down again.
By hopping I mean a full out bounce. Like as though I was repeatedly quickly pushing in the clutch and letting it out carelessly. The whole car nosedives and then jerks back up repeatedly. It happens in 1-3rd gear right after letting out the clutch and instantly stops if I depress the clutch pedal or shut off the AC. I have been driving stickshifts for 15 years so I know to be gentle. The change that happened that made me notice the problem is this: it got hot outside so I started using my AC.
Thank you for replying. Apologies for my ignorance, but I have never heard of changing transmission fluid in a 5 speed. Should that be done often? Is it difficult? How is it that air conditioning and my clutch would affect each other? I should warn you I have almost no experience with working on cars.
Hi! I have a 2002 Outback Wagon 5speed with 145k miles on it. Recently it has been "hopping" when taking off from a full stop if the ac is on. It seems to only be in the lower gears that I have this problem, and simply poking the ac button off untill I reach highway speed seems to fix it. It isn't the worst problem in the world, but I worry about getting rear ended if I can't out of the way in a hurry. What should I start hitting with a hammer first? In all seriousness, I am in Florida and don't know of any local shops that are knowledgeable with Roos, and I always worry about getting ripped off due to my lack of technical abilities. Thanks for any help you can suggest.
on 02 legacy outback 5spd.... Has anyone replaced the (9)rollerbearing, (11)seal, & (13)Oring w/o pulling & opening the 5spd Xfer case?? I have been able to reduce rattle by tightening these before by 1-2 teeth, but now i have one that should be replaced, i think. Minor leak & rattle. This thing needs another gear, so if a rebuild is in order, it should get a 6spd. sean
So I thought that I should come back after 200mi and update the solution to my serious steering wheel vibration @ high speed since many others have had similar symptom and no real documented conclusion. 1st Replaced the front rotors/pads, obvious warp. I tried to manipulate the rack, ball jts, axle and wheel for play which was not obvious. -fixed breaking vibration though. 2nd Swapped front & back tires. - no affect. There was slight cupping on the inner row of tread drivers side. Almost need a micrometer to detect. 3rd Tried the rack, ball jts, axle, & wheels again. crowbar under the wheel (w/light pressure) my hand fealt a slight pop on the spring, drivers side only. Almost in need of a stethascope to detect I thought, and certainly couldn't see any movement. -Decided to replace the bearings because there's no back-woods reason for it to need aligned at least yet. 4th Pulling the knuckle to do a bearing/seal replacement is extensive, w/o alignment, so i'm hoping that the cupping will not return on the fresh tires. So I conclude my vibration fix could have been: 1. The bearings. 2. Rotating the ball jts 90 deg. 3. The broke-thumb-swearing-case-beer-dance-ritual ...THAT CURED MY WIFES BLUEBARU. Something I learned is not to drive a seized race w/a log splitting maul no matter how deep woods pennsylvania you come from. Hope this may help someone in he future. Sean
The more I read the less I know it seems on this subject. I think that anything I would have done would have been wrong except to take it to the dealer. which will probably never happen. Instictfully I would have done the same as you Dave and will do next time as hind-sight. I decided to crack the bearing assy, remove and replace the Green grease with off the shelf valvoline hoping that the nylon cage is chem-safe. The factoy Green grease feels like a higher quality than the valvoline that replaced it. After I got started it fealt like the wong thing to to. So, we're going to have 1 side Valvoline and the other side Valvoline & mysterious Green. Wonder which will last longer.:-\
32mm on 00-04. maybe the same and if you can get to it you can adjust it. w/my 91 Legacy w/ over 200k the rack is still tight. BJ's & inner tierod were loose on it but only when the suspension was depressed & tight with the suspension extended on a lift. just a thought. I had to adjust the backlash on an old 4runner that was really loose but took only ~ 1/2 turn to be too tight and not return to center w/o help. hope this helps.
After a long journey of troubleshooting everything causing steering wheel vibration over 55mph, i've replaced rotors/pads and now the wheel bearings at 120k mi are next. I would have ordered Timken but opted for the cheapo Precision bearings for $17/pair anticipating the axles are next in a year or 2, w/the new 6spd gearbox...or pipe dream. The FSM calls for 159'lbs torque on the axle nut. This seems kind of high to me, and there is no preload specs, although i have never replaced this type before and feel the need for reassurance. The FSM also calls for the "GOLD" axle nut, which I have the "OLIVE" installed of course. Does anyone know the difference?
I would like to thank everyone who responded to this thread. I oboviously have no business working on my car myself, and am always afraid of getting ripped off. I'm also curious about how things work, and acceptable ways of fixing stuff. The fix was simple. The fuel line was rotten. It looked fine from the top, but 2 lines were actually nothing but rust on the bottom and through the grommet. It took some time, but we just replaced it all with hose, as suggested. We, as in I watched. Thank you everyone for making me smarter about my car, and helping keep one more Sube on the road. Next: my alternator died last night. Erp.
