About subiemech85
- Birthday 10/13/1985
Contact Methods
Website URL
http://www.cardomain.com/id/subiemech85
Location
down by the river
Interests
camping
Occupation
Moss Bros
Biography
Eagle Scout, vice chief of elections and promotions Broken Arrow district
Vehicles
11/79 wagon
Recent Profile Visitors
subiemech85's Achievements
Subaru Master (10/11)
11
now that most of the important projects are out of the way, it is time to work on the BRAT again several months ago I bought a newer ea71 from '84 5spd fwd hatch it has the side mount starter I would like to mate it to the 5spd d/r from '85 wagon what is required to mate them and install in the '79 BRAT? clutch, transmission input shaft, driveshaft, and axle stubs compatability concerns.
Weber manual choke through the firewall
subiemech85 replied to Cup O Noodles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I vote for the manual choke use a cable -
my welder came with K-T e71t-gs self shielding welding wire, it works fine I also bought the made in Italy 2# item# 44877 for $15 at harbor freight, and the Hobart e71t-11 for $20 at tractor supply my lincoln pro-core 100 cost $75 at a pawn shop 3 years ago the harbor freight blue flames helmet is good, bought a second one because the first one disappeared after welding class one day. try miller and hobart welding boards for more help ESAB has a lot of info.
can any one tell me what gas tanks work in a 82 brat
subiemech85 replied to HGJ's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what's wrong with the turbo models? -
try fuelly for "average" fuel economy, mine is the gl-10 it has the ea81 with ea82 intake and carb, with the ea82T 3.7 PB 4wd the engine makes more power than the clutch can handle, which doesn't mean much which trans. and gearing you have will make a difference as to the "power" for going uphill or against the wind
1987 subaru rx aftermarket performance parts
subiemech85 replied to BrandonZL1's topic in Subaru Retrofitting
SEARCH for subspeed http://web.archive.org/web/20050307041648/http://www.subspeed.com/Rx.htm http://www.ultimatesubaru.org/forum/showthread.php?t=87980&highlight=subspeed and if $ grows on trees for you, RAM engine$ -
1inch lift block
subiemech85 replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
twist your nuts -
the gauge position is not "normal" no "overflow" tank until gen3 the bracket is for the jack only time mine read higher is when it was 1/2 gallon low of coolant I added a vw diesel coolant tank when I did the engine swap refer to picture @ http://www.pixbox.se/pic_show_id30699044.html for "normal" gauge positions this picture was taken before purchase, much cleaner now!
the '85 & '86 had different style shifter from my '85 before I bought it I like my "crest brown" '86 GL-10 better, roof rack, sunroof, added LSD, hitch, ea81, slightly newer radio and equalizer you have ea82t, not ea81t, you seemed to indicate you had both in one post, IIRC
Distributor interchangeability
subiemech85 replied to AthenTL's topic in Historic Subaru Forum: 50's thru 70's
there may be an obscure FORD ea82 may work, CARB only