If I was to be sitting in the back seat behind the driver, this would be under my butt with the seat cushion between. I took this picture looking in through the back seat driver side window. It seems as though the middle one has gas around it where it goes through the body.. It also seems as though those are metal tubes that rubber hoses pass through. Nothing there seems too well connected. Yes. I did have my back seat pulled last year. My car is also often used as a uhaul.
Er? Ok. Wait. I found this picture that I am hoping is actually my car. http://www.graphics.cornell.edu/~v/pics.cgi/ej22t_fuel_lines.png Porcupine said to look behind the passenger seat for that mess of hoses. My leak is on the drivers side. I had to actually pull up the part of the back seat you sit on to see my leak. I don't think the gas is leaking uphill, or am I confused? If the bottom of the picture is the back of the car, then 9, 10 and 11 seem to be the problem. Is the blob next to 9 a rubber gasket type thing? What is the next thing on the right of the blob? The gas seems to come from that area as opposed to the pump way. I'm dangerous enough without a gas leak, so I'm parked. I'll dig around in my trunk as soon as it lays off the downpour. Thank you everyone. I get tired of blind guesswork and getting ripped off at garages. Does this explain why I was ideling funny?
Hello all. If you have a moment to help an unknowledged Legacy owner, I would be very thankful. I have a 91 LegacyLS. 181k. I have owned it for 4 years, and have had almost nothing but love from it. I found I have a gas leak. It started smelling a few weeks ago, then yesterday it reeked to the point of problematic. It is not at the neck of the gas tank like what seems to be the common problem. When I lift up my back seat, I can Kinda see the leak. (?) It is on the drivers side, my tank is on the passenger side. It is possibly 2 leaks from 2 hoses. I have searched and found lots of threads about leaks, but do not know the proper terms for car parts and locations, so my searching ability is limited. It looks as though there are 3 shielded hoses there. What are they exactly? Do they all have gas in them? Is it crazy difficult to replace gas lines? Are gas lines one long hose front to back? Or are they in sections for easy replacement? Could I have a fuel line that is connected to something close by like a pump that is simply coming loose and gas is running along the lines? How dangerous is it to drive? It streams fuel quite a bit while the car is running, but seems to taper off quickly as soon as the car is off. Will I explode if my drives are under 5 miles? Does anyone have suggestions, please? I have someone who will work on my car free if it's not super dangerous genius stuff, but I would hate to go to a garage and get overcharged for things simply because I am female with no background knowledge. Thank you kindly. Please help me learn.
OK, here are the clues...:-\ 1. 91 Legacy 5spd 2. EJ22 non turbo 3. located @ the front top center edge, below the alternator, in front of the " EJ22 " stamp on the block. Have a guess yet??? Here are more clues... 4. It is approx 3" long cylinder mounted vertically. 5. It has an approx 20mm hex molded at the top for removal. 6. It is attatched w/a single conductor, w/a spade type connector @ the top. 7. It sometimes "burps" oil up through the center ( between the dialectric and conductor) and leaves your engine stinky when it warms-up.
HI! I was hoping someone could either give me links to, or post pictures of a clutch assembly and housing for my car. I have a 91 5spd Legacy 2wd that may have the clutch spring cable retainer clip inside the clutch. The boot is ripped open just enought that the clip may have slipped into it. I can't find it on the ground around the car, but I'm assuming that I would have heard it getting crushed as I put my car in gear after realizing it was gone??? Is this opening at the top of the clutch lever an intentional direct access to the clutch plates? If it did fall inside, is it easily retrieveable, or would it be destroyed already?
Hello. I would first like to say how much I love my Sube before I whine about it. It has 175k on it and has cost me under $500 in the last 4 years, including tires. It still has all its power on the hills, and other than some random strut problems (fixed), my car is amazing. But... My S.O. for the last 2 years has mentioned my clutch is "funny". I realize every stick shift is different, so since I got it 4 years ago, I paid no mind to where it grabs or how it feels. It seemed fine to me. It grabs Very high, but that's just how it's been. Only going into first or reverse do I have to actually press the clutch the whole way down. 2-5 seem normal. Lately it seems... hesitant going in gear. Not "crazy slams into gear seconds after the clutch is released" type of stuff, but off somehow. This problem started Before it got cold out, but now when I start it in under 30F weather, I can hear a light grinding whine sound from the clutch. If I push in the clutch the whole way it goes away, and if I pull UP on the clutch pedal with the top of my foot, it stops. But in regular out of gear and just sitting there running mode, it whines. What's wrong with my baby?
